I find the easiest way was to:
1. unclip the clevis from the steering servo to the nose wheel steering arm
2. Unbolt the retract from the model and lift it out of the wheel well
3. Unscrew the 5 screws holding the retract shell halves together
4. Separate the housing halves and remove the trunion with nose gear from the retract housing
5. Undo the C clip and pull the nose gear wire from the trunion
6. Remove the setscrew and remove steering control arm.
Reassemble in reverse order.
For the mains, its a little easier as the grub screws that retain the landing gear wire are in the axle of the trunion. No need to disassemble the retract housing.
