1. It "Might" require Flap to Elevator compensation - this is usually resultant of CG and Elevator trim setting at normal flight - your results will vary
2. I do NOT employ flaps at take off
3. The piece that you have referred to earlier in this thread is meant as a removable battery tray.....I found the motor boxes supplied did NOT work for my motors to cowling fitment. I "think" this piece was intended to be a tray for these.....I use this piece as a battery tray support...just laid it on top of the existing tray for added support.
TwistedGrin
TwistedGrin
