    It has a lot to do with the store, the one close to me calibrates theirs every morning and all the matches they've done for me are very good.
      One tip to reduce the likelihood of a bad scan: If the clerk is using a handheld color scanner, ensure he or she is holding the scanning head perfectly flush against the piece you brought in. Curved surfaces will allow light into the scanning head, which can result in an incorrect color formula. The Home Depot near me recently switched to using a handheld scanner with a scanning head approximately 3" x 5", so I must bring in horizontal stabs or wings, not fuselages or canopies.
      • BadBob
        • Jun 2016
        • 155
        Originally posted by stitch
        can anyone tell me the color for the green one? i have every military green i can find and still can,t match this green.
        I found a perfect match at ACE hardware for both green and blue. Just took in a drop tank hard point for the blue and the horizontal stab for the green.
        Bob Duncan
        • Oxotnik
          Actung, Spitfire!
          • 931
          • Huntsville, AL
          On the topic of painting, I've only ever airbrushed enamel paints, that I thin with paint thinner. I've been handbrushing the touch-up jobs with the Home Depot color-matched paints. I'm about to take on a bigger project (invasion striping), and will need to airbrush it. What do you use to thin the Home Depot latex paints for use in air brushes? Water?
          Good info on the scanner. I'll watch what they're doing more carefully next time. The last time, I took in a wing from my EFlite P-47D and they scanned the wing top (OD Green) and wing bottom (grey). The grey was spot on, but the green was too dark.
          Warbirder
          • Lon
            • Jul 2014
            • 1202
            • Miles, Iowa
            I'm out of town for a couple days. If you haven't found a match by then. I'll take a picture of the color code i had made, that matches very good.
            Lon
              Stitch.............. as Alpha and others have indicated that color tint variations can change from store to store. I have put the Home Depot mix that they did for my bird over in this thread.
              http://www.hobbysquawk.com/forum/ele...-38-paint-code
              Personally if it was me(which I did with my own), I'd just take the horizontal stab and have them scan it.
              Good luck,
              • BadBob
                • Jun 2016
                • 155
                Originally posted by OV10
                Stitch.............. as Alpha and others have indicated that color tint variations can changed from store to store. I have put the Home Depot mix that they did for my bird over in this thread.
                Good luck,
                The HZ stab and a drop tank hard point, if you haven't already glued it in.
                Bob Duncan
                • stitch
                  • Dec 2014
                  • 142
                  well i got match for drop tanks here,but not green.just have a little scratch on wing was going to touch it up but heck it will need more after i fly it lol!
                  • stitch
                    • Dec 2014
                    • 142
                    home depot is like 30 miles from me lowes is 16 so may try them for scanning paint.anyone have bad luck at lowes for scanning?
                    • BadBob
                      • Jun 2016
                      • 155
                      Got an ACE hardware near by?
                      Bob Duncan
                        • 7387
                        They look great, guys!! Take to the skies with them. This from probably the biggest maiden-chicken on the Squawk. When I got the F8F, she was up in the air within two days of arrival, best thing I could have done, otherwise I could have dreamed up all the things that would/could go wrong.
                        The maiden was a piece of cake!
                          • 8817
                          I agree! How many weeks and weeks has it been with all the messing and buggering about with the plane and it still hasn't seen sky yet. It'll be obsolete before it flies. I mean, doesn't foam degrade after a couple of years? :sick:
                            • 7387
                            HAR!!!!
                              We were privileged to enjoy a great weekend of flying together with old friends and new ones this weekend. Xplaneguy's Warbird Squadron showed up in force and we put 11 aircraft in the sky at once. Four or five bombers, fighters, and the new Tigercat. We also flew a couple P-38 formation flights. It's difficult to capture the fun in still photos, because the camera doesn't show the uniformity with which these aircraft are being flown, and just how consistent there spacing is as they fly a consistent circuit. Here are a couple of the fun stills. Eventually I'll need to edit the footage into a video.
                                The Zero was very brave! I like the four engine P-38...
                                • MikeT
                                  Here......Hold my beer.
                                  • 1060
                                  Awesome pics.
                                  Mike
                                  • Lon
                                    • Jul 2014
                                    • 1202
                                    • Miles, Iowa
                                    Excellent pics!! :)
                                    I'm sure it was a great time at the field!!!
                                    Lon
                                      Beautiful pictures, these Flightline planes have set the standard for foam warbirds going forward.
                                        • 7387
                                        Wow, how about that, Flightline rules!!
                                        • ryramZ
                                          Pilot Ryan
                                          • Dec 2012
                                          • 814
                                          Awesome! All winter I wish I lived in California.
