  • Prekin
    Actually I am suprised about their visibility. I expected, that the rivets will not be visible under final coat.
    My colleague purchased the Corsair last week. When I finish my Spitfire I will take his Corsair to my workshop. I hope, that he will want just only new paint scheme and pilot. πŸ˜†
    commented on 's reply
    Looks great. Worth the effort. Now ya got thinking about my Corsair. All those rivets from the spine downward aft of the canopy. We'll see. Regardless, just outstanding work. Best, LB
  • Prekin
    Originally posted by Elbee
    PK, A great detail and a remarkable difference. It will be interesting to see when painted. Hopefully, just the right amount of 'dent' to be seen. Best, LB
    In attached pictures you can see fuselage painted by gloss paint.
    In the first picture are Gunze paints I will use for roundels. Click image for larger version
ID:	369275Click image for larger version
ID:	369277Click image for larger version
  • Prekin
    Thank you LB. On starboard you can I see, that I put one layer of dark grey paint. I wanted to see, if the rivets will be visible. Under matt paint they are not so visible like under gloss paint.
    But the biggest pain are the decals and stickers! That was not good modification from Flightline. 😑
    I noticed there are no canopy rails. I am thinking if to just paint them or put some rails behind canopy.
    Originally posted by Prekin
    I had a minute to add some more rivets.]​
  • Prekin
    I had a minute to add some more rivets. Fuselage is nearly done. Just a nose, fin and bottom side of stab.
ID:	369151Click image for larger version
ID:	369150Click image for larger version
ID:	369152Click image for larger version
    I started riveting of the fuselage. When I did some first heads of rivets I got idea, that would be better to do that after final new paint coat. I may try to paint some palces with the rivets now and I will see how they look.]​
    PK, Lima Golf, Dude... eh hem, Lookin' Good, Sir. Best, LB
  • Prekin
    I started riveting of the fuselage. When I did some first heads of rivets I got idea, that would be better to do that after final new paint coat. I may try to paint some palces with the rivets now and I will see how they look.Click image for larger version
ID:	368553Click image for larger version
ID:	368554Click image for larger version
  • kallend
    Originally posted by kallend
    Morse code signaling lamp. It randomly selects one of several messages and sends it out, waits a while, and sends another.
    Having nothing much better to do, I created a version for the ATTiny85 (dirt cheap, about $3 from Amazon, weighs just a couple of grams). The code needed to be modified (fewer messages) on account of memory limitations.
    Anyhow, if anyone would like the code let me know by PM and I'll send it. Let me know whether regular Arduino (capacity for dozens of messages) or ATTiny version.
    Also in my Lancaster (different messages): https://www.youtube.com/shorts/vIycoHjHJU4
    Originally posted by Alpha
    The door hinge is actually on both sides. See the picture showing the door hinge on the correct side (port).
    Post # 50, Alpha explains what happened:
    The mold maker changed the drawing without telling us, thinking it was a mistake that we had omitted it on the starboard side. An unfortunate quirk, but not worth making a new $40k mold to rectify a hinge line most people wouldn't notice, and if they did, is a 1 minute fix to shave down. This is one of the reasons why I didn't claim it was 100% scale.
  • Prekin
    Thank you Jet for kind words, I am glad you like it!
    LB, I was thinking about the extra hinge. They may designed it like some kind spare part. Just like extra screws and bolts in Ikea box 🀣
    Thank you for reminder, I absolutely forgot to fill in the lines!!
    I understand you, the rivets would be like rudder pedal and some more cockpit equipment in small plastic kit with closed canopy. Nobody will see those details, only me would know about those details.
    It was the first time when I used Tamiya putty on foamy kit. The structure of surface was the biggest pain on my FMS P51 project. So I tried another filler.
    I worked only Chameleon primer, but I can try 3M. I see, that many guys work with 3M products!
    Thank you for advice.
    Prekin, the 'extra' cockpit entry door is and has been a laugh for all us who own the FlightLine Spitfire.
    Most who did a repainted variant, cut off the hinge as you did and fill in the door separation lines.
    As for riveting everything. I think you will find depending on what type of paint you re going to finish the Spittie, much of the micro detail will be all but invisible.
    I do a lot of modifications and painting that once I reassemble things, those are not even seen ,
    I know it is there and that is all that matters many times.
    I have not used Tamiya Putty on a Foamie, but it seems that would remove one extra sand/fill step.
    I use Sherwin Williams Shrink-Free Spackling, Foam-Tac Foam Filler, and sometimes 3M gray lacquer spot putty for filling and blending.
    After a lay down 3-4 coats of MinWax Water-base Polycrylic Semi Gloss sanding between coats. Really covers all the differing surfaces textures.
    When that dries the foam surface has a good protective layer which takes primer coats well.
    Best, LB
  • jetfool
    Looking good
  • Prekin
    It's nice that Flightline designed two cockpit doors and I'm sure, that many Spitfire pilots would love them, but I think one door is enough.
    I cut the door hinge on starboard. Also cut the one on port side. The one on left side I will replace by the new one. I know, that is wavy in the picture, but I did not glue it. I will fix it before painting.​
ID:	368121Click image for larger version
ID:	368122Click image for larger version
ID:	368123Click image for larger version
  • Prekin
    For those who would need to do some surface repair. Tamiya putty and Surfacer work great with the foamy parts. You can hardly see that there are any rivets. The new "rivets" looks much better to me.
ID:	368108Click image for larger version
  • Prekin
    Do the rivets on whole airplane or not?? πŸ€”
    Before I decide if to do them or not I finally assembled new Hispano cannon. I did some mods on the CAD design, to get right postion of the rivets. I did compromise between FL design and real Spitfire. Now they look good to me.
    ​Click image for larger version
ID:	368024Click image for larger version
ID:	368023Click image for larger version
ID:	368021Click image for larger version
ID:	368022Click image for larger version
  • Prekin
    Some rivets added. It's not difficult to find out which hatch I started with. On the frist I tried to keep accurate quantity, but that does not look good to me.
    Half of them would be enough. Maybe i'll add more rivets along panel lines.​
ID:	367345Click image for larger version
ID:	367340Click image for larger version
ID:	367341Click image for larger version
ID:	367344Click image for larger version
ID:	367342Click image for larger version
  • Prekin
    Thank you LB!!
    Just finished work on ntenna mast base plate. That is the last extra part of fuselage exterior I will add before painting. The exhaust stacks I will add when the fuselage will be painted.
    Not sure what will be the next step. Cockpit or pitot tube.
ID:	367248Click image for larger version
ID:	367251Click image for larger version
ID:	367250Click image for larger version
ID:	367247Click image for larger version
    Prekin​​​​​​​, most excellent. Best, LB
  • Prekin
    Very happy now. Last fastener replaced and last fastener added.
ID:	367176Click image for larger version
