  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1664
    • Catalonia
    • Mtpisgah99
      • 41
      You installed a 90mm fan? Have you flown it yet?
      yes, i maiden flight 10x with different batteries 5.5k, 6k, 5k, for 2.5 minutes and 15% @end
      its fast and heavy. descent quick, very little glides characteristic, alpha/flare in landing
      lost control easily, always powered or need more cruising speed than normal.
      using gyro but worse than with 80mm. set up is same in the book.
      may be im wrong in my observation. need to try more flight.
        • 5385
        Very cool, thanks for sharing!
        • Airguardian
          Post Stall Svengali
          • Aug 2020
          • 1664
          • Catalonia
          Tested the Jetfan today. The plane still flew fine with CG 24mm aft from factory marks on the wings. The jet clearly had more power but I also noticed that closing the cheater with the net made the gain not as significant as it could be.
          The bad news is that I crashed, as I drained the battery in bare 3min of use. I didn't even push the jet hard through the flight as I was testing it, so clearly, the 8S 3Ah packs are kinda limited for this setup, despite being perfectly fine on the Eurofighter running a 90mm fan. Cells came down at 3.2V, my bad.
          The good news is that I kinda managed to drop the jet on top of some bushes and the damage was minimal.
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1664
            • Catalonia
            Originally posted by kallend
            I like your storage racks.
            Designed them together with dad. Told him what I wanted, he made a concept, I improved it substantially with a few ideas and then he built it.
            Can't complain!
            • TangoVector
              High alpha wannabe
              • Feb 2019
              • 142
              • Leksand, Sweden
              Thanks for the info and video, what is the all up mass with your setup? I have planned to shoehorn the FMS 90mm that will add 200 grams and an 8S 3300mah combo will weigh as an Admiral 6S/5000. So I'm hoping I will not be too heavy for high alpha stuff. Some weight will be gained after carving out foam and mounting a 3dp thrust tube. Any other things you have learned?
              Looking forward to some flight footage if it is available later.
              • TangoVector
                High alpha wannabe
                • Feb 2019
                • 142
                • Leksand, Sweden
                Wow, you take the scale realism to new heights by re-enacting the 1993 Gripen crash at the Stockholm water festival
                Good to hear the damage was minimal and looking forward to hear more about your new setup as you get it back in the air.
                • Tigerman
                  • 62
                  Anyone know what rockets/missiles will fit on the Gripen 's wing tip
                    • 8748
                    I used the big ones from the MiG29. Painted one red and the other one blue. I think the smaller ones will also fit the slots.
                    • russ t
                      Accomplished pilot
                      • Oct 2017
                      • 11
                      • Vancouver, Canada
                      Can't complain!
                      Sorry, I can't find the racks you are referring to. Perhaps becoming blind ( which is not good for RC). Please could you post a link or post #. Thanks.
                      • kallend
                        • 1857
                        Did you check Thingiverse? There are several 1:9 scale missiles on there (I have posted Sidewinder and IRIS-T, and someone else posted a Meteor.
                        Sidewinder at 1/9 scale for Freewing Gripen. Lug fits the keyhole in the wingtip rail.The mid section has breakaway support at the base to stabilize during upright printing. They look like fins with pads at the base. They can easily be removed after printing.Suggest printing lug solid for strength, 15% infill for the rest.
                        1:9 scale IRIS-T missile with lug to fit Freewing Gripen wingtip rail.The nose section has some breakaway parts that look like fins to support it upright while printing. These are not part of the missile - remove after printing.Will need supports.Underwing pylons at https://www.thingiverse.com/thing:4713773
                        There are also underwing pylons posted.
                        These are a modified versions of the missile pylons by Bettsmums. These have their own mounting hardware. The lug and socket are the same as the Freewing standard. and should be printed separately with high infill for strength. The main body needs to be light - I used 10% infill. A socket is also placed under the wing so the rail can be removed. Depending on the accuracy of the printer, the lug and socket may need to be trimmed to make a good but not loose sliding fit.Be aware that there are small differences between the inner and outer pylons. They go immediately ahead of the bulges on the underside of the wing.Bettsmums' original is at https://www.thingiverse.com/thing:4708956
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1664
                          • Catalonia
                          Lol, wasn't quite the plan!
                          #1596
                          https://www.hobbysquawk.com/forum/rc...273#post296273
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1664
                            • Catalonia
                            New video with red smoke (from before Jetfan upgrade) :)
                            • janmb
                              Slow and low
                              • 729
                              Can't complain!
                              Ripoff! :D
                              • Airguardian
                                Post Stall Svengali
                                • Aug 2020
                                • 1664
                                • Catalonia
                                LOL
                                I, of course, started by checking out racks made by others to get ideas, but I'm fairly confident the output is original enough! ^^
                                • russ t
                                  Accomplished pilot
                                  • Oct 2017
                                  • 11
                                  • Vancouver, Canada
                                  Originally posted by russ t : Sorry, I can't find the racks you are referring to. Perhaps becoming blind ( which is not good for RC). Please could you post a link or post #. Thanks.
                                  Airguardian replied: #1596 https://www.hobbysquawk.com/forum/rc...273#post296273
                                  Thanks Airguardian. I realize now that Firefox for Android was not showing me the pictures, even if I logged into HobbySquawk. With other browsers ok.
                                  Cheers, Russ.
                                    • 2137
                                    • On planet earth....right
                                    Hi All. I uploaded a STL file for Freewing JAS 39 Gripen main wheel covers on my Thingiverse page and is now available for download. Hope this helps your modding ventures .
                                    • Mtpisgah99
                                      • 41
                                      added intake. 15% at end of flight. May be starvation!
                                      • janmb
                                        Slow and low
                                        • 729
                                        All set for maiden tomorrow :D Click image for larger version
ID:	297011Click image for larger version
ID:	297012Click image for larger version
ID:	297013Click image for larger version
ID:	297014Click image for larger version
ID:	297015Click image for larger version
                                        • janmb
                                          Slow and low
                                          • 729
                                          Damn, so what you are saying is that the Gripen is more hungry than the EF? That is certainly not what I would expect.
