Official Freewing Vulcan 70mm EDF Jet Thread
    • 5401
    He is trying to make better a plane he hasn't flown.
    I agree that for the money it's hard to find better. The HP Mirage is close at $50 more than the Vulcan and the lowly HP Stinger64 at $169 is as good if you add the "for the money" part. I put a 6S 64mm set up in my S64 and it is my highest performance Jet, the only one that has truly unlimited vertical.
    • DaFlyingSnek
      RC warbird/edf jets - 9 years
      • May 2019
      • 56
      • CA, USA
      Originally posted by Skosh25
      Interesting. I fly mine stock in Denver and it has no issues with performance. After about a dozen flights now, I'm loving it more and more. Can't think of anything with better performance for the money.
      Oh it already has stellar performance, but why not make it more efficient? This mod also helps with adding flight time due to more efficient airflow to the edf = less power to fly. I also currently reside at 5300 ft up so any benefit is welcome. Actually today a friend brought a radar gun and we measured 125 mph level flight, and a 4.5 min flight time on a 4000mAh 6S (landed at 3.77 Volts per cell). Watching stock videos of the Vulcan, I'd say that's an improvement. Also since I wanted to be able to transport the Vulcan in its box, I am avoiding any mods that will mess with the dimensions of the airframe.
      If you do not wish to add it to your airplane, that is entirely your choice! I just wanted to show and share something I thought would be helpful and cool. I'm not saying the stock performance is poor, because it absolutely is not, but there's no harm in making it better! I also noticed you added the nozzle onto your painted Vulcan, and that increases performance/speed tremendously. I didn't want to do that for the reason above, and that it decreases your static thrust. The splitter doesn't do that. I just did what I thought would work best!
      Exactly! :D
      • Skosh25
        • Mar 2019
        • 177
        • Denver
        Exactly! :D
        Do you have an .stl for the one you put in your Raptor? I have the 8s. Would be curious to try it.
        • DaFlyingSnek
          • May 2019
          • 56
          • CA, USA
          I'm currently away from my home computer so I don't have the stl with me, but if you're willing to dig in the Freewing 90mm F-22 forums, you can find it there. If not, I'll dm it to ya when I'm back!
          • Matthew Starnes
            • Dec 2021
            Just received Vulcan in mail Friday 12-17-2021
            passenger side retract doesn't work
            Need to contact warranty team
            How do I do so
              • 5401
              The web site where you bought it.
              have you verified it’s the retract and not a connection or the blue box?
              • kallend
                • 1877
                ​​​Hello all!
                I had received a Vulcan for my b-day (today) from my incredible family, and being at a mile up in altitude I wanted to improve the performance but still be able to transfer it (college student) in the box (no external parts), so I spent far too long making an inlet duct splitter! Essentially it goes over the stock splitter (seen when you take the wing off) and it should improve airflow to the EDF. I put one in my 90mm F-22 and there was a very noticeable performance increase so I'm hoping this one goes well!
                -Chris
                (also I still need to maiden it. It's my first sport jet, and I've been flying scale for 7 years, but I love it so much already)
                How do you know it gives "Great performance increase" (according to your thingiverse write up) if you hadn't maidened it? Did you measure any thrust increase? Change in current?
                  • 8814
                  Originally posted by Toot
                  Does anyone know if I can use a AR631 reciver in a ultimate 3D plane?
                  This thread is about the Vulcan EDF jet. Your question is better asked in another appropriate thread or you can start a new one in the appropriate forum.
                  • DaFlyingSnek
                    • May 2019
                    • 56
                    • CA, USA
                    Well given its stock speed at sea level is 120 mph and at >5000 ft (with the attachment) I got a listed top speed of 125 mph plus I got an extra 30 seconds of flight time going pretty hard than on James' video. Other than speed and time, I don't have other hard data, but from what I've seen I'd call it a great performance increase! Hope this helps :)
                    • kallend
                      • 1877
                      My (full size) Mooney goes faster at 5,000ft than at sea level. It's atmospheric physics and can't be attributed to any modification.
                      IF you had a before and after thrust measurement under the exact same conditions, then I'd be inclined to believe you.
                      • paulrkytek
                        • Jun 2019
                        • 530
                        • North of England
                        Am I missing something here, just that 4 percent increase does not seem to be a great performance increase, 25% does. Bearing in mind the accuracy of speed recorders and the fact that the air is less dense at 5000 feet above sea level I would have expected an increase in speed of the stock system anyway by around 5% or more . Perhaps you might give this some further thought. The only way to be certain would have been to test the stock setup v the altered setup at the same field and maybe do at least 5 speed runs on each, taking the average and then looking at the results.
                        • Tigerman
                          • 62
                          Fancy this Vulcan, just need a fun EDF. This Vulcan looks to fit the bill. Just wonder how it compares with 80mm Avanti. The 70mm Vulcan is cheaper and I just want a fun EDF to fly over the winter but is it worth paying the extra and get the Avanti????
                          • Chrisrhays
                            • Dec 2021
                            • 15
                            • Lexington,SC
                            Does anyone have a picture on how all the wires are hooked up with the receiver and the blue box? I have power everywhere except the wheels. Only the nose gear operates. I am using a graupner radio that I don’t have a lot of experience with. Thanks!
                              • 5401
                              They fly very similar. I would say they are both as smooth but the Vulcan is faster. The Avanti has gear doors and lights and some like one scheme over the other. Both are really good flyers.
                              If you already have the batteries for one over the other that may make a difference too.
                              • Chrisrhays
                                • Dec 2021
                                • 15
                                • Lexington,SC
                                issue solved. So I can’t delete my post, it’s all setup and came in a 1528g without battery and 2162g with battery
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1676
                                  • Catalonia
                                  • GliderGuy
                                    • 1412
                                    Now THAT'S CLEVER!
                                    -GG
                                      • 8814
                                      Just got this Vulcan myself. It's all built and set-up. Just hanging from the ceiling waiting for spring. I had the Avanti S but sold it a couple seasons ago to make room for something else at that time. I missed it but remembering what my Stinger 90 was like, I decided to get the Stinger instead. I just preferred the looks and the way the Stinger flies over the Avanti. Both were excellent airplanes. I'm hoping the Vulcan will be just as satisfying.
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1676
                                        • Catalonia
                                        Now THAT'S CLEVER!
                                        -GG
                                        Glad you liked it!
                                        So, flew a bit more today, CG further aft, more expo on the elevator, thing flies better now but still feels hella nose heavy.
                                        What are you guys flying this jet at in terms of CG?
                                        • Airguardian
                                          Post Stall Svengali
                                          • Aug 2020
                                          • 1676
                                          • Catalonia
