    • 8814
    When experimenting with higher cell count, the first couple of flights should keep the gear down. You just never know if you have to do a smoking/flaming emergency dead stick landing, hoping that it doesn't happen right after take off and the BEC didn't burn up with the ESC. (Ask me how I know.)
    • billsplanevideos
      YouTube
      • Dec 2022
      • 15
      • Connecticut
      All great replies thanks. I have the CG right on the recommended 85mm with 6s 3300 Hrb battery. Just had to carve a little foam out for the battery leads at the nose to allow the battery to be forward enough. I’m heading to the field soon though I’m bringing my great planes extra 300 and yak130. I’ll save the bearcat experiment for another day, and try to remember to keep the gear down. I do have a 2 blade 12x8e apc laying around, would need a prop adapter to make it work.
        • 8814
        Unless you can't make it back to the runway and have to do a belly flop, then suck up the gear. :stuck_out_tongue_cl
          • 7383
          Always interesting to hear someone trying something new. I think I'd be inclined to run her up on the ground, but if you've run the numbers and they look good and have a one piece prop that works with the amperage of your ESC and of course , the motor is capable of handling 6s, I guess there is no reason why it wouldn't work. Just make sure everything is good, then blast away and let us know how it works. Should go like Rare Bear!!
          • billsplanevideos
            YouTube
            • Dec 2022
            • 15
            • Connecticut
            I also have an apc 13x6.5e that might be easier on the motor. The stock multi piece prop probably shouldn't be spun an additional 4000rpm over its intended use, at least not without some safety glasses, yikes . . .
              • 5401
              Caution using that, it has a small hub. All APC have a max rpm number. I suggest finding what it is for that prop on the APC web site.
              • billsplanevideos
                YouTube
                • Dec 2022
                • 15
                • Connecticut
                good point, thanks. according to apc e props are good for 150,000rpm / inch diameter. example 10x_ would be 15,000 max rpm.
                580kv x 25.2 = 14,616 rpm
                580kv x 25 v = 14,500 rpm
                580kv x 24 v = 13,920 rpm
                580kv x 22.8 = 13,224 rpm
                150,000 / 13 = 11,538 rpm
                150,000 / 12 = 12,500 rpm
                150,000 / 11 = 13,636 rpm
                11x11 make a wish
                I ordered this prop adapter, i'll give the 12x8e apc prop a try
                Buy FlightLine Motor Shaft Type A online at Motion RC. Order online with fast delivery.
                • TNES48
                  • Feb 2023
                  • 8
                  Hello group! I just recently received my Bearcat and saw the pin hinges. I’ve never installed these things and am probably overly intimidated by them. Principal seems straight forward enough but the pins go in one way, and if I mess up on possibly gluing it in place the hinge is no longer a hinge. Plus the instructions aren’t especially clear. Wondering if any of you could point me to some good info or pointers on things you may have done. And it seems like only the rudder? But could also be for ailerons? Thanks all.
                    • 7383
                    I personally have never used them in the years of flying my Bearcats. I've only had one incident where I could see an aileron starting to separate from the wing. I removed it and reapplied it with Foam-Tac and its been good ever since. You bring up a good point though because I don't recall anyone ever mentioning that they used those hinges.
                    BTW, I run bigger motors than stock as well, still no problem with control surfaces.
                    • TNES48
                      • Feb 2023
                      • 8
                      That’s good to know! I appreciate the feedback!
                      • Ks.jetflyer
                        • 131
                        Question for those that have installed the sport power package, did you have to add weight to the nose? After changing mine c.g. is about a 1/2" aft of recommended location. I flew it that way, flew just fine. Whe pulling back the power to land nose does not drop, plane just comes down flat. Made it a little harder to land. Think I must be getting close to tail heavy. Did make 2 succesful flights. Sure do like the increase in power and speed with the sport package.
                          • 7383
                          Interesting. What size battery are you using? I generally fly mine with 3600 4s's and occasionally a 4000 moved back about 1/4". I think if you feel your close to tail heavy, instead of adding weight, go a bit bigger battery. When I upgraded my power plant, I went to a 650 kv with an 85 amp ESC spinning an FMS 1400mm Corsair prop and had to add a tab of weight to the tail.
                          When I rebuilt Bearcat One, I used a 750kv with an 85A ESC spinning the stock four blade prop and didn't need any weight in the tail.
                          The point being that I've never run across one that was tail heavy, even running the stock system. I assume you cg'd it upside down with the gear extended?
                          Anyway, good luck with it and be cautious when adding weight. Dead weight is, well, dead, at least you get more flight time with a bigger battery.
                            • 7383
                            Pilot Ryan showing the correct CG position
                            • Ks.jetflyer
                              • 131
                              I'm using hrb 4s 4000 as far forward as possible. Balancing on the panel line just aft of his finger. Yep, upside down with gear extended.
                              • jetfool
                                • Nov 2022
                                • 1335
                                • Crawfordsville, Indiana
                                Grossman,
                                Love your bearcats. Wish FL would come out with a 1600mm, articulating LG with bells and whistles. I would pull out the ole credit card for one. Wishful thinking on my part probably.
                                Rex
                                • N1EDM
                                  • Jun 2021
                                  • 6
                                  • Brockton, MA
                                  Hi Everyone,
                                  I was considering getting one of these but my biggest concern was the seemingly long LG struts.
                                  Could someone please comment on how the plane handles on a grass runway with a few lumps in it? Our runway isn't a putting green but we are trying. Does the plane have a history of the gear folding because of the length?
                                  Also, what about assembly? Are there any major problems that one should look out for?
                                  I've narrowed the choices to the F-8F and the FMS Hawker Typhoon.
                                  Also, what is the average pilot using for a LiPo? What capacity?? I'm only going to go with a 4S, so I don't intend to overpower this. I just want to have some fun with a warbird.
                                  If you think of anything else that will be helpful, please let me know.
                                  Thanks a lot for any input that you folks might have,
                                  Bob
                                    • 7383
                                    Hi Bob, I've had three so far and two are still flying. I bought my first when they first came out, so I have a lot of 'experience' with them. The struts are plastic covered wire and you're correct in assuming that grass wouldn't be the best thing for them. The torque on the retract wing mount is pretty high due to the gear length and it's not unusual to see stress marks start to appear on the upper wing surface.
                                    To reinforce the wing, many have used packing tape on the top, cut to the shape of the wing panel. I went one up on them and used Flite Metal, which is thin aluminum with a sticky backing. I figured aluminum would be best for strength.
                                    Now, I've only done this on one Bearcat as she's something like 6 years old and was rebuilt a couple of seasons ago. One of the things that needed repair after her 'accident' was the wing because the strut ripped out from the wing, taking the wing section with it. I reattached it using Foam-Tac and then cut a pattern from the upper wing section. Cut the Flite Metal from the pattern and applied it over the wing and wrapped it over the leading edge to the landing gear bay. So far, it's worked great on our not-so-smooth paved runway. We have lumps and bumps and divets to the point that the tailwheel sounds like its sending morse code when taxiing. One thing I've found really good for giving the mains a little more cushion is to use Dave Brown tires as well.
                                    You can see where the piece was reglued in in this pic:
                                    Click image for larger version  Name:	20220215_102141.jpg Views:	0 Size:	81.8 KB ID:	373249
                                    Same with this side:
                                    Click image for larger version  Name:	20220215_102230.jpg Views:	0 Size:	72.4 KB ID:	373250
                                    And after applying the Flite Metal and repainting:
                                    Click image for larger version  Name:	20220221_102253.jpg Views:	0 Size:	92.4 KB ID:	373251
                                    Hope this helps
                                      • 7383
                                      BTW, I use 3600 - 4000 4s in mine, flies great even with the stock power system.
                                      • N1EDM
                                        • Jun 2021
                                        • 6
                                        • Brockton, MA
                                        Thanks a lot for taking the time to write all of that info, Grossman. It gives me something to think about.
                                        We just moved to a new field and it'll take a few years to get the new grass runway to be where we really want it. It's pretty rough now.
                                        I'll keep all of what you said in mind. Thanks a lot for taking the time and effort.
                                        Bob
                                          • 7383
                                          No problem Bob, I love that airplane!
