Roban AH-1W Cobra 700 Size Scale Helicopter
  • DCORSAIR
    • 1918
    • Selma, Ca.
    • DCORSAIR
      • 1918
      • Selma, Ca.
      Sorry for the bad video, had no one to hold the camera.
      • Clugh
        Current F3A world champion American motor winder.
        • Sep 2023
        • 5212
        • Research Triangle Park North Carolina
        Man thats nice! Looks scale and sounds good too. What are you powering it with?
        • DCORSAIR
          • 1918
          • Selma, Ca.
          Powering as in motor?, It has a Scorpion 530kv as for motor, KST HV 1035 tail servo, MKS 1220 cyclic servos, Kontronik 160 ESC, Futaba 6303R SBus rx with a Microbeast FBL controller, all stock kit and this is the older kit with the single bearing lever control arms to swashplate, got it dialed in nicely and very easy to fly.
          • Clugh
            • Sep 2023
            • 5212
            Thank you for your reply. Yes, I was wondering about the e power . What series 530Kv. How many cells and what is the average runtime? If you do not mind me asking.
            • DCORSAIR
              • 1918
              • Selma, Ca.
              Oh no problem, 4035-530kv, running on 12 cells, around 5-6 minute flight times and land around 3.85v per cell and that's with my old Gensace 60c 5000mah packs, haven't tried my new HRB 5000 100C packs yet so I'm sure I will get even better flight times with those. I don't know my head speed, I just go by the sound I hear and how the heli responds to my stick position, been doing this a long time so I don't calculate anything.
              Its been a few months since I have flown it, time to get her down and take it up for a few sorties.
              • sfcfury
                • Mar 2019
                • 490
                • Baton Rouge, La
                I'm using the Egodrift 4525-515Kv and usually have 5500 to 6000mah packs (12S) and my timer is set to 8 minutes. I have very slow spool up... so It's about 7 minutes of 'semi-aggressive' scale flight... When I land I usually am at ~3.7v per cell.
                • Clugh
                  • Sep 2023
                  • 5212
                  Not to go too far off topic but what did you run before the egodrift? did you see improvements? Vincent makes a nice motor but I haven't rewound one yet because I was not able to acquire a raw stack and didn't want to tear a good motor down. What ws the average amp draw and what were the peaks you saw.
                  • Shaun Evans
                    • Apr 2021
                    • 121
                    • California, USA
                    How many of you guys had to balance your stock blades?
                    • Gravythe clown
                      • Mar 2019
                      • 711
                      • Clovis, California
                      I e had to balance blades on all my scale helicopters.
                      Gravy
                        • 2817
                        • Arlington, TX
                        Always have needed to. Close, but still needed adjustments.
                        • Shaun Evans
                          • Apr 2021
                          • 121
                          • California, USA
                          Hi,
                          I got the bird up! I need to make some adjustments to the collective scheme, then get her decals on, add more lights and then airbrush some weather and soot on. Are these included decals water-slide?
                          • DCORSAIR
                            • 1918
                            • Selma, Ca.
                            Hi,
                            Sweet, you seen mine already I'm sure, but I will try to get a recent video uploaded that I did over the weekend, I have the same one and yours looks to be flying well.
