New E-flite Fw-190A, 1.5m
  • SanExup yeah!!! Please don’t be quite, it is music to my ears
    Tolga
    Instagram: @_t01ga_
    YouTube: t01ga
    • Loving this plane in the grass.
      • i really like this fw190a..flys great when u listen to advise from others lol.. all the statements about landing with some power seem true as i tryed a no power and stalled it from about 2 feet up and it came down on left main,, no damage to plane but the retract quit and now have to wait for july to get a new one from hh...if anyone knows where i can get a new or used retract unit please let me know as i dont want to wait for july
        • For those that have used Callie Graphics what scale did you use? Thanks!
          • Originally posted by jseese View Post
            I usually just tell her which model I'm working with and she sends the correct scale automatically.
            The Eflite FW190 is approximately 1:7 scale
            I made my own waterslide or painted graphics, and my friend did the Russian front winter camo using a combination of some of mine and Callie's.
            • jseese
              Originally posted by Phatbob View Post
              I received my graphics from Callie and I believe them to be on the small side. I calculated scale of the plane at 1/7 and ordered accordingly. I also ordered the nomenclature and find those to be on the large side. If I did it again, I'd order the 1/6 scale decal sheet.
              • Does anyone have a guide for the nomenclature placement? Thanks!
                • How you guys remove the old decals without ruining the surface.
                  • That's not possible completely. It will leave an outline where the decal was. If your repainting, I use packing tape or paint over them.
                    • What can you do to support the elv. rod from flexing?
                      Thnaks
                      • Originally posted by bobtheman View Post
                        Thnaks
                        I did two things to my EFlite 190, to stop the Elevator pushrod from flexing.
                        First, I wedged a piece of foam up against the pushrod tube inside the fuselage. The pushrod still wanted to bend, so I replaced the wimpy stock pushrod with a beefier pushrod. I used a 2-56 rod for my pushrod. It is almost too fat for the pushrod tube, but it’s worked fine for me for over 60 flights.
                        Warbirder
                        • Originally posted by SanExup View Post
                          I remove the decal. I've had bad luck with factoring over some decals. Once removed, feather in an acrylic paint to act as a primer and level the affected area. Usually I use a Vallejo white. I just add it until I get it feeling smooth across the transition. I rarely try to make it perfect because usually a new decal is going where the old one was and this hides most flaws
                          • Originally posted by Oxotnik View Post
                            Thanks for your help
                            • Mostly finished with my repaint on my FW 190. Nowotny’s white 10 winter splinter
                              • T- Elbert So badass!
                                • Thanks SanExup
                                  • T- Elbert I LOVE THIS, well done!
                                    • Need a La 7 or MiG 3 to go with it. Nice work Travis
                                      • A Yak 9 would be cool too
                                        but La-7’s are bitchin
                                        • Originally posted by T- Elbert View Post
                                          TE, Superb work. Just a great job on your repaint. Best, LB
