Official Freewing 70mm F-16C Falcon V2 Thread
    • 8207
    I saw the video of Pilot Ryan taking someone's 4S up for a maiden at NEFI...Seemed to fly just fine! May not have quite the punch as the 6S but still looked pretty nimble and speedy to me. Check it out in case you missed it:
    • dkalwishky
      Warbird Lover
      • Sep 2015
      • 1382
      • Des Moines, IA
      I did not see that video before, thanks for posting it. My 6S batteries are all 5000's and while they would physically fit I'm concerned I'd have to add tail weight to get it to balance.
      • gooniac33
        The Original Gooniac
        • Jun 2016
        • 1047
        Anyone flying the 4S version of this plane? I have 4S batteries that I could use, my 6S are all 5000's.....
        I use the 5000 in mine with no issue! Actually my fave battery is the Roaring Top 6s 35c 5800mah pack! The plane loves it!
        • Pete Lane
          Turbine lover
          • 290
          • Los Gatos Cally
          Yep....it was a treat to see it !
          Pete
          • dkalwishky
            Warbird Lover
            • Sep 2015
            • 1382
            • Des Moines, IA
            Good to know, I'm really liking the Arctic Camo scheme. Better add this to my list of planes to buy.
            • PappaBear
              • May 2015
              • 377
              • California
              Originally posted by Alpha10
              Man, I'm VERY disappointed in the new Arctic scheme from Freewing...
              They didn't even paint the white sections and just left it bare foam...It looks extremely cheap and awful...Almost transparent.
              I don't know why they cut corners and didn't paint it white like the T-45 or Thunderbirds F-16. Doesn't make sense to me to have to repaint the white just to get it right.
              My buddy will likely be sending it back... Just a heads up guys. : /
              Poor choice on FW's behalf. :(
              I was excited for this one too... :(
              Painting the model a base white and then painting the gray on the top involves a lot more work, not to mention materials. It has not been done this way to cut corners, it is in an effort to keep costs down to an acceptable level to the customer. If you are not 100% happy with the model you are more than welcome to return it for a refund as long as it has not been assembled and flown. Please see the link to the Motion RC returns policy below.
              IMPORTANT: You must contact Motion RC to request a Return Merchandise Authorization (RMA) number before returning ANY products. Items returned without an RMA number will be rejected and returned to the customer at their expense. Motion RC Return Policy Details If you ordered the wrong item or you no longer want your it
              Martin,
              Motion RC Customer Service Manager
                First and foremost, as Martin said, our customer family's satisfaction is paramount, so if for any reason someone isn't happy with any product they've received from Motion RC, we encourage that person to please promptly contact the Customer Service team to process a return and full refund under our Returns Policy. It's our job and pleasure to keep our customers happy!
                Looking into "why" more deeply, it isn't just because using bare foam in white areas provides lower weight, simpler processes, and less mold cost. In addition, I would say from my experience at our various manufacturing partners that white paint on foam can sometimes, compared to other colors, react differently in sunlight, leading to fading, discoloring, or even in some instances yellowing. We saw this on the old Freewing 70mm F-16 V1... over time we had several complaints about the white painted areas becoming discolored, and we did not want that to happen on the V2's Arctic Camo scheme. The exact reasons why white paint can behave like this inconsistently aren't within my expertise so I cannot speculate. Although, I would observe that using bare foam for white areas is common practice with several models from different manufacturers, implying a common reason. The Taft 90mm Viper Jet, HSD 105mm Super Viper, Hobbyking 90mm Cobra, Freewing Stinger 90, Freewing 80mm Avanti S, Freewing 70mm Rebel V2, Dynam 70mm Meteor, Dynam 64mm Turbo Jet, Grand Cruiser, and other models (not to mention scale gliders) all use bare foam instead of white paint for the white areas.
                When viewed from that lens, the 90mm T-45 and 90mm Thunderbird seem to be exceptions. Fun fact: I remember pushing very hard for white paint on the 90mm T-45, regardless of the disadvantages.
                Perhaps someone more versed on the subject can explain to us why white paint can sometimes age differently over time compared to, say, gray or silver paint. Is it rooted in a UV reaction? Similar to why clear epoxy can yellow over time when exposed to sunlight? I'd really like to know.
                • Pete Lane
                  Turbine lover
                  • 290
                  • Los Gatos Cally
                  http://www.ehow.com/how_7723009_stop...ng-yellow.html
                  • Pete Lane
                    Turbine lover
                    • 290
                    • Los Gatos Cally
                    http://www.britmodeller.com/forums/i...ing-over-time/
                    • Pete Lane
                      Turbine lover
                      • 290
                      • Los Gatos Cally
                      I have a degree in auto body and paint but not an expert at anything.....still learning. Hope this helps.
                      Plane
                        Thanks, Pete! I appreciate those links!
                        • Pete Lane
                          Turbine lover
                          • 290
                          • Los Gatos Cally
                          Your welky.
                          Glad to help !
                          Plane
                          • dkalwishky
                            Warbird Lover
                            • Sep 2015
                            • 1382
                            • Des Moines, IA
                            Hurry up and send it back so I can buy it!
                            • Pete Lane
                              Turbine lover
                              • 290
                              • Los Gatos Cally
                              lol
                              • runway14left
                                • 50
                                Has anyone tried flying the 6 cell version on a 4 cell? I'm wondering if that would be a good way to start and then go up to 6 cells after some flights and comfort.
                                • Alpha10
                                  J e t - J u n k i e
                                  • 377
                                  • Chicago
                                  I doubt it'd even rotate tbh.
                                    Not gonna work unless you do a motor kV change also. Your losing 1/3 of your RPM's by dropping to a 4S pack with the stock motor.
                                      • 7334
                                      That was Boots Whirlygig's and it was impressive! I thought it performed great on 4s, nice for guys who run 4s in prop driven warbirds and are not wanting to spend 100's of $$ on 6s bricks, but want to get into a jet.
                                      Definitely made me a believer
                                        As a follow up to Dan's comment...........that was the 4S version of the 70mm F-16 V2.
                                        Freewing makes them in two flavors.
                                        4S - https://www.motionrc.com/collections...mm-edf-jet-pnp
                                        6S - https://www.motionrc.com/collections...mm-edf-jet-pnp
                                        But the 6S version will most likely not fly on 4S power going back to runway14left question;)
                                        • runway14left
                                          • 50
                                          Thanks for the input. I thought that would be the case. I bought the 6 cell version and am trying to "ease" into all the power it will have. Time to buck up I guess!
