View Post
I'd get both as well, plus the gray scheme would provide a great base coat for experimental schemes.Originally posted by Westsider View PostSeems like a lotta gray in the marketplace, not much choice for green out there. :angel:I know I would get both, I'm that caught up, but I would buy a big green first. Grun!
Bingo.......falls right in line with the rhetoric by a lot of modelers in the last year wanting a blank palette to do there own.Originally posted by xplaneguy View Postplus the gray scheme would provide a great base coat for experimental schemes.Warbird Charlie
The wings are about ~750mm each, and the fuse/wingroot is about ~200mm wide. You're looking at ~950mm from starboard root to port tip with just the port wing attached.
The wing is a single electrical connection and two machine screws after sliding on/off of the carbon spars.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Big is cool, but it does present challenges for transport. We've tried to make it as straightforward as possible.
In response to a few PMs, here are pictures of the battery bay. It's quite cavernous. The ply floor is about 100mm wide. Like the Tomcat, the model will CG with the Admiral 6s 4000, but the A-10's bay is wider, taller, and longer, so we've tested 5000s and 6000s in with needing to modify anything. I will be ordering some 8000s to evaluate how they fit, just to test the high end of the size range. I anticipate needing to dremel out some of the underside of the instrument panel to allow for clearance on the front battery, and scooting the rear battery rearward to the bulkhead. Ten minute EDF flights seems achievable since I'm at 5 minutes on the 5000 with an appropriate flight profile.
Did someone get the license plate of that MRC Awesome New Product truck that keeps plowing my bank account over? Thank you in advance. ;)My YouTube RC videos:
I did.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Hey MikeT, I'm heading out to fly but I'll post pictures later of the four decal sets we plan to include in the box.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
.png)
