  • Tipstalled10
    • Sep 2023
    • 21
    • U.S.A. Georgia
    Found the hidden hardpoints. Ordering new gear doors.
    • kallend
      • 1859
      Originally posted by Tipstalled10
      Can someone tell me what I need to order. My gear door popped off, the plastic piece that holds the nub from the gear door appears to be missing. I have looked at the spare parts but just can not figure it out. Click image for larger version Name:	IMG_0946.jpg Views:	0 Size:	39.3 KB ID:	398181 Click image for larger version Name:	IMG_0945.jpg Views:	0 Size:	39.8 KB ID:	398180
      I don't see it in any of the "Plastic parts" sets. Would be very easy to make with a 3D printer. Or make one out of thin ply or ABS sheet and glue it in.
      • kallend
        • 1859
        Where did you find them?
        • Tipstalled10
          • Sep 2023
          • 21
          • U.S.A. Georgia
          They are located deep in the recess of where it popped out. there is a plastic piece with a hole for the nub. Took me using a dental pick to find it ! The nubs I created with toothpicks were actually too long, once I shortened them and knew where they went they popped right in. Gear doors fixed. Did not cancel the order for the gear doors, old adage, if you have the spare parts on hand you'll never need them. It's the ones you don't have that you need!
          • kallend
            • 1859
            Oh, OK. I thought you meant you'd found them for sale on the Gripen spare parts list somewhere.
            • Gizmo6023
              • Jun 2020
              • 21
              Just started on my Grippen and discovered one of the nose wheel tires is out of round, checked the site for spare parts and the only nose wheels are part of a nose gear set, no separate wheels.
              Does anyone know of a suitable replacement for the stock nose wheel assemblies?
                • 5385
                You have a warranty, have Motion send you a replacement, whether a wheel or assembly.
                • kallend
                  • 1859
                  Both the kits I bought this year came with big yellow notices saying the warranty is only good for 30 days. So it's best not to dilly-dally in checking everything.
                  • Gizmo6023
                    • Jun 2020
                    • 21
                    Warranty expired 23 days ago while I was out of state for work so I am now looking for a suitable replacement to purchase.
                    • Gizmo6023
                      • Jun 2020
                      • 21
                      What is the trick to removing a canard servo? Seems the servo lead is stuck, likely got glued to something.
                      • muzamilabbasi
                        • May 2024
                        • 4
                        I just flew the Grippen, I had a 6s 6000mah pack, had a hard time taking off and felt loss of power even on full throttle. Now this model is running 2100kv motor, I also noticed the wing was rocking and noticed that when you open gear door it flies better. Has anyone. experienced anything similar?
                        Thanks
                        • kallend
                          • 1859
                          Thanks
                          It would help if you told us your setup (receiver, gyro, etc.)
                          • muzamilabbasi
                            • May 2024
                            • 4
                            Hi I flew with jeti assist rx, 6000 mah hrb 60c 6s pack
                            • Reptielenfreak
                              • May 2024
                              • 153
                              Rocking is mainly caused by to high of a gyro rates. A delta winged jet is sensetive to gyro corrections making is wabble
                                • 5385
                                2100kV is a 70mm EDF motor... There is no way to get a good balance with a 6000mAh battery. Even balanced by the marks under the wing the Gripen flies very nose heavy. Read about how all of us, at least most of us are balancing ours.
                                A lot of delta's rock. Especially if it's windy for some reason. Yes, high gains cause oscillations.
                                  • 5385
                                  • kallend
                                    • 1859
                                    Oscillations due to gain being too high are usually very fast. "Rocking" due to delta aerodynamics are generally much slower. It's pretty easy to to tell the difference. I found the Gripen to be particularly susceptible to rocking. I don't remember how I cured it since it was 3 years ago, but I think a HobbyEagle gyro with fairly high yaw gains did the trick.
                                      • 5385
                                      Exactly my point, two different things.
                                      • muzamilabbasi
                                        • May 2024
                                        • 4
                                        Thanks guys, will try out a 4000mah battery next. Also I didn't had any gyro turned on the day wasn't that windy. Will retry it thank you
                                        • muzamilabbasi
                                          • May 2024
                                          • 4
                                          Sorry for the incorrect info, it came with upgraded 3658-2150Kv
