    • Nov 2013
    • 2654
    • Cody, WY
    Originally posted by davegee
    I was able to figure out one way to get the nose gear door to close once the gear is extended in the down and locked position, as the real ones did. I had an extra Doors/gear cable from my E Flite P-51D and plugged it into the gear and door for this plane. Works perfectly!
    I think I'll take another stab at Chris Wolfe's plan to use braided fishing wire on his main gear doors that then attach to the main gear struts. I had some success, but not enough to satisfy me so I removed them temporarily. If this doesn't work this time, I might try to add some dedicated servos to do the job for the gear.
    I ordered a 1/10 scale USAF pilot bust from Chris Wolfe that should be arriving in the mail tomorrow. That will be my weekend project extracting the "Chinese" pilot and installing him in his place (after I paint him, of course!)
    Cheers
    Davegee
    Hi All: I was able to order the 1/10 scale "Sabre Jock" bust from Chris Wolfe and it arrived yesterday in the mail. I had already cut a hole out of the bottom of the cockpit to extract the stock pilot and smoothed up the hole so it would be ready to accept the Chirs Wolfe pilot when I got it painted. My wife did her part and painted the pilot for me.
    Was fairly straight forward getting the pilot into the cockpit. I pretty much copied the idea from CW and how he did his: 1) use a soldering iron to cut out the hole and extract the OEM pilot, 2) glued the CW pilot onto a small piece of basswood painted gray to match the existing floor in the cockpit, 3) glued the pilot and basswood floor onto the cockpit from underneath using RC Canopy glue (in case I have remove it someday). I think it looks much better than the OEM pilot.
    We're having some stormy weather the next couple of dasy, so it might be later in the week until I can fly the new updated model. I'm still working on Chris' method of using braided string to pull the main gear doors open and closed when tied onto the struts. I have tried three times, and I still can't get it to work right. I might give it another go, or I'm also looking at some servos, or a servo to get this door sequencing coorect.
    I'll attach a couple of pics I just took in the shop.
    Cheers
    Davegee
    Click image for larger version  Name:	IMG_3041.jpg Views:	0 Size:	152.0 KB ID:	428918 Click image for larger version  Name:	IMG_3042 (1).jpg Views:	0 Size:	152.3 KB ID:	428919
      • 4819
      https://www.hobbysquawk.com/forum/rc...-sabre-jet-pnp
      Hey All,
      I started an FMS F-86 Non-Official Thread, so click the link and subscribe.
      Now I sound like a ewe-toober
      Best, LB
      • chrizon
        • Jun 2024
        • 16
        Hi all,
        I got my freewing 80mm sabre late last year and kept it for this summer. On only my second time out with it i had a
        bird strike on take off that caused the model to slam into a barb wire fence on full power. Needless to say the main wings and fuselage are shredded as a result. I’ve just seen on the motion rc website that the 80mm is discontinued. So they don’t have any replacement parts. (Also checked
        with support).
        it’s painful that after only 2 trips to my airfield and a handful of flights it looks like that’s the end of the road with this plane.
        can anyone help at all with where I may be able to pick up wings, fuselage and decals from somewhere not yet out of stock?
        I’d hate to have to salvage a few parts for spares after such a short time and have to bin the rest!
        thank you for any help you might be able to give pointing me in the right direction!
        Chris
          • 8748
          Try RCCastle, AliExpress, Banggood. They have been known to sell parts for discontinued models.
           - High Performance EPO EDF Jet.- New Version With 80mm 12 Blade EDF With 3658-2150Kv Inrunner Brushless Motor & New 100A ESC With Reverse Brake Function.- With Flap System Installed.- With Electric Servoless Retract Landing Gear & Metal Suspension Leg Installed.&nbs
            • 5385
            Also put a want ad on RCG. I was really surprised Freewing discontinued this plane.
            • chrizon
              • Jun 2024
              • 16
              Evan D
              YEah to say I was surprised would be an understatement. I think it's pretty poor customer service. I've seen a good few models over the years discontinued as PNP/ARF etc, but the parts remained available for a reasonable amount of time thereafter. But this seems to have just pulled the rug out from under this model with no warning. so given the limited usage over gotten this looks like it'll be stripped of parts and binned sadly
              • chrizon
                • Jun 2024
                • 16
                xviper
                Thank you for this... I'll hit them up and see if I can find a few last parts to see if I can keep this bird in the air just long enough that it doesn't feel like a mistake to have bought in the first place!
                  • 5385
                  One in great shape for sale on RCG.
                  Originally posted by chrizon
                  Evan D
                  • chrizon
                    • Jun 2024
                    • 16
                    Evan D
                    there are about 3 or 4 on there in great shape but all the Ines Ive seen are local pickup only sadly
                      • 5385
                      Can I suggest placing a want ad there?
                      Evan D
                      • chrizon
                        • Jun 2024
                        • 16
                        Evan D
                        yes, great idea thanks... I've just done that, I hope there's a response just soured my experience with the model and the brand given ho little use Ive gotten out of it and now might not be able to keep it going
                        • Mr. “B”
                          • Nov 2025
                          • 4
                          I’ve just started back into the hobby after a long layoff. After Captain Jolley rotated back to the States this F-86 became my Father's. He renamed it the Patricia II. I’m going to change a few of the decals to make it the Patricia II !
