  • Gary S.
    • Apr 2020
    • 52
    • Fort Worth, TX
    Anyone know why the F-16 90mm is not show on the motion site. Not to purchase new of backordered. Just one open box.
    • Gravythe clown
      • Mar 2019
      • 711
      • Clovis, California
      I found both grey and Tbird just by searching under jets.
      Gravy
        • 2691
        You may have the filter set for "in stock only".
        • Gary S.
          • Apr 2020
          • 52
          • Fort Worth, TX
          That was it Thanks!
            • 2691
            That was it Thanks!
            I set my filter for "Ones I Can Afford". But All the pages are blank for me!
            • Gravythe clown
              • Mar 2019
              • 711
              they have a filter for that? Don’t let my wife see it.
              Gravy
              • gooniac33
                The Original Gooniac
                • Jun 2016
                • 1047
                I don't know why but I keep having major issues landing my f16, I can land every other jet I have without a problem, but this one, I just can't figure out I feel like I'm coming in too fast or something, I just can't figure it out. It's embarrassing honestly. Only other thing I can think is the narrow undercarriage on the grass field. It keeps tipping on its side when the nose gear contacts. To be fair to the plane the grass was way tall as the guy who normally mows couldn't because it has been raining for 4 days straight til about 5am this morning. Some parts of the grass was almost 6 inches high. So that is probably the major contributing factor. It was one of those I really want to fly even though I shouldn't moment. Winds were also gusting to 15mph. But the good news is she did get down in a flyable condition, so I just shutdown flying for the day all together
                The F-16, pretty much in any size, doesn't land how you think it will. I have had 50mm, 64mm, 70mm and now the 90mm version... (there will be an 80mm in there soon soon thanks to Eflite/FMS) Every single one of those planes do the exact same thing on landings!! If you try to land them like a regular warbird or any other plane for that matter it will go whizzing by you at high speed and bounce like crazy or tip and make you look like a complete novice! Just land the plane how it wants to and things will be fine. You need to get the plane in a high alpha attitude, hold it there with the elevator, use ailerons to control roll and then use throttle to control your sink rate. Its usually best not to flare it also... just fly it to the ground and it will be fine. Another thing I have done is just spend an entire battery working the landing pattern. Leave the gear down and just get used to what it does in landing configuration. Starting up pretty high and then working my way down to the actual landing itself. Learning to land this plane actually helped me with the F-104 as well since it lands the same...
                • Tigerman
                  • 62
                  So I wonder how the Freewing High Performance 90mm F16 compares to the new Eflite 80mm F 16
                  Could be interesting
                  • Gary S.
                    • Apr 2020
                    • 52
                    • Fort Worth, TX
                    Could be interesting. I never flown either but my vote goes to the Eflite 80mm F16 now Motion RC have increased there prices by 10%. Bearing in mind the £580 for the Eflite comes with an £80 receive and the Freewing 90mm F 16 will almost cost the same without any receiver
                    I am also interested in the 80mm Eflite.
                      • 2691
                      Just take a look at RC Informers grass take-offs and that should tell you what you need to know. Both the E-Flite F-16 and the MRC F-16 are almost the exact same weight, yet the E-Flight has a smaller wing area and a few inches shorter. Oh, and an 80 mm fan vs the 90 mm fan. Maybe I'm missing something, but guess I'm spoiled with my MRC F-16 with the 12 blade inrunner. 100' for take-off ON GRASS, and that's with a heavy 8100 mah battery giving me 5 minutes of flight time and flying with all the ordinance. It's not as great as an 8S, but for a 6S it's pretty special, with outstanding vertical even with a brick for a battery. This is the only airframe that flies just as well with an 8100 mah battery and a lighter 6000 mah. Rich had to finally go to a 5000 mah battery to get the E-Flite up. But that's just me, if someone would send me one for free to try out, no problemo, it will be the best EDF I've ever flown!
                        That makes sense, I had actually thought about flying it in landing configuration that time, but my ego took command and overruled sense. next tr out, and also maiden of the 104 will be done this way to figure out what they want on landing
                          • 5385
                          With the F-104 my only caution is getting it too slow on approach. Both the flaps and airbrakes work well and can slow you down quickly. If you use them you will need more throttle than other planes to stay flying. It flies surprisingly well otherwise.
                          • gooniac33
                            • Jun 2016
                            • 1047
                            its all good been there done that... Just set up a flight to do landing practice only and you should be good. the key to it is not getting on the elevator too much. Let it's weight and the throttle do the work for you. Once you get used to what it will do you will see when you can feed in more elevator to flare or aerobrake etc... it take practice though!
                            I think that the new F-104 will be easier to fly with the new 9 blade set up being so much lighter than the original which helps with CG and overall weight. Same thing apply to that one as well. Just always be ready on the throttle and don't let it get too slow.
                              • 5385
                              I put the 3748-1750kV outrunner 9B in mine and it is a great improvement.
                                Probably just use the airbrakes when I touch down, at least at first. My f86, I use them on final now, would have been pretty cool if they could have added them to the f16, but do understand why it wasn't done, being a clam shell operation and all.
                                • gooniac33
                                  • Jun 2016
                                  • 1047
                                  yeah my buddy did that as well. I want the inrunner though because its got even more punch....
                                  • Tigerman
                                    • 62
                                    So has anyone been able to compare the 2 F 16 yet to see which one comes out on top ( Eflite 80mm /Freewing 90 mm). I expect it will come down to personnel preference. Think which ever one you buy will be a winner. I am waiting on some more reports on the Eflite 80mm before I decide. All I know is I want a 80mm/90mm F 16 soon, 😊
                                      I need to get a better run with my 90mm. I know it has more speed in it, I just haven't got a decent pass with it yet.
                                        • 5385
                                        Tigerman, No one unbiased has the EFLite.
                                        • Protos
                                          • May 2021
                                          • 5
                                          H Guys,
                                          Are there any Mods needed on the Freewing F16 90mm for grass runways like I've seen you have to do on the F14 ?
                                          cheers 👍
