Found the hidden hardpoints. Ordering new gear doors.
Originally posted by Tipstalled10 View Post
Originally posted by kallend View Post
Where did you find them?
They are located deep in the recess of where it popped out. there is a plastic piece with a hole for the nub. Took me using a dental pick to find it ! The nubs I created with toothpicks were actually too long, once I shortened them and knew where they went they popped right in. Gear doors fixed. Did not cancel the order for the gear doors, old adage, if you have the spare parts on hand you'll never need them. It's the ones you don't have that you need!
Originally posted by Evan D View PostYou have a warranty, have Motion send you a replacement, whether a wheel or assembly.
I just flew the Grippen, I had a 6s 6000mah pack, had a hard time taking off and felt loss of power even on full throttle. Now this model is running 2100kv motor, I also noticed the wing was rocking and noticed that when you open gear door it flies better. Has anyone. experienced anything similar?
Thanks
Originally posted by muzamilabbasi View PostI just flew the Grippen, I had a 6s 6000mah pack, had a hard time taking off and felt loss of power even on full throttle. Now this model is running 2100kv motor, I also noticed the wing was rocking and noticed that when you open gear door it flies better. Has anyone. experienced anything similar?
Thanks
2100kV is a 70mm EDF motor... There is no way to get a good balance with a 6000mAh battery. Even balanced by the marks under the wing the Gripen flies very nose heavy. Read about how all of us, at least most of us are balancing ours.
A lot of delta's rock. Especially if it's windy for some reason. Yes, high gains cause oscillations.
Originally posted by Evan D View PostA lot of delta's rock. Especially if it's windy for some reason. Yes, high gains cause oscillations.
Originally posted by Evan D View Post2100kV is a 70mm EDF motor... There is no way to get a good balance with a 6000mAh battery. Even balanced by the marks under the wing the Gripen flies very nose heavy. Read about how all of us, at least most of us are balancing ours.
