I've set up my F16 with flaperons primarily to get off grass quicker and have finally gotten somewhat proficient at landing with the nose up, but there is a fine line in stall speed.
If I try spoilerons for landing, would I just set the 3rd flap position (switch position 2) to something like 2% +, assuming flaps up 0 position is at 0% and take off flaps position 1 is -8%? I seem to remember that my elevator comp on take off flaps is up elevator and slighly more for landing flaps. Would the spoileron compesation for landing then actually be slight down elevator? And you're saying the surfaces should deflect up only slightly at say 2-3 mm, correct? I do have my gyro gains substantially higher for takeoff and landing flaps, but if I use spoilerons for landing I suspect I'll have to change the FM switch in my as3x rx for gains from Aux 1 (flaps) to the 2 position gear switch as moving landing flaps back up above 0 position will cause the gains to go back to the same as flaps up.
This might also work well on the SU-30 pig. I've put the older 7 channel as3x in it to use flaperons (again primarily for grass take-offs) while still keeping the air brake. She's tough to keep the nose up on landings, especially with the air brake, and stalls at the drop of a hat, even though it still seems to be coming in hot.
You're thoughts would be much appreciated. Although setting it up correctly and getting it right might be like asking a cave man to perform brain surgery.
Hey, what coud possibly go wrong?
