Official Freewing 70mm F-16C Falcon V2 Thread
  • dahawk
    Augermeister
    • Jun 2013
    • 1006
    • Keller,Texas
    I would think so
    • jfrinconc
      • Oct 2013
      • 2
      Originally posted by Hardway
      Battery tray dimensions are 77mm wide. 200 plus long, more like 220 when using all of the space to the rear of the cockpit, and the height at it's shortest where the battery could side to the rear of the fuse for balancing is 46-47mm, so you are good on two dimensions. It will depend on the battery weight if it will work...The Admiral Pro 4000 is 50 x 42 x 142mm... So it is smaller than your battery described... Hope that helps.
      Hi, thanks for your answer. I've decided to go with the Admiral Pro, is a proven choice. Greetings.
      • Ted7rns
        CVF Warbird Squadron CO
        • Mar 2015
        • 26
        • Newbury Park, Cailfornia
        Okay,
        My Friend and I both have the 70mm F-16 and have a total combined 9 Flights......5 with the RoaringTop 5000mAh 45C and 4 with the Roaring Top 5500mAh 45c that weights 800grams. All Flights were great Both, it's a great plane, love how it flies. Big Thumbs Up here.
        Ted
        • MOFO1
          • 56
          I fly my F-16 with Floureon 4500mAH 45c batteries and Zippy compact 5000mAh 25c . It handles the weight just fine. I actually like the way it flys with the heavier batteries.
            Good deal!
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              I tried to maiden f16 off short grass...ameral 6s4000 cg at recommended 90mm... light breeze ,, couldn't get it off the ground... been suggested that flaperons would help...how do u hook them up anyway? other suggustions would be the fms 70mm 1850kv in runner fan
              • Dirty Dee
                • 768
                • Northern Illinois
                Not sure of you saw Suko's response on RCG, but he linked his blog post talking about the setup. Check it out, pretty informative.
                short and simple is set up airplane for flaperon in the transmitter, then put left aileron in the aileron port, and the right aileron in the Aux1 port (or maybe its switched).
                I just got my plane buttoned up and programmed for a maiden flight tomorrow. Also have it setup with a lemon gyro and the upgraded struts.
                • dahawk
                  Augermeister
                  • Jun 2013
                  • 1006
                  • Keller,Texas
                  Mine has been a hangar queen for almost a year. Hit the reset button and will try tomorrow. Short grass. Dr Mad Thrust 1900kv, Admiral 5000, flapperons. No stabilizer. I wish they had built this plane with flying h-stabs. Not much elevator authority.
                  Really is designed for pavement ops. Narrow stance with small wheels. Frankly , I like the Hawk T1 and Yak-130 better.
                  Give her a go anyway.
                  • JeffS69
                    Jet Pilot
                    • 12
                    • Macomb Twp., MI
                    Click image for larger version  Name:	IMG_2243.JPG Views:	1 Size:	90.3 KB ID:	144608Click image for larger version  Name:	IMG_2246.JPG Views:	1 Size:	175.0 KB ID:	144607
                    Had a great flying weekend here in Michigan. Just logged my 112th flight on this airframe over the weekend. Stock EDF & Turnigy Plush 100A ESC. Awesome Jet!
                    • dahawk
                      Augermeister
                      • Jun 2013
                      • 1006
                      • Keller,Texas
                      Must be doing something wrong on the flapperon setting. Plugged one aileron into the aileron port on the rx. Plugged the other into the aux 1 port on the rx. Set wing type on the DX9 to flapperon with tail normal.
                      Went to flap setting and started dialing in values like I normally do when setting up flaps.
                      I get one aileron and one elevator moving .
                      In servo settings do I need to assign both ailerons to a switch ?
                      Is there a SOP for this somewhere?
                      Thanks,
                      Hawk
                      • Dirty Dee
                        • 768
                        • Northern Illinois
                        Check the Servo setup menu to see how the channels are assigned. Move the sticks while on this screen and see how the channels react. What control surfaces move with elevator input?
                        • dahawk
                          Augermeister
                          • Jun 2013
                          • 1006
                          • Keller,Texas
                          Thank DD,
                          I will check when I get back Thurs night.
                          • Ron1950
                            Retired ATC
                            • Oct 2015
                            • 887
                            • brandon ms
                            went with the new freewing 2210kv 70mm in runner fan from rc castle....don't know why mrc doesent carry it yet...should have enough poop to get off short grass if stats are correct it puts out 5.4lbs of thrust...that's about 1 lb more then stock out runner I think
                            • Dirty Dee
                              • 768
                              • Northern Illinois
                              dahawk, one other thing crossed my mind. You may have selected "Elevon" for aircraft type. check this picture for how channels are assigned.
                              • dahawk
                                Augermeister
                                • Jun 2013
                                • 1006
                                • Keller,Texas
                                I did select Flapperon for wing type and tail normal but I will check the monitor.
                                • Ron1950
                                  Retired ATC
                                  • Oct 2015
                                  • 887
                                  • brandon ms
                                  dave just order the 2210kv in runner from rc castle.. took 2 days to get from hong kong to Chicago then customs for 2 days Monday delivery...8 days from china ..good deal lol
                                  • Beetlemankurt
                                    • Aug 2018
                                    • 124
                                    • Rotorua, New Zealand
                                    Hi all, been stalking this site for a while now and have been active over at another popular RC website too. After flying my FMS Yak 130 for a bit I purchased this fantastic jet and thought you might like to see my repaint. Can’t wait to get her flying. Still got a few bits to do on it. I look forward to being part of this great community.
                                    Cheers Kurt.
                                      Welcome aboard the squawk! For some reason the pics didnt show for me, might be on my end though since I'm just using my phone
                                      • Beetlemankurt
                                        • Aug 2018
                                        • 124
                                        Thanks Rifleman. Mmmmmm....I can see the pics fine on my iPad but not on my phone either. I’ll look into what I’m doing wrong and try again.
                                          Weird indeed. I'll have a look on my computer
