(Updated March 28, 2017)
Renowned by its crews and the men and women it has protected on the ground for decades, the A-10 Thunderbolt II, affectionately called the ‘Warthog’, continues to dominate the skies on CAS missions in conflict areas around the world. Despite first flying over 40 years ago, the A-10’s superior ability to execute its intended mission in modern warfare remains unchallenged.
To honor this iconic aircraft, Motion RC and Freewing Models are very proud to announce the world’s largest and most definitive foam electric PNP A-10 Thunderbolt RC model aircraft in the world! Powered by twin 80mm EDFs, this 1700mm wingspan beast is larger than the two 1500mm wingspan twin 70mm EDF A-10s on the market, while still remaining easy to transport. The Freewing 80mm A-10 delivers the best balance between size, weight, thrust, top speed, stall speed, transportability, rough grass handling, and overall scale fidelity. As an added bonus we've included a full compliment of highly detailed weapons in the box; a $50 value!
The model is assembled from just ten main parts. Removable wings and a convenient flexible servo wire harness accessible at the wing root ensures a safe and reliable electronic connection at all times. The A-10’s wings are composed of hollow chambered foam with an interlocking matrix of plywood ribs, carbon square spars, and aluminum blocks, providing rigid yet supple handling.
Recognizing requests from our customers who don’t have access to smooth paved runways, the Freewing 80mm A-10 was specifically designed to be the most grass-capable PNP EDF on the market. While sporting a scale Oleo nose strut, the main struts are tensioned trailing links. With foam rubber tires over 3” tall and 1” wide, we tested the Freewing 80mm A-10 to takeoff from extreme grass 3” tall. The main landing gear mounts are arranged as part of the aforementioned plywood, carbon, and aluminum matrix, to distribute rough landing forces throughout the wing and avoid critical damage.
In the air, the A-10’s all-new power system delivers a fully scale flight profile. Tall vertical loops, hard “jinking” turns, stable slow flight, and authoritative power. Critically, this model was designed to fly at all throttle points, both upright and inverted, without pitch sensitivity. There isn’t any nose weight in this A-10; instead various factors were optimized in concert so you won’t need lots of up elevator to fly level, and varying power suddenly won’t cause the nose to pitch up or down.
As a semi-scale model, the Freewing 80mm A-10 is finished from the factory in USAF two tone gray. A waterslide decal set with over 50 utility markings and three complete A-10 liveries, is included for the pilot to customize his or her A-10. These decals proudly represent:
Indiana’s 163rd Fighter Squadron “Blacksnakes”
Louisiana’s 47th Fighter Squadron “Termites”
Georgia’s 23rd Fighter Group “Flying Tigers”
For pilots wanting to install a matched pair of their own 90mm EDFs on 6s, we will also be offering a 90mm nacelle which bolts into place and retains the outer dimensions of the stock 80mm nacelle. Own the world’s largest, most capable, most customizable, and most powerful foam electric PNP A-10 and add a definitive scale powerhouse to your hangar today!
To read more and purchase this amazing A-10 go to the product page at: https://www.motionrc.com/products/fr...mm-edf-jet-pnp
This photo is of the actual production model:
Photos below show a pre-production sample, painted and detailed by Alpha, showing the potential of the aircraft for personalization. It won the "Best Scale Jet" award at AEf 2017 :)
Preview flight videos of the Prototypes:
https://www.youtube.com/watch?v=H3UVcINa5iE&feature=youtu.be
