Official Freewing 70mm Twin Me 262 Thread
  • seaviper
    ATC retired
    • Aug 2016
    • 1092
    • Philadelphia Mississippi
    I think it was Jetdoc If I am not mistaken. Apparently his 6s pack had a Deans connector which melted itself in the A-4 If I understand correctly. Correct me if I am wrong mr Jetdoc.
      • 8831
      Hmmm, it should be criminal for any company to sell a 6s LiPo with Deans on it. I've had 4s packs come with Deans and I've immediately changed them to EC5. The only exception being the Admiral 4000mah, 4s packs, which I use in one of my Flightline twin props that came with Deans. Since the A-4 comes with EC5, he must have used an adapter to make the battery work or he actually changed the ESC plug on the plane to Deans. That would be inconceivable.
      • fhhuber
        • Aug 2015
        • 1476
        Better Tell BVM to quit shipping 5000 watt 12S EDF units with Deans....
        They've been doing it for over 8 years. (that's how old my pair of BVM EVF 5 inch EDFs using NEU motors and Castle ESCs are and they still have the factory original Deans plugs)
        I melted down an AstroFlight Wattmeter (rated 50 volts, 100 amps) trying to measure one EDF's power. The Deans didn't get warm.
          • 8831
          Might depend on whether or not they're "clones". I can't tell a genuine Deans from a cloned one, so when I see one, I'm likely to change it. My first Freewing SU-35 from 6 years ago crashed. It went down like it had no power to anything. When I found it, the Deans were melted and fused together.
          • jetdoc
            Hobby Squawk Mechanic/ Pilot
            • 59
            • York County, SC
            The Deans Ultra that caused the problem on my A-4 was not so much the fault of tbe connector itself as it was one of the factory solders on the connector. I've used Deans for years without incident on power systems up to 12s. However, a cold solder on any type connector is a bad day once it vibrates loose and begins to arc. I've recently switched over all my HV and high amperage applications over to the new XT90S connectors. These have the integral resistor to prevent arcing as the esc capacitors charge during lipo plug-in. I like them so much I've transitioned to XT's on all my lipos. XT60 or XT90 depending on amp draw.
            • fhhuber
              • Aug 2015
              • 1476
              Deans can have serious problems if soldering is not done right.
              Overheating the blade while soldering the wire on will deform the plastic housing and you wind up with poor contact and a connector that gets very hot, which will melt the solder off.
              The blade being soldered needs to be supported along with the plastic housing to prevent this. Clamping the plastic only will have the hot metal deform it and the blade will not be straight any more. Clamping just the blade, the plastic will shift...
              Then the solder area is relatively small compared to a bullet fully encircling the wire. So silver bearing solder is recommended for both added strength and lower resistance.
              Factory joints won't be using silver solder, they'll be using modern lead free solder. But they will be using a fixture that supports the blade and the plastic as the robotic system solders on the wire.
              • Icarus the 2nd
                • Aug 2018
                • 164
                • Pajottenland, Belgium
                Here's 2 happy pilots after a tandem flight, old vs new livery, in Belgian skies.last weekend.
                I'm the one on the left, the other guy doesn't need an introduction :)
                That new scheme looks very attractive don't you think so ?
                • mr.frankenjet
                  Eat, sleep, FLY FLY FLY !
                  • 448
                  • Virginia, USA
                  I had deans on everything for ever and they are really good. I have found over time (a long time) the do where out as there is a "spring" gets weak and several started to have poor contact . With the new builds I'm building been using xt type,I like these and the chargers are starting to come equipped this way though I will not convert my deans until/unless they where out.The connectors seem to be really high quality and are ez to solder up, we'll see if they pass the test of time.
                  Deans are not rated for high current ( over 40+ amps or so) though they may be OK, here I have been using EC type,they too seem well built, so far so good.
                  Just my experience, everyone has a favorite.
                  rc flyin addict
                  • Icarus the 2nd
                    • Aug 2018
                    • 164
                    I only use 2 connectors:
                    - 4mm bullet connectors for all my 3S planes
                    - 5.5mm polymax bullet connectors for 4S, 5S, 6S
                    They are really easy to solder plus you can stow them away easier in athe crowded compartiment because the red and black wires are completele seperated.
                    Tried XT60 and XT90 and EC5 as well but sometimes I almost damaged my planes because they need more force to unplug.
                    • seaviper
                      ATC retired
                      • Aug 2016
                      • 1092
                      BVM is irrelevant. The 12S 5000W systems only run about 100 amps. The 6s systems run higher current at takeoff. Use Deans at your own risk with a 6S EDF.
                      • jetdoc
                        • 59
                        • York County, SC
                        Maidened the 262 today. Graphene 6s 6000 65C fully aft, separate 2s 1100 LiFe receiver battery forward of the flight lipo. Uneventful as planned. 2 clicks aileron, 2 clicks elevator. Flies like it's on rails. Five minute flight with combined power settings, 3.8/cell remaining. Cruises easily on 1/3 power. Flight pack barely warm. Amazing. Set up the ailerons with 2mm reflex. No hint of tip stall or any other anomaly. Landed like "a butterfly with sore feet", as I heard it described by a club member behind me. As expected, it lived up to every expectation I had for it. I couldn't be happier. BTW, also remaidened the Flightline 63" Spitfire after completing the clipped wing mod with similar results. IMHO, a much better performing aircraft now in all respects. Good day at the field.
                          Congrats on your successful maiden and remaiden! I'm glad so many people are rediscovering just how slick a flyer the Freewing Me-262 is. It's one of the birds the Freewing factory guys here fly for fun, which says a lot.
                          • e4dragongunner
                            Living the dream!
                            • 876
                            • Arlington Heights Il.
                            Will be Next! for sure! RUNNING OUT OF SPACE!
                            • jetdoc
                              • 59
                              • York County, SC
                              I know the feeling. I recently bought an Avanti S from a friend and as I was setting it up in my iX12 I realized that it was aircraft #40! That's just crazy! I pull a 6' x 12' cargo trailer (my wife's idea, btw) to the field but it will only hold around 25% of my fleet. I've come to the realization that it may be time to thin the herd. Ten years ago when 2.4G and electric flight was beginning to take off I told my wife I'd like to get back into RC she said, "I don't care what you buy or how many as long as I don't have to smell gasoline or glow fuel in the house!". Bless her, but I think I got carried away somewhere along the line. Thank you Lord for a great woman!!!!!
                              • 68Strat
                                Opteryx_Air
                                • 7
                                • Wilmington, MA
                                Signing in. I just received my 1600mm Spitfire this week. After buying a bunch of new 6S packs, I somehow convinced myself it was only justified if I bought another plane that used them, and placed my order for the 262 LOL I live in a small single bedroom apartment and a path to my bed is about the only clear space not occupied by aircraft. I'm trying to draw the line at assigning a portion of my bed as an extension of the tarmac.
                                • jetdoc
                                  • 59
                                  • York County, SC
                                  You'll love the 262 as well as the Spit. I really like my Spitfire much better since I installed the clipped wing kit. I also started flying it with a Turnigy Graphene 6s 4000 45s instead of the Dymond 6s 5200 35s I'd been using. Much more well-mannered than before.
                                    Finally picking one of these up, along with the new F-22. Much fun ahead. Already have the CF beef up on the nose planned for the 262.
                                    • C17loadmaster
                                      Retired USAF Aircrew
                                      • May 2018
                                      • 371
                                      • Auburn, CA
                                      My hangar is quite full too... I’m starting to list the gas planes. Since these pics I got the 90mm F-104, FW B-17, green version ME-262 and the 8s F-22 should be here for Christmas break . Since this picture I purchased large shelves so the planes aren’t stacked on top of each other.
                                      The last pic is current from my most important security cam. All the gas planes are broken down and stored in the garage.
                                        With my wife and I both building and flying, the hangar can get kind of full in a hurry:Silly:. About 1/2 of the fleet is giant scale, up to 1/3 scale and 147" wingspans(all electric). The birds and build rooms are on much of all three floors of a rather smallish house. I guess that there are worse addictions to haveLOLLOL. Wife and I are both USAF vets, so I guess it's a given to have a fascination with aircraft.
                                        • C17loadmaster
                                          • May 2018
                                          • 371
                                          • Auburn, CA
                                          I’m still in technically, stationed at Beale, waiting to be Med retired. I was rated 100% Permanent and totally disabled. You’re actually very correct about this being a “better” addiction. As soon as I quit drinking my hangar exploded haha. I’m going to make better storage racks soon. I like having everything in the same place. My big gas planes and quad EDF C-17 had to be mothballed in the basement right off the man cave
