  • Shaun Evans
    • Apr 2021
    • 125
    • California, USA
    Hi Fellas!
    I'm about to start building my second one for T-power. I don't need these EDF units, so they're on RCGroups if anyone wants some of these new. Also, this kit came with the 'upgraded' servos for the stabs. Are these any good? How do they compare to the Hitec D85's? Thanks!
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1676
      • Catalonia
      Originally posted by t33jetman
      Looking good!
      • Shaun Evans
        • Apr 2021
        • 125
        • California, USA
        Originally posted by Shaun Evans
        Hi Fellas!
        Dang, NADA, huh?
        • kallend
          • 1877
ID:	336419Click image for larger version
          Next you should fix those nozzles.
          • Radar-Guy
            AirBorn Jetworkx
            • 364
            He got the files...
            • Shaun Evans
              • Apr 2021
              • 125
              • California, USA
              Well alrighty then, lol...
                • 8814
                Hi Fellas!
                Dang, NADA, huh?
                You sound a little perturbed and a bit annoyed that nobody responded. Not sure to which point you are referring to ........................... your EDF units or that noone said anything about the Hitecs. If it was about the EDFs that you listed on RC Groups, I'm not surprised. You didn't provide a link to make it easier for any interested parties to go check it out. Instead, you want people to go over there and hunt for it. I hate RC Groups and I go there only if I have a need to.
                If you are referring to the Hitecs, this has been discussed in this thread many times. All that you needed to do was to put in a search within this thread and you would have found all kinds of stuff about it. It's an old topic and I think people are tired of talking about it, especially when it's all posted before.
                • Shaun Evans
                  • Apr 2021
                  • 125
                  • California, USA
                  Haha,
                  Oh how I've missed your lucid, thoughtful and illuminating contributions, lol. This is the 'be careful what you wish for' response. I think I prefer the silence.....
                    • 8814
                    Haha,
                    Impatient, demanding AND snotty. And you think you got voted off the island.
                    • Shaun Evans
                      • Apr 2021
                      • 125
                      • California, USA
                      Hardly any of those things. It's been a while since I was active here, and I instantly remember your unhelpful, unresponsive, pedantic and often-idiotic replies. When you would say stuff that was comically wrong, you'd just move the goalposts or obfuscate and change the subject. Let's just agree that if ever I ask a question, I'm specifically NOT asking you. Fair enough?
                        • 8814
                        Guaranteed!
                        • locharrow
                          • Feb 2020
                          • 283
                          "Here is a video of my gear door , landing light mock up testing."
                          T33...your garage is far too tidy..........
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1676
                            • Catalonia
                            Glorious slow-mo footage is glorious!
                            • Turbinefancy
                              Head-tracking FPV Advocate!
                              • 294
                              • Irvine, California, USA
                              Excellent flights as usual Airguardian!
                              Some of us are slow on the sticks by nature, no playback slowdown required. Sharing a flight in which I took the MiG up to altitude to catch a second sunset, checking out the mountain ranges with head-tracking FPV, swoop down to do some lazy acro to wind down the day. Love the Mig-29
                              • radfordc
                                • 375
                                • Lansing, KS
                                Man, that is some excellent FPV flying. It completely immerses you in the role of "pilot" of a jet fighter.
                                • Birdseed
                                  • Feb 2019
                                  • 12
                                  I maidened my mig 29 yesterday, and managed to get in three flights.
                                  I used Zeee 5200 mah cells and i swapped out the standard elevator servos for savox 1261MG servos which are rated at 15kg/208oz at 6V
                                  My CG is a 1cm behind the manual recommendation, and ailerons raised so that the lower edge of the aileron lines up with the top of the wing. The flap is level with the aileron. I haven’t raised the ends of the wings as some people have done. Stab position is as per the manual.
                                  Flight 1- without any pylons or missiles. Bit of aileron trim required but no elevator trim required at all. Very pleasant flight, but felt like it wanted to make an uncommanded dive on a couple of occasions, and that was without flaps being deployed.
                                  Flight 2 and 3 were with pylons and missiles fitted, and i tried to set up the igyro. However i quickly turned it off. As you can see in the below vid, there were three episodes where it dived towards the ground. Each time i managed to save it. The end of the vid of the approaches, more than likely shows a PIO as the model was a bit quick and my elevator dual rate was set to 80 percent (as per the manual) and 30 percent expo.
                                  So the question is, is the models diving behaviour a result of a fwd CG, or am I experiencing the mig’s dreaded nose diving tendency-despite elevator servos being vastly over torqued?
                                  • Turbinefancy
                                    • 294
                                    Thanks redfordc! I think it’s a common dream among all rc flyers to shrink down and pilot from the cockpit of our own jet and warbird models. With head-tracking FPV, it’s achievable at least visually. I think FPV should be more aptly called “Fighter Pilot View” but that’s just my opinion
                                      • 2709
                                      For some reason I'm not seeing the attached video. Maybe my settings, but have always been able to open videos in the past. By chance did you forget to attach it?
                                      • Birdseed
                                        • Feb 2019
                                        • 12
                                        Not sure why there isn’t a preview attached…
                                          • 8814
                                          https://youtu.be/yiEtDOK8Wls
                                          In all cases where the plane suddenly lost altitude, it seemed like it happened either just as you banked it or right after you banked it and then tried to level the roll axis. I can't tell if you have the thrust vectoring units on the plane. When you are on the ground and you move the sticks to simulate a mild bank like when it was in the air, do any other control surfaces react when they weren't supposed to? I'm just wondering if there is some kind of coupling going on. IE, bank the plane, then the elevators go "down". It doesn't look like it was going all that fast, so can't say it was due to air flow doing something weird to the elevators as we saw when this plane first appeared in Taiwan. The flap down thing was discussed quite a bit in those days as having some affect on the elevators when going fairly fast, but I did several flights at speeds while activating 1/2 and full flaps and mine never dove at all and that was before I installed the TV nozzles. I also don't think your CG had anything to do with the nose dive. The only thing you've got going on that mine doesn't, is the "UP" incident on your ailerons and flaps. Maybe take that out and test fly it again but try to have some altitude if you can. As on one of my old sailplanes where I dialed in UP flaps on a switch, it would lose altitude rapidly but that's with a different kind of wing. Some sailplane guys like to use UP flaps for landing instead of DOWN flaps for landing as it requires a higher angle of attack, which slow the thing down in a more controlled way (sorta like wing spoilers) rather than regular flaps where there is more of a tendency to stall unexpectedly. On this Mig, perhaps a little UP on the flaps/ailerons don't cause a dive till it's bank over a bit.
