  • Kokopellimusic
    I got online at Motion today and started a "chat" about upgrading the F86. They said "unfortunately Freewing doesn't show any upgrade options." He couldn't suggest any. What have you guys put into yours with out a lot of carving of the foam and such?
  • Boots Whirlygig
    So was that all in one take?
  • JLambCWU
    F-86 Sabre flown to High Flight and America The Beautiful with onboard camera. Turn the Volume Up!
    This was the maiden and subsequent flights on the stock F-86 Sabre. A beautiful flying jet that got faster each flight with the motor break in. 14 flights the first day out, Freewing models proving their durability.
    Big thanks to camera girl for the great footage!
  • Air Florida
    OK so I'm looking to get into EDF jets, and I really like the F86. One of the guys got an old one (fixed gear/no flaps) and seems to have a good time with it. I am about at or above his flying skill level so I have been looking around for a model that's not going to break the bank, and I cam across a F86 sold by General Hobbies that just might work for me.
    Question is has anyone of you heard of this company and is anyone familar with this plane??
    Thanks,
    Rick
  • Oxotnik
    Captain M, are you flying in grass? Where’s Your CG? If you're balancing it per the manual, the CG will be way too far forward, making it much harder to get off the ground. I’d also recommend a high-C battery, but you may have to shave the bottom of the canopy, to allow the fatter, higher-C battery to fit. Even if a lower C battery will work, the EDF is probably going to make the battery get hotter than hell. Heat kills LiPos.
  • fhhuber
    I expect something else is going on, causing less power than what it should have.
    ESC calibration, a bad solder joint acting as a resistor...
  • Phantom
    Originally posted by fhhuber
    Flown almost all of my EDFs on 20C packs with no issues.
    This includes a 12S 5000 watt BVM EVF.
    Yes, you can get a marginal power increase with the lower internal resistance of higher C rated packs. The increased top speed might even be measurable.
    I am really surprised that you fly on 20c packs. Not so much for your larger battery packs but on smaller 6s packs, very surprised. Based on your experience what would you have Cpt Moron do? Aside from recalibrating his esc? I never had issues with the stock power system on take off and mine was pretty old. I purchased it back in 2015 and flew it until a few months ago on the stock system. I upgraded to the FMS fan and 2100kv motor for more speed, of which I got a little bit, mostly I just got a little better efficiency, increasing flight times.
  • fhhuber
  • Phantom
    Originally posted by Captain Moron
    Need a bit of info .Been flying my F86 ,to me it seems a bit underpowered ,especially on the take offs .I am using a 6s 4000mph battery with a 30c rating .If I was to buy the Admiral 6s 4000mph with a 60c rating that Motion RC sell would this improve the problem on my take off or would it just give the same power has my 30c rating lipo just give me longer time with no improvement in the power ratings .If you no what I mean ,Is does take off but only just .It only just get off before the end of the runway looms up .Failing changing the battery the next step would be to upgrade the motor ?
    Just my opinion here, but I wouldn't fly any edf jet on less than a 40c rating. Usually I use 50c or greater, I think rc jet dude uses as low as 35c on his larger capacity 6s batteries but don't really know of anybody who uses less than 35c. So I'd say upgrading to the admiral or any 6s battery with a higher discharge rate would improve your power output.
  • Captain Moron
  • C17loadmaster
    I don’t know exactly how it compares to other planes it regards to actual performance data, but I do know that the plane needs a lot when on takeoff roll. Especially with upgraded power systems. I don’t know if it will cause any negative effects on higher speeds being as most the air will be coming through the nose
  • Race 22 Crew
    Can anyone tell me if the nose gear opening is actually needed for inlet air. Was looking to add a nose gear door to but if it’s a needed additional cheater hole I might just leave it alone? Maybe Alpha can chime in?
  • Captain Moron
    Love my F 86 Sabre .just been watching a programme on the Korean War and the dual between the F86 and the Mig 15 .It now got me wishing Freewing would bring out a 80mm Mig 15 .I am surprised they have not already brought out a Mig 15 . Yes I know Hobby King have just brought out a Mig 17 but think I will wait and see if Freewing will bring out a Mig 15 ,might have a long wait I think
  • C17loadmaster
    I just save to an SD card after I program a new model. With the Sabre I had the issues because I had recently started over with an upgraded RX without saving the .ispm file. The new iX will be out soon and it’s supposed to be a lot better. At that point mine will be worth $100 haha
    I flew my F-86 the other evening after streamlining the inside of the fuselage for better airflow. I could definitely tell the difference in once I picked up a little speed. I carved the foam just aft of the nose gear and cheater grate to at least 45 degree angle to pull air in easily. Theoretically it should increase the airflow while dulling turbulent air forward of the fan. I also pulled the new ESC out of the original location and side mounted it above the battery tray. I closed off the old ESC opening with thin hobby styrene in the air inlet side, and glued another piece on the top of the battery tray so that I could slide lipos back enough to get the CG where I like it (tail touch method).
    Everything worked out great except the ESC gets a bit hotter obviously. I have an alarm set if it gets too close to heat limits per Castle specs.
  • Ron1950
    ya I never have updated my dx8 as its working well and I don't want to take a chance on reprograming...
  • C17loadmaster
    Yeah I have it going. It’s been a pain to deal with a few times in the past year. Other than that it’s been great. It always seems to be an issue after a firmware update. At least I didn’t drive an hour and load up a bunch of planes.
    ...and to think I sold a DX-18 to get it :frown:
  • Ron1950
    hey C17 did you ever get the ix12 working correctly? everyone I know that has had that radio sold it for the dx9...
  • Race 22 Crew
    Was looking for another 80mm and I too was on the fence. After watching several fly at the Jet Jam, including the group of five in formation I say let’s make it a group of 6 next year. I plan on adding gear doors to mine Click image for larger version
  • Captain Moron
    Doh ! Did not want to do that.Wrong thread
  • C17loadmaster
    True statement. They are great planes. I replaced my fuselage and wings after the aileron control horn separated from the foam and will keep it as long as It’s stocked. I just finished upgrading the power system and electronics with parts 3 times the cost of the plane. Hopefully I’ll get to fly in a bit. Last night and the night before were spent trying to get my TX to function properly....
