You'll be pleased!!
With my Bearcat, I used the same 650kv power system with the same 85A ESC and installed the 1400 mm FMS Corsair prop in front, incredible airplane, literally unlimited vertical.
Gman,
I went with the FL recommended 3648-880kv w/12x6 2-Blade (scale blasphemy I know I'll paint the wing tips yellow). Two reasons:
1. I read on another forum that the 14x8 prop is tough to fly from grass. I did some measurements. With the plane near horizontal there is only 1.375 inches from the prop tip to the ground. Our field is cut to .75" and gets to 1.3" between cuts. Just a little error on takeoff/landing and I'd be cutting grass i.e probable hard noseover.
2. $47 versus over $100.
Bernie
Gman,
Bernie
Absolutely.
