OK, if you wish ........................... I just looked at my TX settings for my flaps. 3 second delay and 0% ELE comp on all positions. IF I were to use no delay and didn't slow down the plane before throwing the flap switch, then the plane will "balloon" and I'd need some DOWN ELE comp. If that's the way you fly, then experiment with 3% (1/2 flaps) and 6% (full flaps), but this is also dependent upon exact what your flap deflection is set at to begin with. This is for Spektrum but again do this up high to see what it does. And since you should do this kind of stuff up high anyway, that's why I always suggest to NOT use any compensation till you find out what it does based on your flying style.
It's only worthwhile if you know how a person flies. EG. I know guys who do their whole flight with the retracts hanging down. This changes a lot of things and other peoples' settings are much less meaningful.
