Official Freewing F9F-8 Cougar 80mm EDF Jet Thread
  • Tom
    Super Moderator
    • Sep 2013
    • 905
    I have a ton of the 3668-1960Kv inrunner with 90mm 12B fan power system on order but they are in a different shipment. I don't have an ETA for that yet. Hopefully not too far behind.
    • Swarick
      • 36
      FedEx just delivered mine. Its all put together awaiting a receiver.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Woohoo, where is the picture??
        • themudduck
          -TMD- Foaming at the Mouth!
          • 1041
          • Burton OH (near Cleveland)
          Here it is! Its mine, you can't have it....
          Click image for larger version  Name:	Cougar.jpg Views:	0 Size:	114.2 KB ID:	379013
          • DCORSAIR
            • 1918
            • Selma, Ca.
            Looks great by the way.....
            • Swarick
              • 36
              Painted the drop tanks.
              • Gilatrout
                RC Pilot Addict
                • 806
                • Albuquerque NM
                Just putting mine together now. I carved a little foam to put the rx in the recess below the battery tray. Fits perfectly
                one thing I noticed is that at about 1/2 travel on the flap servo the flaps hit the tanks. If you fly with the tanks make sure there isn’t a similar issue.
                the painted tanks above look awesome
                • Gilatrout
                  RC Pilot Addict
                  • 806
                  • Albuquerque NM
                  I am going to have to do something about that pilot. So far Im not having any luck finding a close enough ejection seat to print. I suppose while I'm at it I'll pretty up the pilot's workspace with some details.
                  good info here
                  Tailhook Topics Drafts: Grumman F9F/F-9 Panther and Cougar Ejection Seats
                  Tailhook Topics Drafts: Grumman F9F Panther/Cougar Canopy
                  Tailhook Topics Drafts: Search results for f9f​​
                  • Tom
                    Super Moderator
                    • Sep 2013
                    • 905
                    Quick PSA - Everyone make sure the gyro is moving the control surfaces the correct direction before you fly. Freewing is generally good with their gyro programming but please be double sure and check rudder, ailerons, and elevator to make sure the gyro is moving them the correct direction before your maiden.
                      • 5401
                      I let them know on RCG. Am I correct in assuming someone reported that theirs was wrong? Also, to let people know, to correct it you need the programmer.
                      Freewing E52 6 Axis Gyro Programming Card [E5201] Motion RC
                      May be good to add a note to the product page, Support tab and in the instruction manual notes pg 10.​
                      • Tom
                        Super Moderator
                        • Sep 2013
                        • 905
                        Nobody has reported an incorrect setting but I always like to double and triple check, especially since this is only the second plane Freewing has made with a gyro. If it does need a change, a programmer is needed. Put this in the category of better safe than sorry.
                        BTW, the second shipment of Cougars is running slightly ahead of schedule. They are currently on a train to Chicago.
                          • 5401
                          OK, I'll pass that along. Thanks.
                          • StevenR
                            • Oct 2020
                            • 50
                            So us folks in in the second shipment group may have our Cougars sometime next week then??
                            • didier n
                              • Oct 2019
                              • 109
                              • leopoldsburg Belgium
                              What about the shipment for us over here in europe??
                              • Nino
                                • 10
                                Grear
                                Maiden Done. Had an issue with the Gyro Elevator function failed, the rudder and aileron were fine. Removed Gyro Flew Great
                                Nino
                                • hhamzeh
                                  • Nov 2019
                                  • 9
                                  I am not sure about that. RC-Castle has notified its costumers that FreeWing has received at least two reports of reversed rudder gyro direction asking them to check for correct gyro directions before flying the plane. If there are 2 reports at this time, likely there are more. As mentioned by someone before, unfortunately a programming card is required to fix this for those who may have this issue.
                                  This is not really a huge issue but not officially notifying customers on MRC page may cause more financial damage to the company.
                                  My 2 cents.
                                    • 5401
                                    How is Raymond notifying people?
                                    • hhamzeh
                                      • Nov 2019
                                      • 9
                                      Email.
                                      • Ron1950
                                        Retired ATC
                                        • Oct 2015
                                        • 887
                                        • brandon ms
                                        Where’s that train? Lol
                                        • wvrcdude
                                          • Aug 2020
                                          • 18
                                          • Fairmont WV
                                          I haven’t heard but was the second shipment sold out already? Thanks!
