  • Warthog
    Got a question for Jetdude. I'm installing the Shockwave system and wanted to know what type of glue you used to glue the foam panel to the wood frame where your exciters are. Do you think Foamtac would work, or should I use CA?
    Lots of vibration, and Foamtac is flexible.
    Originally posted by waytooslow View Post
    My baby -- A-10 Demo Team Scheme
    Click image for larger version Name:	IMG_4940.JPEG Views:	0 Size:	233.4 KB ID:	267106
    Click image for larger version Name:	IMG_0179.JPG Views:	0 Size:	141.7 KB ID:	267102Click image for larger version Name:	IMG_0180.JPG Views:	0 Size:	114.0 KB ID:	267100 Click image for larger version Name:	image_59602.jpg Views:	2 Size:	108.6 KB ID:	267098Click image for larger version Name:	image_59603.jpg Views:	3 Size:	126.9 KB ID:	267099
    Very nice indeed. Love the stripes.
  • Warthog
    That's a wild AND good looking paint job!!
  • waytooslow
  • Warthog
    Ok. Thanks Dude. I'll let you know how it comes out. That smoke unit I made from an E-cigg works very well.
    If I recall correctly it was around 1/4" or so.
  • Warthog
    How thin did you make the bottom foam where you mounted the exciters?
    I noticed no real difference.
  • Warthog
    Hey Dude, I just watched the video of your BAD ASS A-10 when you taxied up and down your street. Was there much difference in sound between the test bench and that video? I know you were using the 4" speakers on the bench and the 2" exciters in the bird.
  • Warthog
    Ok. Thanks a lot Dude. Can't wait to hear this system in action. I watched your you-tube video of the system on the test board. Really loud!!! Love it.
    Originally posted by Warthog View Post
    Thanks Dude. Bought them. Do you use one on the motherboard?
    No. Just the transducers after I had two of them fail on a Corsair using an Aspire system.
  • Warthog
    These should work
  • Warthog
    Originally posted by RCjetdude View Post
    Hey Brent, I used two of the TT-25 speakers in series to make 8 ohms. The Shockwave2 requires 8 ohms on 6S. I did take advantage of trial fitting the speakers before gluing the fuselage together but I don't think it is necessary. I cut a hatch in the bottom and framed it with strips of 1/8" plywood. Not having the back of the fuse glued on did help with knowing where to cut though.
    Hey Dude, where do I get those heat sinks for the speakers? Thanks
  • Warthog
    These are the ESCs I installed. It already has extra caps wired to the unit.
    https://www.motionrc.com/products/fr...0616e554&_ss=r
    I haven't had mine for very long, but one thing I noticed was a better "Jet" sound. I talked with a tech at MRC before I bought mine, and he did say there is a big difference in performance over the 80mm 9 blade EDFs. I also installed 130 amp ESCs and all 10 awg wire. I'll post when I get more stick time with it.
    Some added caps. soldered to the leads close to the ESC is also a good idea if you haven't done so already on the 130A ESC's. The wiring is extraordinarily long in this model, so it is worth the time to do so.
    I had my 80mm EDF A-10 using the stock ESC's, yet with the Freewing 12-blade fans with inrunner motors (1857kv). They are a drop-in fit, provide good power gains, and sound significantly better in this model than the stock power system. It takes very little time to install, which is nice. It does add some weight, and that needs to be accounted for by adjusting battery location, etc. to bring the CG back to where you need it after the install. However, the additional weight wasn't a noticeable issue on this model, in my opinion.
    My other A-10 used 130A ESC's, Castle Cap Packs, and Freewing 90mm EDF's (and Freewing's 90mm Nacelles). It was an absolute monster with thrust, especially from transition from slow speed to climb, etc.
    If I were to do it all over again though, I thought the Freewing 80mm 12-blade EDF with inrunners was a happy medium between all factors for me, specifically added thrust for the weight, improved sound, minimal install time (because I was able to use the stock 100A ESC's installed, and the Freewing shroud drops right into the nacelles), cost, and the look of the 12-blade fans while the model was static on the ground.
  • Warthog
  • MikeT
    Originally posted by Dirk.S View Post
    Has anyone tried the FMS 80mm fans as an upgrade from stock?
    Is there something wrong with the stock one's? They seem to work just fine.
    Mike
  • Dirk.S
  • Lon
    This Covid virus must be effecting me....I was always so happy with the stock power system in my A-10. I just finished installing and flying her with the Freewing 1857kw inrunner 12 blade power system. First thing I noticed was the sound. Less motor whine sound. And I was very happy with the vertical power improvement. Increase in top end speed not real significant, but noticed. Click image for larger version
Name:	DSC04238 - Copy (1024x681).jpg
