  • t01ga
    Originally posted by Marco Polo
    EU shipment is approx 2 weeks away.
    So was the US but arrived 2 weeks early. So I am hoping we might get our shipment notices some what early as well.
  • Marco Polo
    Originally posted by t01ga
    I hope the EU stock won’t be long. Now the waiting game got even more harder!
    Originally posted by RCGuy83
    Here's the Bronco taking off and landing off-road. This dirt area may look smooth but there are rocks hiding under a very soft layer of dirt as well as some weeds I mowed through. The landing gear is quite strong and has lot's of shock absorption for off-airport operations. The Bronco is a 4X4 pickup truck of the skies!
    YES IT IS.........as I've said before, this is going to be the ultimate all terrain twin for those wanting to venture into twins.
    For those who have never flown a twin..............Do this Bronco first then the Tigercat and then the Lightning
  • t01ga
    Hey pilots! I want to share my experience with the new Flightline OV-10A Bronco. As a customer service team member at Motion RC it's important we get a feel for the build and flying of new products so we can better assist you with any questions you may have. The build is nice and simple like most all Flightline products but following James' build video helped me with the wiring. Being able to take 16in off each side of the plane with the removable wing tips makes transport much easier. The battery tray is large and the canopy has the most volume of any Freewing/Flightline canopy I've seen making it perfect for FPV operations. Once built the Bronco is a sight to behold having an aggressive look sitting on the flight line poised for action.
    With 18 flights on my Bronco in a variety of conditions I can confidently tell you that you're going to love the way it flies. I'm flying mine with an Admiral RX600SP gyro stabilized receiver in Combo C for gyro on/off. It doesn't need a gyro but when the wind kicks up it does help keep the large profile of this plane more stable. It's very easy to pilot the Bronco like a trainer but you can also throw it around the sky on high rates and use unusually large amounts of rudder to increase maneuverability. The Bronco is not a one-trick pony. This is a plane you will start trusting the more you fly it and explore the edges of the flight envelope. Add full rudder deflection with any roll and the roll-rate will dramatically increase. The Bronco will do really tight loops or you can make them large and gradual if you desire. The entire back of the wing is movable control surface so when setting it up step back and make sure it's all evenly set across the wing. The quad flap setup allows for some very short take-offs and landings. The landing gear is stout so fear not taking this bird off-road to the forward operating base. With full flaps and full power you're off the ground in 35-45ft (less with some headwind) and climbing out to altitude very quickly. I found the manuals flap to elevator mix to be the direct opposite of what is needed. The more flap you put down on the Bronco, the more nose down elevator trim you need to keep the nose from shooting skyward. Setting the same manual published percentages to nose down vs nose up settled the plane on approach perfectly. Using two 4,000mah 4S packs I am happy to report 8.5min flight times. Having been flying more EDF lately it was very nice to have so much time for activities up in the sky. I could take off, stunt around exploring the flight envelope, and work the pattern for a few minutes before taking a good landing. I'm very excited to see and hear how others experience this unique aircraft.
    ​Throughout testing I tried to capture the Bronco in a variety of different ways to show what it's capable of. The view from the horizontal stab using a RunCam was my favorite media capturing position on board the aircraft. I chose not to cut this demo video up to show the full 8+min flight time. The winds on this flight were all over the place and it was extremely turbulent at times both above the field and on approach but the Bronco can cut through. If you're on the fence about purchasing one go ahead and hit the happy button. You won't regret it!
    Please note this issue new Bronco owners. I called this out on post #340 after doing my maiden 3 weeks ago on May 21.
    You will also find the
    DX9 settings for the Flap/Ele mix corrected for down elevator on that post.
    Aros Hope that Motion puts a correction note on the product page also
  • RCGuy83
    Battery placement is a non-issue with the Bronco: Put 2X 4,000's all the way forward against the foam bulkhead for perfect CG and you're good to go! I have my timer set to 8.5min and even then was landing with packs at 3.82V-3.86V per cell. I hear some are already looking to add more power but the stock system has plenty of power and allows for the very long flight times. Loitering at altitude the Bronco can putt around at 30-40mph or less heading into wind. Top end speed flat and level averaged 60-65mph and making strafing runs I hit a max speed of 75-87mph. Once you get the plane moving with some momentum behind it she will boogie on the top end! Those 9.5X7 3-blade props sound great at full song too! During the course of an 8.5min flight the Bronco covered 6.3mi of distance.
    Click image for larger version  Name:	IMG_4099.JPEG Views:	0 Size:	87.4 KB ID:	260173Click image for larger version  Name:	Bronco GPS.JPG Views:	0 Size:	177.0 KB ID:	260174
    Click image for larger version  Name:	IMG_4342.JPEG Views:	0 Size:	98.2 KB ID:	260175
    I was secretly hoping for 14 days early, but I'll accept 13.
    Right on time!!! Thanks MRC and team...
  • James
    So excited everyone will be getting their Broncos soon! Love when our container comes in early!
  • RCGuy83
  • Racer944
    I also live in Canada and it's only about 3 hrs to the border for me. However, expedited shipping for this plane is about 50 bucks US (so about 70 Canuck bucks). With expedited shipping, there is no brokerage at this end, only GST and if paid online (FedEx account is free to set up), no fees for collecting it. I calculated that the fuel used in the car to drive down there, the wear and tear (mileage) on the car, my time is worth a lot to me (6 to 8 hrs), waiting in line at the border and all the bugs on the windshield, 70 bucks is a bargain, so really not a "ton" of expense. It's only about 100 clicks and maybe over an hr drive each way for you, so your expenses and time won't be as much as mine.
    No Brokerage fees on FEDEX expedited shipping... that's good to to know!
    In my case its really close to me and the border crossing is never busy, so its worth it. I agree though anything more than an hour or two would not be worth it for me either and I would simply pay the shipping to get these great planes from Flightline....
    Cheers;
    Eric
  • Racer944
    Originally posted by JLambCWU
    I overnight in Ogdensburg taking flights up for SkyWest from Chicago. Was amazed to hear the lengths people go through up there to get around all the government taxes and fees in Canada.
    Cool, its become a great little airport!
    So in my case, its actually not so much the government fees and taxes... The big advantage lies in the fact that its usually free shipping within the US for most things, but as soon as it crosses the border, shipping for a plane like the Bronco is an additional $75. Then you have the "brokerage" fees charged by UPS/FEDEX to do paperwork to clear customs, etc., and that can easily add another $60-$80 to a plane, so you can see it adds up quick. In my case the government still gets its tax dollars as I always declare the parcel crossing the border and pay my Canadian sales taxes at that time. Since I live 35 minutes from the border crossing its a no brainer for me to drive and save what is usually in the neighborhood of $130-150 extra fees per airplane.
    Sorry to sidetrack the discussion!
    Cheers;
    Eric
  • desertdrifter7
    Mr. D. Thank you so much for the flap-elevator issue in the manual. I just looked at the copy I downloaded and, sure enough, it states to add up elevator when deploying the flaps. That appears to be the opposite of what is needed. I could see someone following the manual and, while backing off the throttle to land, putting the plane into a stall.
  • desertdrifter7
    Well, I had originally posted: Outstanding. I just received my email stating my OV-10 is on the way. Sadly, I don't see it listed. So here it is again. Outstanding!!! Ordered my two 4000 mAh admiral batteries for it today as well. Looking forward to getting this plane into the air.
  • Mr D
    Click image for larger version Name:	IMG_4197.JPEG Views:	0 Size:	230.9 KB ID:	260095
    Click image for larger version Name:	IMG_4508.JPEG Views:	0 Size:	235.1 KB ID:	260096
    Click image for larger version Name:	IMG_4088.JPEG Views:	0 Size:	154.9 KB ID:	260097
    Click image for larger version Name:	IMG_4341.JPEG Views:	0 Size:	186.3 KB ID:	260098
    Thanks for the explanation on elevator mix with flap. I’m afraid that depending on how one sets up their radio, the recommendations in terms of +/- elevator can be inadvertently misunderstood. I prefer your description of elev deflection based on a reference of aircraft nose up or nose down.
    Originally posted by Racer944
    Well that's great news! Not for me though... I am probably the only one that was hoping for a delay!
    I live in Canada but ship all my Motion RC stuff to Ogdensburg, New York. I then cross the border myself to pickup items as it saves me a ton of shipping and fees. When I placed the Bronco order, Covid was not a big deal... but now the border is closed so I can't cross over to pickup my package. The plane will likley arrive within the next week or so, but I will not see it until the border reopens in a few months (I sincerely hope)... <sigh>
    Ah well, such is life I guess, enjoy your planes folks I will be eagerly watching all your flight reports and awaiting the moment that I can go get mine!
    Cheers;
    Eric
  • Cutter262
    Shipping notice received!!! Bring on the BRONCO..... STOKED!!!
  • desertdrifter7
    Outstanding. I just received an email that my OV-10 is on the way.
  • JLambCWU
    Cheers;
    Eric
  • RCGuy83
