  • Rubicon99
    • 3311
    Originally posted by JennyC6
    Progress continues on my NCR operated KV-1E. More greebling going on, painting, detailing. Put in a quote for some decals. Tank runs like a swiss watch too.
    Good start I like the color.
    • JennyC6
      • Nov 2022
      • 55
      Ye. It's Mission Models Sandgelb sprayed through a cheap airbrush at about 17psi. I love how it came out as well. Took the time to rust the tracks up, too. Well, fake rust anyway. My 3D printer has been running 24/7 for the past week to churn out some of the greebling I've put on the tank. Extra tanks out back...larger ones for fuel smaller ones for drinking water...some crew stowage, a Fallout terminal for comms with greater command, some ammo cans, a crate, the twin M2 Brownings on the turret, all printed off.
      • cmdrcody
        "Grumpy"
        • Dec 2022
        • 228
        • Largo, FL USA
        Finished up my T90 that I received last Friday. Can't wait to run it after I finally receive a replacement battery from MotionRC since the one that came with it was completely dead and would not take a charge (had it on the supplied charger for a full 24 hours).
ID:	363779Click image for larger version
        Still need to find a fax log to attach to the rear.
        • cmdrcody
          "Grumpy"
          • Dec 2022
          • 228
          • Largo, FL USA
          The replacement battery from MotionRC is scheduled to be delivered today so I thought I would take a look under the hood, so to speak.
          Once it was opened up, I decided to label all the wires to identify them if I ever had to disconnect everything from the TK-7.0 board.
          Click image for larger version  Name:	1214221619a.jpg Views:	0 Size:	127.8 KB ID:	363956
          Click image for larger version  Name:	1214221619c.jpg Views:	0 Size:	109.6 KB ID:	363960
          Click image for larger version  Name:	1214221902_HDR.jpg Views:	0 Size:	107.6 KB ID:	363958
          Last edited by cmdrcody; Dec 15, 2022, 01:33 PM. Reason: Got battery today - Installed it - Tested all tank functions - Speaker blew out!!
          • Rubicon99
            • 3311
            Taigen / Torro Sherman M4 76mm. Finally completed adding the last “battle rattle” accessories.
            Click image for larger version  Name:	15EBC10E-555F-483F-9DB5-5BD8B6D7EF17.jpg Views:	0 Size:	283.6 KB ID:	364098Click image for larger version  Name:	948B942E-C140-4FB1-ADA4-AF54C3B9DB3F.jpg Views:	0 Size:	242.9 KB ID:	364097
            • DavidN
              • May 2021
              • 3180
              • Los Angeles, CA
              And here is my latest IR battle Panzer III...
ID:	364121Click image for larger version
              • DavidN
                • May 2021
                • 3180
                • Los Angeles, CA
ID:	364125Click image for larger version
                • DavidN
                  • May 2021
                  • 3180
                  • Los Angeles, CA
ID:	364128Click image for larger version
                  • DavidN
                    • May 2021
                    • 3180
                    • Los Angeles, CA
ID:	364131Click image for larger version
                    • Rubicon99
                      • 3311
                      Snowy play time of year. Below a modified M41 and KV running around at full speed in the snow. Yes we do get snow in parts of So Cal. Let’s see your tanking snow fun....
ID:	364140Click image for larger version
                      • Zippersnapper
                        Insane Unknown
                        • Mar 2021
                        • 502
                        • SW Texas
                        Your Photoshop skills are as good as mine
                        • Rubicon99
                          • 3311
                          These are screen shots from a video taken through a window and then enlarged. I was warm in the house while driving the tanks. So the photo quality is rather low res. It’s the idea that counts, getting some snow photo shots to start to be posted.
                          • Zippersnapper
                            Insane Unknown
                            • Mar 2021
                            • 502
                            • SW Texas
                            I figured you ge as much snow as I do in SW Texas- Once every 10 years
                            • DavidN
                              • May 2021
                              • 3180
                              • Los Angeles, CA
                              Mobelwagen from DAKRC conversion kits. The AA gun does not rotate or elevate. Too complicated!
                              • DavidN
                                • May 2021
                                • 3180
                                • Los Angeles, CA
ID:	364430Click image for larger version
                                • DavidN
                                  • May 2021
                                  • 3180
                                  • Los Angeles, CA
ID:	364433Click image for larger version
                                  • DavidN
                                    • May 2021
                                    • 3180
                                    • Los Angeles, CA
ID:	364436Click image for larger version
                                    • Rubicon99
                                      • 3311
                                      Slowly turning my test and evaluation course into a battle field. This is just the start of the new forested hill section. I have another 40 trees to add.
ID:	364454Click image for larger version
ID:	364455Click image for larger version
ID:	364456Click image for larger version
                                      • DavidN
                                        • May 2021
                                        • 3180
                                        • Los Angeles, CA
                                        Can you kindly share with me where to get the trees? I need some for my battlefield too. Thank you!
                                        • SoCalBobS
                                          • 2699
                                          • Southern California
                                          David, good work. I gave up my attempt at that tank, because I wanted functions, and the lack of interior space just didn't allow it. Perhaps if the hull top had been hollow it'd be a different story.
