Official Freewing 90mm F-16 Falcon Thread
    It should be fine as is, mine flew off the grass quite well
      If the f16 flys as well as the eflite phantom does, it should be an excellent plane as well. Only downside to eflite is they love to quickly discontinue planes within minutes after they release them.
        Boy isn't that the truth. "E-flite: Not Discontinued Yet? Give It A Minute."
          • 2716
          Originally posted by Protos
          H Guys,
          Are there any Mods needed on the Freewing F16 90mm for grass runways like I've seen you have to do on the F14 ?
          cheers 👍
          Fly mine off grass and you don't really need any modifications. With that said, there are a couple that may help it on grass if you are so inclined. First off, I'm using the 12 blade inrunner instead of the 9 blade it comes with, which may give it a little extra push on the take-off run (but again, not a requirement). Secondly, I programmed flaperons (others have used spoilerons instead) to shorten the take-off run. The manual even gives you a wiring setup if you decide to do flaperons and all that is required is a 6 channel RX. One last thing I did was changed the stock nose wheel from a 1 3/4" (I think) to a Hangar Nine 2" Pro Lite wheel. Required just a bit of grinding on the strut for it to rotate freely and a modification of the nose gear door. You can do without all of these and it will get off just fine. However, with these modifications mine get's off in less than 100 feet and I'm using an 8100 mah SMC battery weighing about 920 gr, so the mods for me were a bit helpful.
          • Protos
            • May 2021
            • 5
            Thanks for the Information Hugh. Hopefully I might get round to the test flight today then , I'll see what happens with the Gripen first, I was so excited to pull off a successful landing on the first flight I forgot to steer it on the run out and fell off the edge of the runway 😣 she's all fixed now though and ready for round two 👍
            • sam51401
              • 368
              • Sellersburg IN
              Hey Hugh, Im interested in you using the SMC battery and your GC and flight times. I just pressed the button and got one of the blemished ones in the ARF+ version and will repaint to thr YF-16 scheme. Mine will have a Schubie with a 1680kv motor, raffle prize.......from last years Jet Jam. I bought two of those SMC when he first offered so to try in the A10 but now it looks like they have a second ride to fit in. I went with the 1680 as a mild 6s and if i wanted to go 8s, no changes would be needed in the power system.
              • gooniac33
                The Original Gooniac
                • Jun 2016
                • 1047
                Originally posted by Tigerman
                So has anyone been able to compare the 2 F 16 yet to see which one comes out on top ( Eflite 80mm /Freewing 90 mm). I expect it will come down to personnel preference. Think which ever one you buy will be a winner. I am waiting on some more reports on the Eflite 80mm before I decide. All I know is I want a 80mm/90mm F 16 soon, 😊
                I plan to get it as well. I have the 90mm F-16 and actually love the plane! Its an older model though so it will be hard to compare it to the new Eflite because of all the improvements that have come about over time. When the new Eflite comes out I will have 3 F-16s... 70mm Freewing, 80mm Eflite and then the 90mm Freewing. I have also had 50mm versions and the 64mm versions as well...
                  Get 'em while they're hot!
                  • Big12fan
                    mrt1035
                    • 33
                    • KS
                    Can anyone tell me what other model shares the same wing spares as this model? Motion Doesn’t seem to have them for sell under their spare parts section.
                    • Big12fan
                      mrt1035
                      • 33
                      • KS
                      Well, been a while since I put one together that I didn’t realize until a few days ago that the front wing spare is 2 small ones. Still find it odd that motion doesn’t sell these separately.
                        I'm thinking I might just end up gluing my nosecone to the f16. I lost mine in a blackmore, never to be seen again. Just glad I got an extra
                          Well I just went ahead and glued it on. Just feels too loose to me
                            • 2716
                            Maybe a little late, but I've also found several of my aircraft that either the nose cone or canopy hatches just didn't "grab" on tight enough for my liking. The magnets they use are not very strong, so I went to K&J Magnetics (kjmagnetics.com) and ordered all kinds of their "rare earth" (whatever the hell that is) magnets in various shapes and sizes and replaced/added them where needed. All I did was "inlay" them in on both sides, epoxy them in, and now they hold like crazy. Worked great on the nose sections of the B-24 after adding the extra weight of a gunner and servo, as before, any slight bump landing the thing would fall off. On the F-16, since I made like 5 different nose cones to go with 4 different tails, added them to the body of the fuselage and into each nose cone. On the K&J website it lists the "strength" of each so you can pick the ones you need. Compared to the stock magnets, it's night and day.
                              Yeah I had already glued it on. It's all good though
                              • DCORSAIR
                                • 1918
                                • Selma, Ca.
                                What I found to be the problem on most of my EDF jets, the magnets were installed backwards, my one A-4 was really bad, it had two installed backwards on the avionics hump, lucky I caught it before I lost it in flight, I've had 5 of the F-16's and even though they seem loose, I never lost one, looks like you took care of the problem anyway...
                                  Lmao yeah, I used the glue that came with the plane, so I can still be removed without much damage
                                    Well finally flew it again today. I really love how this plane flys. One of the coolest looking planes on takeoff rotation
                                    • DCORSAIR
                                      • 1918
                                      • Selma, Ca.
                                      Nothing like rotating the F-16 and pulling the gear up at the same time.
                                        Heck yeah, straight into vertical
                                        • Peter Flinn
                                          • Jul 2021
                                          • 5
                                          G'day guys. Was thinking about purchasing the in runner version and thought whether my field will be long enough. I would say it is 70 metres with short grass. It has a slight "launch ramp" at the end of the field that is roughly at an angle of elevation of 4 degrees. Do you think the F16 will be suitable at this field...?
