  • Arcangel
    • Jun 2016
    • 85
    • 29 palms CA, north of Moss Eisley and just this side of Anchor-head.
    Phatbob,
    When I set up my F-15 Eagle, I put the air brake on a separate channel on my receiver and did some flap / aux mixing.
    I have the flaps on a 3 position switch and the brake deploys at full flaps down. The brake closes on positions 1 & 2 for take off settings and flaps up.
    I run a Spectrum DX-18 gen 1, but you should be able to do the same on a DX-9.
    This is just my personal preference but here is a break down of how I set all my flight controls for all my EDFs:
    1) Throttle
    2) Aileron
    3) Elevator
    4) Rudder
    5) Retracts
    6) Flaps
    7) Steering
    8) Aux 1 / special feature { Air Brake }
    9) Aux 2 / special feature
    10) BEC / E-Fuel
    11) expansion module out to channel 18
    • Phatbob
      • Apr 2013
      • 118
      • Baldwinsville, NY
      Originally posted by Arcangel
      Phatbob,
      I guess that's what I'll be doing.I don't see any way around it. When you say " full flaps down", is that at 90 degrees, or the high rate setting per manual?
      Thank you!!
      • Arcangel
        • Jun 2016
        • 85
        Hey Phatbob.
        I always go with the maximum settings detailed in the manual. I see no reason to push a flight control past the manufacturer's suggested maximum limits.
        Although, in the case of my F-15, the maximum suggested limit for the flap deflection was further than I could physically get the flap to travel, so I went with the max physical deflection I could get from her wings. ;)
        • Jet10
          • Aug 2017
          • 19
          Any one...Is the CG to be checked with the gear retracted or down on the f-15.
          • bill34207
            Jet Junkie
            • 455
            • Bradenton, Florida
            I did mine gear down. It's still alive :)
            • purduephigam
              Jet degenerate
              • 352
              • Plainfield, Illinois
              Yes, gear down.
              • Jet10
                • Aug 2017
                • 19
                Okay... I am working on a ARF Model. I'm finding it to be tail heavy. I also built an PNP and it balanced fine with my battery location. this one requires it to be moved forward and I am still not where I should be. I wonder if they add extra weight to the nose cone on the PPN model and put in less on the ARF for the folks using a 8s power??
                  My ARF had weight in the nose cone. I installed an 8S fan but had to remove the weight to get it to balance with my two Admiral 4S 5000 Pros
                    Steve, I did the same thing when I replaced my fan with the FMS 90mm unit. It's a sizable chunk of metal, but I was surprised that it was only .7 oz.
                    • Having Fun
                      Just keep flyin
                      • 42
                      Got the ARF Plus 90mm F-15 and put the 1680KV setup in it. Setting the CG machine at 118mm with a Motion RC 5000 6s battery she comes up tail heavy. Suggestions on what is being used to balance it out. Thanks!
                      • DCORSAIR
                        • 1918
                        • Selma, Ca.
                        Hey there Having fun,
                        I bought the high performance version with the 1680kv and mine came with a chunk of lead in the nose cone from the factory, I think the ARF plus kit does not come with this lead weight. I did leave it in and mine balanced out just a little tail heavy still so I moved my fan/motor forward, used two of the stock mounting holes and drilled out two holes for the front mounting screws, I did that for two reasons, it moves the CG more forward and it also helped the wires to be more relaxed on the ESC, I did grind some of the fan shroud too, it was pinching the wires right where they go under the cheater hole cover. Hope this helps and I don't have the weight of the lead I used, sorry, I glued the nose cone on solid because some people were losing it on a rough landing, I haven't had to remove it yet. This jet is forgiving on the CG too, you can be a little back on the CG and it flies fine. I know I'm not much help but thought the pictures might help you understand what I did to mine, you can also see that my fan cover doesn't sit down flush anymore because I moved the fan foward out of the foam ring, it's no big deal, got plenty flights with no issues, keep your timer to no more than 2:30, it loves to eat batteries with this setup but it's way faster over the stock F-15.
                        I can get you my CG range if you need it?? I use Gensace/Tattu 6S 5000 60C to power mine.
                        • Having Fun
                          Just keep flyin
                          • 42
                          Thanks DCORSAIR! Can't be flying a tail dragger through the air.
                          • purduephigam
                            Jet degenerate
                            • 352
                            I'm not sure if you have any juicier batteries, such as the RT 5500 or 6250. I believe this should get you another 1-2.5oz depending on the battery. I haven't flown my high performance version yet, but have also heard it's a pretty forgiving plane in regards to CG.
                            • Having Fun
                              Just keep flyin
                              • 42
                              Thanks purduephigam, I have some Roaringtop 70C 5500s I fly in my HSD F-16. I will try those. They are about 4 oz. heavier then the Admiral batteries
                                Just placed my order. Looking forward to adding this bird to the fleet!
                                  The Eagle comes in today! :Cool:
                                    It is here in North Texas. Arrived in great shape and in a few days. Thanks Motion!
                                    • scootergenie
                                      Jet lover
                                      • 261
                                      • Stuart FL.
                                      congrats ! BTW, which version did you get ?
                                        Thank you! The standard 6s. Mainly for flight time. My T-45 has the inrunner setup, and it is a battery hog! ;)
                                        • Jet10
                                          • Aug 2017
                                          • 19
                                          Anyone.....The stock bec failed on my F15. fortunately not in flight!! I purchased the castle creation 10 amp bec. After receiving it I discovered that it is only rated for 5 amps on 6s continuous. Am I safe with this? The stock one is rated at 8 amps but I do not know if that is Peak or continuous.
