Pretty nice Ryan. Can you elaborate on your technique? I like the silver paint splotches.
Try this site for cool photos 17bg-b26marauders - Category:Martin B-26 Marauder - Wikimedia CommonsDon't just fly--WREAK HAVOC!!!
I also have been using water based latex paint from Home Depot or Lowes. Since the paint is latex, it flexes with the foam and does not crack. I airbrush it on and use brushes for touch ups. The results have been great. Check out RCG for my pictures of the FW F-14 in Iranian Air Force colors this will give you an idea of what is possible. On hot summer days I thin it down with water. On cooler days I thin it down with el-cheepo rubbing alcohol.
Originally posted by quitcherbitchen View PostPretty nice Ryan. Can you elaborate on your technique? I like the silver paint splotches.
Originally posted by quitcherbitchen View PostTry this site for cool photos 17bg-b26marauders - Category:Martin B-26 Marauder - Wikimedia Commons
Originally posted by MOFO1 View PostI also have been using water based latex paint from Home Depot or Lowes. Since the paint is latex, it flexes with the foam and does not crack. I airbrush it on and use brushes for touch ups. The results have been great. Check out RCG for my pictures of the FW F-14 in Iranian Air Force colors this will give you an idea of what is possible. On hot summer days I thin it down with water. On cooler days I thin it down with el-cheepo rubbing alcohol.Still Learning:D
Pauly yes I use rubbing alcohol or water to thin down the latex paint. Home Depot will match a paint sample for $4.00 +- in a 8oz sample.I use water when the temp., is above 100 degrees. In the colder months I go with the alcohol. This helps control the evaporation rate. I have had great results with a el-cheepo airbrush from Harbor Tools. I thin the paint to the consistency of milk. Experiment with your airbrush to find what it likes. Check out my Freewing F-14 on RCG with Iranian desert paint scheme, all done freehand with latex paint.
Got my notice too...boo-ya. A few shakedown flights and im going with the metalized tape(thanks alpha)I assume i can print off tired irons nose background (thank you for the leg work). Wingnut...wingnut where are you? Looking forward to the first 3d file user reports. Wingnut...if you design a scale bomb bay you will make my christmas list. Now to order a couple adam bombs.Still flying P.15, avanti(#2), mig 21, yak 130 70mm(#2), f35, f9f panther, a10 64mm, F8 crusader/ PA ultimate amr /HK skipper, durafly dh vampire, p 51,spit mk24, corsair, flybeam/ BH f86 50mm, deltawing 50mm/ HH su 26 mm,umx pitts,umx sbach, blade nano cp s,blade 450x, inductrix 200, inductrix pro, umx yak 54,umx f27 fpv/ electrifly 4s L39/ flyzone beaver/ volantix asw 28, /dynam B26
Originally posted by WW2 Wing Nut View PostAnd Finally the Cockpit. With pilot and Co-Pilot included. Print with or without Pilots: https://grabcad.com/library/dynam-b-26-cockpit-1
Oh and to those wondering, the dimensions are good. I've already spoken with Alpha on the New Dynam B-26 Kit in personal messages and emails. And yes I know the pilots suck but they are the best I can do. I don't do pilots but there you go, lol. The cockpit kit is designed so as to not get in the way of the battery compartment. So the only thing you're modifying is the battery hatch, not the space under it.
