Official Freewing 70mm F-16C Falcon V2 Thread
  • paulrkytek
    • Jun 2019
    • 530
    • North of England
    Finished the painting on my F16 70mm prior to assembly so I attach two large photos and some small photos showing paint stages below. All work is hand brush painted, the tiger is a black and white print I adjusted for scale then hand painted to finish.
    Click image for larger version  Name:	F16 P13.jpg Views:	0 Size:	274.8 KB ID:	327089
    Click image for larger version  Name:	F16 P12.jpg Views:	0 Size:	185.3 KB ID:	327090
    Click image for larger version  Name:	F16p2.jpg Views:	0 Size:	126.6 KB ID:	327091Click image for larger version  Name:	F16p3.jpg Views:	0 Size:	132.5 KB ID:	327092Click image for larger version  Name:	F16 p4.jpg Views:	0 Size:	117.3 KB ID:	327093Click image for larger version  Name:	F16 p5.jpg Views:	0 Size:	131.6 KB ID:	327094Click image for larger version  Name:	F16 p7.jpg Views:	0 Size:	124.9 KB ID:	327096
      • 8228
      Nice job! Looks fantastic!
      • rcaviator
        • Nov 2014
        • 14
        Originally posted by kallend
        Its a 2860, not 2680. I had one in my FW F-16 for a while and it was fine. A little bit of foam trimming was needed to get it to fit. Takes an afterburner well, too: https://www.youtube.com/watch?v=Ubls...el=JohnKallend
        (I now have the FMS PRO unit in mine, which is even better.)
        Thank's for the correction on the motor, my two fingers make many typing errors. I did put the Eflite motor in and as you said, a little foam trimming and it fits well. I maidened it successfully yesterday. The motor worked great.....very fast and efficient. I used a 4000mah 6s and after 3 +minutes battery was 3.9's at 60%. I feel 4 minutes should be easily attainable.
        • gazza
          • Apr 2018
          • 29
          Originally posted by RPC
          Does anyone have the aileron servos configured as flaperons? If so, are they useful to reduce airspeed on landing?
          i have the ailerons set up as just flaps, and the elevator set up as tailerons, flys great
          • Cape Jets
            Member- Jet Jockey
            • Dec 2020
            • 120
            • Cape Cod, MA
            A friend of mine who also has a F-16 70mm Artic Camo noticed a loss of thrust on rotation. He did some digging and found some info on opening up holes on the main retract wheels in the fuse to create more air to the EDF. He states that this bird is restricted with air flow from the air intake. The front landing gear eats up alot of space in the front air intake causing poor air flow. After cutting the holes he said he noticed an increase of thrust by 15%. Have any of you done this mod ?
            • kallend
              • 1877
              I believe I originated that mod. From 2017:
              • Cape Jets
                Member- Jet Jockey
                • Dec 2020
                • 120
                • Cape Cod, MA
                https://www.rcgroups.com/forums/show...postcount=2795
                My friend went with the kallend suggestion of the openings in the main wheel bays. Took her out for a re-maiden last weekend and showed a good improvement on take off rotation (without flaps) and overall speed. After doing more research, I noticed that all other makes of F-16's 70mm or larger have side cheater vents behind the main landing gears. I went with that option on my F-16 70mm and created new openings behind the mains on the fuse. Haven't flown her yet as I am in the process of a new paint livery for this bird, but looking forward to seeing how the additional air intake works. Click image for larger version
                • paulrkytek
                  • Jun 2019
                  • 530
                  • North of England
                  did something similar using sharp metal tube as a hole maker just above the ventral fins, hard to see in black but it worked well
Name:	F16 camo version.jpg
                  • kallend
                    • 1877
                    I have twice broken the little tabs on the cheater grill where the ventral fins attach, due to landing in the grass.
                    Here is a revised version of my 3DP cheater grill with the more robust tabs.
                    The cheater grill on the F-16 is susceptible to damage on a gear-up or grass landing due to the underfins being attached to it. This is a replacement with a more robust attachment. Some minor foam trimming may be required.
                    • Shadow3g
                      • Oct 2021
                      • 2
                      I accidently purchased a 4S 600 14.8 mAh battery 50C would that be to much battery or should I just cap it off at a 6S 4000?
                        • 5401
                        Not sure what you are asking. 4S 600 14.8 mAh battery 50C tells me you have a 4S (14.8V nominal) 600mAh 50C battery. I think you are saying you bought a 4S 6000mAh battery??
                        Maybe this one? Admiral Pro 6000mAh 4S 14.8V 50C LiPo Battery with EC5 Connector [EPR60004E] Motion RC
                        At 624g It is pretty heavy for the 70mm F-16 and because its 4S, 14.8V nominal, it will be very low powered. The F-16 should be used with a 6S, 22.2V nominal battery.
                        • Shadow3g
                          • Oct 2021
                          • 2
                          Thanks Evan, I and appreciate your response, you're right, I left out a 0 on the 6000, I'm going to purchase the required 6S 22.2V 4000 this week, lucky for me Freewing is only 20 minutes down the road, so I order and pick them up the same day, thanks again.
                            • 5401
                            You mean Motion in Chicago? Can I suggest better batteries? Admirals are okay but not what I call a value. I am using Hobby Star 3500 35C in mine from RC Juice and Power Hobby 5000 100C from Power Hobby. The 5000 are not cheap but they are super light weight @575g and really perform great.
                            Powerhobby 6s 22.2v 5000mah 100c Lipo Battery w EC5 Plug Soft Case 6-Cell - Powerhobby.com
                            • Suprawill1
                              Suprawill1
                              • Jul 2022
                              • 10
                              • MD
                              Good suggestion but here's what I found. Per your Hobby Star recommendation, you can get 2 3S high voltage 4100mah, 100C lipos weighing in at only 440g total. (wired in series for 6S) That seems like a bigger kick than the Admiral Pro 4000mah at close to the same price and considerably lighter.
                              As far as the Power Hobbys, if you back down to the 4200mah, you can get a graphene version, also HV and 120c, only weighing in at 442.4g.
                              Shop PowerHobby for premium RC parts, performance upgrades, aluminum hop-ups, wheels, tires, batteries, electronics, slot cars, model trains, and hobby accessories. Fast shipping, competitive prices, and thousands of products from top brands.
                              • Suprawill1
                                Suprawill1
                                • Jul 2022
                                • 10
                                • MD
                                Just got this nice looking bird and plan on sucking up some insects.
                                There is an angled slot on the vertical stab just under the servo. Does anyone now what this is for? I'm about to apply some decals and one of them would cover this slot.
                                Also, when applying the strip decal across the very top of this stab, do you bury it into the hinge area or are you cutting it so it doesn't bind?
                                Thanks for your thoughts.
                                • Suprawill1
                                  Suprawill1
                                  • Jul 2022
                                  • 10
                                  • MD
                                  Where are you F-16 flyers mounting your ESC? I mounted mine on the wooden rail in front of the EDF and now I may have to relocate it to the battery area because the plane is way too tail heavy. The cg is a good 1 5/8" behind the recommended cg and that's with battery as far front as it will go.
                                  Thanks for your replies.
                                  • Suprawill1
                                    Suprawill1
                                    • Jul 2022
                                    • 10
                                    • MD
                                    That would be more like a half inch, not 1 5/8". I had the wrong battery in it. A half inch is still too tail heavy for me. Any thoughts? Not trying to add more weight to balance it out.
                                    • kallend
                                      • 1877
                                      What have you got that's heavy back there? I have no trouble at all getting the CG in the right place with a 4000mAh pack, and it doesn't have to be all the way forward.
                                        • 5401
                                        Leave the ESC, where it is is a good place in air flow for cooling. Moving it you'll need to do a lot of soldering too.
                                        • Suprawill1
                                          Suprawill1
                                          • Jul 2022
                                          • 10
                                          • MD
                                          70mm RC Lander 2200kv EDF and a 100A ESC. Another difference is that I have a 3200mah which is probably lighter than the 4000 pack. A 4200 is on the way but in its own right is a bit light for its amperage. 440.4g as opposed to the 3200's 394.8.
