New E-flite Fw-190A, 1.5m
  • SanExup
    paladin Are you using the 190s power system in another plane? I'm just curious why you didn't use the stock 100amp esc?
  • SanExup
    I love my FW and want to buy another one to play around with the power system. It would be my favorite plane, if I didn't have so many favorites, it's confusing to choose one as the ultimate favorite.
    I don't feel like the stock is too lacking. But ok, yes it would be better if it were faster but I'm satisfied enough with the stock performance. A second, faster one, would be fun too.😁
    I use the Robarts on the 190 and the Mustang, I'm very satisfied with the ground handling. I fly from dirt, rough dirt, filthy dirt, and grassy dirt. They're perfect...once they're modified to fit the wheels/rims.
    I love flying it back to back with the 1600 Flightline Spitfire. So fun!
  • paladin
    so, i love the way this plane fly's. i don't like the power plant they picked, i don't think it does the aircraft justice. so i did an engine-ectomy. i replaced the stock power with a turnagy NTM 5060-380 turning a ape 15x10x2 on8s. to follow is my path
    my initial thought was the stock motor was a 4258 and i was replacing with a 5060 so i was only 2mm longer. well, its clear they did not use the same ruler to measure both. the 5060 is 10mm longer.
    https://hobbyking.com/en_us/propdriv...ucts_analytics
    https://www.smallpartscnc.com/index....product_id=130
    https://www.horizonhobby.com/product.../EFL01371.html
    https://www.dolphinco.com.au/spinner...inum-2-blades/
    so i started by buying an extra x mount and elongating the holes to fit the 5060 and drilling out the center hole till it fit over the c ring on the back of the 5060. the 5060 covered part of the screw holes that mount the x mount to the firewall so i installed the screws in it before loc-tite-ing the x mount to the motor,
    removing the stock motor is accomplished by removing the four x mount to firewall screws. the esc is glued in so it pulls out the nose with a little elbow grease.
    the castle 100amp fit in the same spot, though i did have to lengthen the battery lead. the 5060 with the modified x mount screws right in place of the stock motor. when i thought the motors were 2mm delta i figured i could use the back plate of the stock spinner to give me the cooling fan, but 10mm delta put the fan mostly out side the cowl. so i went with just the dolphin spinner. i started with the 15x10x2 prop with a plan to go to the master airscrew 14x9x3.
    i put two flights on it today, the first it was flying in and out of the lifting fog which was ok because i wanted to test how well the firewall would hold up to a motor putting out 3 hp so i wanted to do a lot of fast throttle ups, then MPT's. second flight i did all the maneuvers i usually do. i did notice that when i retracted the wheels at full tilt they would bind as the wheels entered the wing, at half throttle they went up fine. this is because i put a robart wheel on the stock hub, it was one i had here and it was a 1/4 inch larger than everyone has been using so i'm not worried about it at this point. so now it does all the maneuvers like a fighter!
  • walkerm45
    Has this forum died a slow death?
  • t01ga
ID:	322556Click image for larger version
ID:	322549Click image for larger version
ID:	322550Click image for larger version
ID:	322551Click image for larger version
ID:	322552Click image for larger version
ID:	322553Click image for larger version
ID:	322554Click image for larger version
ID:	322555Click image for larger version
ID:	322557 86 flights as of yesterday. For me this is the most I have ever flown a plane in one season and it is not even over yet. I might hit 100 this year.
    Excellent! It could have been any of those things so I listed them all…
    many use the main trim all the way down and if you ever do then throttle cut at -130 works. But set up as I said makes the throws -100/0/100…
  • Chris curran
    Originally posted by Evan D View Post
    Center your trim and sub trim. Put travel at 100 and -100. Throttle cut at -100. Turn off throttle cut and calibrate the ESC.
    Thank you. That did it. The Throttle cut will shut off the motor even at half throttle. It works like it should.
  • Chris curran
    Originally posted by SanExup View Post
    Have you tried recalibrating your throttle?
    I did. It would still do this intermittently . So, I swapped out The Old ESC from my Crashed FW. It seems to be working better.
  • Chris curran
    Any chance that the trim on your throttle is not zeroed out?
    It was Zeroed out. However, at full zero the throttle would engage, so I had to add 25% up throttle trim for it to stop.
  • SanExup
  • SanExup
  • Chris curran
    Ok. I'm having a weird issue with my FW. The ESC will not slow down for the aircraft to make a safe landing. Now, Sometimes it will, and then it won't. The Throttle stays at ,just under. quarter throttle. Also the Throttle cut will not engage unless you toggle the switch twice. Now, During the ground pre flite, it's fine, Once it runs for a little bit, It acts up. Has anyone else had this issue, and is it the ESC?
  • Bajora
    BEAUTIFUL job on the custom schemes!
    Terry Dunn does a nice video review of the model for Model Aviation Magazine here:
    Originally posted by T- Elbert View Post
    Mostly finished with my repaint on my FW 190. Nowotny’s white 10 winter splinter
    TE, Superb work. Just a great job on your repaint. Best, LB
  • T- Elbert
    A Yak 9 would be cool too
    but La-7’s are bitchin
  • Vaseline
    Need a La 7 or MiG 3 to go with it. Nice work Travis
    T- Elbert I LOVE THIS, well done!
  • T- Elbert
    Thanks SanExup
  • SanExup
    T- Elbert So badass!
