  • Originally posted by The Sheriff View Post
    Well, I didn't lose all control, but lost a motor with no altitude or airspeed. Batteries came back healthy and with plenty of juice.
    Sorry to hear that. I pulled the stock motors and ESC’s for a more powerful setup. Was going to use them for another project. Might hold off on that now, although I did fly it a couple of times stock with no issues.
    • Originally posted by donskit View Post
      Both esc are still working but I test ran them afterward and they pull about 25 amps but do run quite hot
      If they run "hot", one or both could have gone into thermal shutdown. When an ESC does that, putting the throttle to zero for a second or two, can bring it (them) back to life for another short stint till they shutdown again. I've found with one of my planes that an ESC (or engine) getting really hot was due to a bad connection or bad solder somewhere (or anywhere) between the battery and ESC, between ESC and motor. On that plane, when I resoldered the connection at the battery, everything cooled down.
      On this Bronco, there are some very long runs of wiring with some hidden connections. It may be necessary to trace it all from one end to the other and check those as best as you can.
      • Thanks for the update, I think I an done with this plane as it will cost too much to get it going again.
          Flew my new OV10 for the first time and after about 4 minutes using (2) 4s 4000 mah batteries I lost power, possibly in one motor, and lost all control and crashed. I checked the battery condition in both batteries and found that there was still about 65% power remaining. Anybody else have similar problem?
          Those are the exact circumstances that befell the previous owner of my Bronco. I bought it from him for $50 after he crashed it. I replaced the crumpled Fuselage and tested all the electronics. During motor testing I saw that the ESCs were maxed out at 26 amps on full throttle and one was getting rather warm. Considering they are 30A ESCs thats too close for comfort (for me). I replaced the ESCs with ZTW 45a ESCs and successfully maidened it today.
          • Thanks for the info. I think I will upgrade as I now have a new OV 10 nearly assembled but the ESCs are on back order.
            • As I’ve mentioned a few times, the P-38 and Tigercat ESCs have the correct wire length and work perfect in the Bronco. I have the Tigercat ones in mine. That way you don’t need a BEC either.
              • Its strange that they would put in 30 amp ESCs in the Bronco that weighs just slightly less than the Tiger Cat which comes with 60 amp ESCs
                  You can't just go by the weight of the planes. That's only one part of the equation. Take a look at the other aspects of each plane.
                  1. 3530 motor vs 3748 / 3648 motors. Not just size differences but internal differences.
                  2. The P-38 turns 12" props vs 9.5" on the OV. If you put those tiny props off the OV onto a P-38, it's not likely to push over 30A either and the plane won't likely get off the ground.
                  Most of these mass produced planes are equipped with stuff that will just do the job, with very little left over. If you were to put a meter on a P-38, it might surprise you that it's pushing close to the rated amps for its ESCs. Having said that, even those 30A ESCs can probably take 35A to near 40A on short bursts (a few seconds).
                  Then there are other unique circumstances on any particular model that can stress the powertrain.
                  • Terry (tan), Vic (green) and me flying today, 9/6/2020, Vic was also FPV so I'm sure he'll post his too
                    • Originally posted by thomasnwilliams View Post
                      Tolga.... Huey pilots from Real Model Pilots in the UK didn't work out. I got 1 email from Sean then nothing. Tried to order on his site but delivery option was only UK. I searched for a week and found same quality Pilots but not the selection on CGTrader, I downloaded the STL files I liked and printing now, not cheap but they look to be worth it. I really wish Sean would offer STL download on his Pilots, that would open him up world wide. Thanks for the info anyway!
                      Really sorry to hear that. I have now finished my cockpit and will be posting photos here. I am really pleased how well these pilots turned out for the Bronco.
                      Anyhow good luck and hope you will get it sorted.
                      Tolga
                      Instagram: @_t01ga_
                      YouTube: t01ga
ID:	273016Click image for larger version
ID:	273014Click image for larger version
ID:	273015Click image for larger version
ID:	273012Click image for larger version
ID:	273010Click image for larger version
ID:	273008Click image for larger version
ID:	273009Click image for larger version
ID:	273007Click image for larger version
ID:	273006Click image for larger version
ID:	273004Click image for larger version
ID:	273005 I have completed upgrading my cockpit and I hope you like it. Here are several photos from the workshop and I then I will post some static shops from the field.
                        There are some action shots to follow which I will
                        post as soon as I get them from the fellow club member who kindly took those.
                        Tolga
                        Instagram: @_t01ga_
                        YouTube: t01ga
ID:	273028Click image for larger version
ID:	273027Click image for larger version
ID:	273026Click image for larger version
ID:	273025Click image for larger version
ID:	273024Click image for larger version
ID:	273022Click image for larger version
ID:	273023 Static shots from today at the field...
ID:	273020Click image for larger version
                          Tolga
                          Instagram: @_t01ga_
                          YouTube: t01ga
                          • Outstanding work "T" looks like the real deal.
                            • Originally posted by boomer108 View Post
                              Thanks man, appreciate that!
                              Tolga
                              Instagram: @_t01ga_
                              YouTube: t01ga
                              • Really T, You did a fantastic job. If you search pics of the one this is actually copied from, you could almost do side by side comparison's to you shots that are posted from nearly the same angle.
                                • One example,Thow a coat of clear gloss on it and it be very pretty!!!!!
                                  Click image for larger version  Name:	N388RC-1.jpg Views:	0 Size:	193.0 KB ID:	273067Click image for larger version  Name:	N388RCmodel_1.jpg Views:	0 Size:	120.9 KB ID:	273068
                                  • Originally posted by sam51401 View Post
                                    Thanks Sam, really appreciate that. White undercarriage and red&white prop tips are on the list.
                                    Tolga
                                    Instagram: @_t01ga_
                                    YouTube: t01ga
                                    • Also from yesterday. Click image for larger version
ID:	273139Click image for larger version
ID:	273153Click image for larger version
ID:	273152Click image for larger version
ID:	273151Click image for larger version
ID:	273149Click image for larger version
ID:	273150Click image for larger version
ID:	273147Click image for larger version
ID:	273148Click image for larger version
ID:	273146Click image for larger version
ID:	273145 Aerial shots from yesterday. Click image for larger version
                                        Tolga
                                        Instagram: @_t01ga_
                                        YouTube: t01ga
                                        • Here is a pic of my OV10 was going to maiden it yesterday but it didn't happen.
