Very nice work, thinking outside the box is a dying trait in the new world. I commend you, your effort and the result!
Is this Vettle's last year?
VR
VR
. I'd recommend toning down the ailerons throws a bit at first as the Avanti is very capable of aggressive sport flying and rolls can be intense if wanted.
Sorry I got the rules wrong, but then I was never very good at following the rules.
You will love the Avanti, it is such a sweet flying bird. I must have about 70 flights on mine and it never gets boring. I also have a gyro, the AR636, but it probably doesn't really need one. I fly mine a little heavy, with a RT 6250 mah battery, all the way back, but I get at least 5-6 minutes of aggressive flying on it. It is almost like a trainer. I also added an RC Geek afterburner just for kicks, and yes I know, this jet shouldn't have an afterburner but it looks way too cool and I have one on all 8 of my EDF's. One word of caution, with some of them the flaps will sometime stick remaining deployed. At the beginning, virtually every other flight after using full flaps on landing, one of the flaps would not return to the up position, and it was a different one each time. A few others (not everyone) had the same problem. I solved my problem by reducing the flap speed to 0 instead of any delay (not the best solution, but it worked). Several others, including me had the exact same issue on the B-24 and that same solution solved the problem on both mine. Must be some issue with the blue box. This solution did not work for everyone though. If you've already flown it 10 times with no problem, you're probably not "infected" with the flap virus.
It is troubling though if you drop flaps for a slow pass, raise them up and one stays down, you'll have to quickly get on the aileron and put the flaps back down.
so I need a lot of expo to keep the plane from flying like an insane jitterbug. With the jets, I'll still use expos in the 30-40% range, but with the higher rates. So under normal flying, moving the sticks 0-50%, it "acts" like low rates, but if I need more deflections, it's there, even if it means getting there fairly quickly from 50-80% stick movement. Most, if not all good pilots (I'm definitely not in that category) don't use as much expo as me. I've had some top pilots fly my planes/jets and they definitely don't like having to move the sticks that much, but it's what you're accustomed to. I've gotten so used to and comfortable with having to make "exaggerated" stick movements to get where I'm going that I don't even think about it any more. If I fly someones plane/jet with little to no expo, I'm all over the place, kind of like a drunken sailor in a race car!
