Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
    • 8830
    Originally posted by flyjets01@gmail.com
    Evan what's your Cell % after 7.5 min?
    Here is my Maiden.
    Watch this on YouTube and select HD. As seen embedded here, the quality is at 240p, very fuzzy. HD is MUCH better.
      • 5417
      I don't remember but around 59-60% and just at 3.9V. I'll probably add another 30 seconds for my next flights.
      She really floats, doesn't she? This is the only plane I have to use full flaps landing to get it slowed down.
      • flyjets01@gmail.com
        Flt Test
        • Apr 2026
        • 32
        • Western NC
        Evan I think it's the weight that keeps it's moment up. Reminds me of my larger Turbine models.
        Ian
        Management is doing things right; leadership is doing the right things.​
        • Giovanbattista
          • Sep 2026
          • 26
          Hi Evan, so did you use the Flapperon setting? If you landed with the flaps down and then retracted them to use a single aileron… thanks
            • 5417
            Giovan, I'm not sure if flapperon is the correct term. I think that would be your ailerons also acting as flaps (or full span flaps). I pulled the flaps from the MCBe and mixed full span ailerons. So when on the flaps act as ailerons so it is full span ailerons. I am using them every flight. I have the mix on mu retract switch so when the gear are down they are not active and I have standard ailerons and standard flaps. When the gear are up then the flaps are mixed with ailerons for full span ailerons.
            • Giovanbattista
              • Sep 2026
              • 26
              Oh, okay, Evan. I get the model now—you’ve just been experimenting with different mixes. If it gives you such amazing results, I’ll give your great idea a try.
                • 5417
                I wanted more roll rate but didn’t want to do tailerons since I am using the stock gyro.
                • EDF-Jetpilot
                  Jets are a lot of fun
                  • May 2024
                  • 137
                  • Aarburg, Schweiz
                  367
                  I’m going to set up the horizontal stabilizers as "tailerons" and, much like on the F-14, mix the ailerons with the flaps; this is true to the original aircraft and I’m convinced it will yield the best flight characteristics. ;-) I’ll also be using the AS3X+ stabilization system, since I fly with Spektrum gear. It’s really interesting to read about the different flying styles here on the forum!
                    • 2716
                    Here is my Maiden.
                    Nice maiden and excellent landing. What a beautiful place to fly, where are you?
                    She's obviously grass take off capable.
                      Flt Test
                      • Apr 2026
                      • 32
                      • Western NC
                      Brasstown Flyers Details
                      • Address: 811 Settawig Rd, Brasstown, NC 28902
                      • Coordinates: 35.04765, -83.9478
                      It's a small club in the very western tip of NC.
                      Ian
                      • f4u ausie
                        • 1242
                        • Melbourne
                        Hey team hoping you r all well. 😄my flying friend. Got one of these baaaad boys. Hese retired lucky duck. But he's got his troubles.. importantly. Maiden this morning. All by the book... Exactly. 4 flight s. 2 on 5000 mah... 2 on 6000. Not much difference ... But told me. Easy flyer. Like his 2. F4 phantoms. Better off the grass. Bigger wheels. B safe yas all. Oh I had the 70mm. This is just impeccable
                        • SteveW
                          • Mar 2020
                          Hi. I have the ARF version which comes without the BEC that powers the Landing Gear and servos.
                          If I look at the picture of the BEC in the F35 spares list it can be set to 5v, 6v and 7.4v
                          Can you tell me which voltage is used so I can power my landing gear correctly ?
                          I have attached a pic of the BEC.
                          • paulrkytek
                            • Jun 2019
                            • 539
                            • North of England
                            Ask Motion but my research shows The landing gear retracts, gear door sequencers, power hub, and STOCK servos all run at 5V. Does it not say in the manual ?
                              • 5417
                              I don't trust what the Motion reps say anymore. I'll look at mine and put a meter on it after breakfast.
