New E-flite Fw-190A, 1.5m
  • t01ga
    " T "
    • 197
    • UK
    SanExup yeah!!! Please don’t be quite, it is music to my ears
    Tolga
    Instagram: @_t01ga_
    YouTube: t01ga
    • Gilatrout
      RC Pilot Addict
      • 806
      • Albuquerque NM
      Loving this plane in the grass.
      • Ron1950
        Retired ATC
        • Oct 2015
        • 887
        • brandon ms
        i really like this fw190a..flys great when u listen to advise from others lol.. all the statements about landing with some power seem true as i tryed a no power and stalled it from about 2 feet up and it came down on left main,, no damage to plane but the retract quit and now have to wait for july to get a new one from hh...if anyone knows where i can get a new or used retract unit please let me know as i dont want to wait for july
        • jseese
          • Sep 2020
          • 13
          For those that have used Callie Graphics what scale did you use? Thanks!
          • Gilatrout
            RC Pilot Addict
            • 806
            • Albuquerque NM
            I usually just tell her which model I'm working with and she sends the correct scale automatically.
            The Eflite FW190 is approximately 1:7 scale
            I made my own waterslide or painted graphics, and my friend did the Russian front winter camo using a combination of some of mine and Callie's.
            • SanExup
              • 912
              • Western Wy.
              jseese
              Originally posted by Phatbob
              I received my graphics from Callie and I believe them to be on the small side. I calculated scale of the plane at 1/7 and ordered accordingly. I also ordered the nomenclature and find those to be on the large side. If I did it again, I'd order the 1/6 scale decal sheet.
              • jseese
                • Sep 2020
                • 13
                Does anyone have a guide for the nomenclature placement? Thanks!
                • Mark Franke
                  • Apr 2021
                  • 6
                  How you guys remove the old decals without ruining the surface.
                  • SanExup
                    • 912
                    • Western Wy.
                    That's not possible completely. It will leave an outline where the decal was. If your repainting, I use packing tape or paint over them.
                    • bobtheman
                      • 83
                      • I live in Wesley Chapel Florida
                      What can you do to support the elv. rod from flexing?
                      Thnaks
                      • Oxotnik
                        Actung, Spitfire!
                        • 931
                        • Huntsville, AL
                        Thnaks
                        I did two things to my EFlite 190, to stop the Elevator pushrod from flexing.
                        First, I wedged a piece of foam up against the pushrod tube inside the fuselage. The pushrod still wanted to bend, so I replaced the wimpy stock pushrod with a beefier pushrod. I used a 2-56 rod for my pushrod. It is almost too fat for the pushrod tube, but it’s worked fine for me for over 60 flights.
                        Warbirder
                        • Gilatrout
                          RC Pilot Addict
                          • 806
                          • Albuquerque NM
                          I remove the decal. I've had bad luck with factoring over some decals. Once removed, feather in an acrylic paint to act as a primer and level the affected area. Usually I use a Vallejo white. I just add it until I get it feeling smooth across the transition. I rarely try to make it perfect because usually a new decal is going where the old one was and this hides most flaws
                          • bobtheman
                            • 83
                            Thanks for your help
                            • T- Elbert
                              • Sep 2020
                              • 98
                              • Helena, Montana
                              Mostly finished with my repaint on my FW 190. Nowotny’s white 10 winter splinter
                              • SanExup
                                • 912
                                • Western Wy.
                                T- Elbert So badass!
                                • T- Elbert
                                  • Sep 2020
                                  • 98
                                  • Helena, Montana
                                  Thanks SanExup
                                    T- Elbert I LOVE THIS, well done!
                                    • Vaseline
                                      • 290
                                      Need a La 7 or MiG 3 to go with it. Nice work Travis
                                      • T- Elbert
                                        • Sep 2020
                                        • 98
                                        • Helena, Montana
                                        A Yak 9 would be cool too
                                        but La-7’s are bitchin
                                          • 4874
                                          TE, Superb work. Just a great job on your repaint. Best, LB
