Wow...that is a ton of weight!
To be quite honest, I'm not surprised it's balancing properly with the weights removed. My CG is just a bit forward of yours...not significantly. Is your battery identical to my Admiral 4000–and is it all the way forward touching the front of the battery bay? If it is, I would set up yours using my setup exactly and set that 3.78mm down neutral deflection on the elevators.
To put your mind at ease, back in the beginning for me in 2018, I remember looking at the old MRC promo video of Old Crow flown by Pilot Ryan. I looked specifically for his elevator deflection when he taxied in with flaps up—and it looked identically like where mine is now. I think it is just the way this model was designed.
I'd also recommend checking your flap alignments with the fuselage lines also; from what I could tell with your photo, your wing looks like its seated properly.
DB
DB
