Summary: How to set/adjust correct amount of "toe-in"?
I'm finally getting around to assembling my Freewing 1410mm P-51D "Old Crow". I've checked out all the servos with a servo tester and they all work just fine. I've disassembled and reassembled the landing gear adding loctite to all the metal-on-metal fasteners (especially the set screws). I've read through all the threads, both here and over on RCG, and want to set up the main gear with a small amount of toe-in. The method of adjustment I'm going to use is to (very slightly) bend the ductile main bar (trunion?) at its curved portion.
How does one measure the amount of toe in?
