Official Freewing F9F-8 Cougar 80mm EDF Jet Thread
  • #81
    I have a ton of the 3668-1960Kv inrunner with 90mm 12B fan power system on order but they are in a different shipment. I don't have an ETA for that yet. Hopefully not too far behind.
    • #82
      FedEx just delivered mine. Its all put together awaiting a receiver.
      • #83
        Woohoo, where is the picture??
        • #84
          Here it is! Its mine, you can't have it....
          Click image for larger version  Name:	Cougar.jpg Views:	0 Size:	114.2 KB ID:	379013
          • #85
            Looks great by the way.....
            • #86
              Painted the drop tanks.
              • #87
                Just putting mine together now. I carved a little foam to put the rx in the recess below the battery tray. Fits perfectly
                one thing I noticed is that at about 1/2 travel on the flap servo the flaps hit the tanks. If you fly with the tanks make sure there isn’t a similar issue.
                the painted tanks above look awesome
                • #88
                  I am going to have to do something about that pilot. So far Im not having any luck finding a close enough ejection seat to print. I suppose while I'm at it I'll pretty up the pilot's workspace with some details.
                  good info here
                  Tailhook Topics Drafts: Grumman F9F/F-9 Panther and Cougar Ejection Seats
                  Tailhook Topics Drafts: Grumman F9F Panther/Cougar Canopy
                  Tailhook Topics Drafts: Search results for f9f​​
                  • #89
                    Quick PSA - Everyone make sure the gyro is moving the control surfaces the correct direction before you fly. Freewing is generally good with their gyro programming but please be double sure and check rudder, ailerons, and elevator to make sure the gyro is moving them the correct direction before your maiden.
                    • #90
                      I let them know on RCG. Am I correct in assuming someone reported that theirs was wrong? Also, to let people know, to correct it you need the programmer.
                      Freewing E52 6 Axis Gyro Programming Card [E5201] Motion RC
                      May be good to add a note to the product page, Support tab and in the instruction manual notes pg 10.​
                      • #91
                        Nobody has reported an incorrect setting but I always like to double and triple check, especially since this is only the second plane Freewing has made with a gyro. If it does need a change, a programmer is needed. Put this in the category of better safe than sorry.
                        BTW, the second shipment of Cougars is running slightly ahead of schedule. They are currently on a train to Chicago.
                        • #92
                          OK, I'll pass that along. Thanks.
                          • #93
                            So us folks in in the second shipment group may have our Cougars sometime next week then??
                            • #94
                              What about the shipment for us over here in europe??
                              • #95
                                Grear
                                Maiden Done. Had an issue with the Gyro Elevator function failed, the rudder and aileron were fine. Removed Gyro Flew Great
                                Nino
                                • #96
                                  I am not sure about that. RC-Castle has notified its costumers that FreeWing has received at least two reports of reversed rudder gyro direction asking them to check for correct gyro directions before flying the plane. If there are 2 reports at this time, likely there are more. As mentioned by someone before, unfortunately a programming card is required to fix this for those who may have this issue.
                                  This is not really a huge issue but not officially notifying customers on MRC page may cause more financial damage to the company.
                                  My 2 cents.
                                  • #97
                                    How is Raymond notifying people?
                                    • #98
                                      Email.
                                      • #99
                                        Where’s that train? Lol
                                        • I haven’t heard but was the second shipment sold out already? Thanks!
