downwindleg/Aros ESM 50cc F4U Corsair Build (Electric Conversion)
    I thought it looked a little too red. Trying to do two part mixes in real small batches makes getting the % ratio right critical. I've found it's best to make a larger batch and toss the extra, than have a weak mix especially with critical structural material. Bondo is event tougher because it's not a 50/50 mix.
ID:	98207Yeah I read the microscopic directions wrong. I thought it was 1:1 but not at all. 1" circle of putty to 1" line of red. Worked like a charm.
        First hit of filler primer after the first round of bondo and sanding. Shows me where all the imperfections are. Not too bad for a first pass. Have some work to do but might only need one more round of bondo, sanding and priming and that could possibly do it before painting when the time comes.
          DANG!!!! That looks gooooooood
          • RRHandy
            Instructor Pilot
            • 898
            • Lilburn GA
            Looking good
            AMA 424553
              Thanks fellas!
              • Capt. Crunch
                Balsa flies better
                • Nov 2014
                • 388
                • Iowa
                That looks awesome!
                  Thanks again! I think the end results will look pretty good. Unfortunately it won't have the recessed depth the full scale coolers have (they sit back a bit from the LE) so museum scale is out, but semi-museum scale is the goal which is still achievable. The full depth cockpit Plastic_Aviator has been working on is incredible and I can't wait to get it and install. That cockpit will really be the catalyst for the rest of the build. The 1:5 Pappy will set it off. I may even have to shoot for the swivel head that turns in conjunction with the rudder. So the question then becomes, once she's complete, how on earth will I have the nerve to maiden her???
                  LOL
                    LOL
                    LOLI know what you mean. There seems to be a trend with me that as the time/money investment on details curve sweeps upward, there is a coresponding declining curve in the number of flights a bird sees, especially on giant scale birds in particular.
                    • downwindleg
                      • 1279
                      • Friday Harbor, Washington
                      Awesome job Todd, yeah the "emotional torque" ratio can be pretty steep on what will be a beautiful model. If you can just get past that first flight and trim out you'll be sittin' pretty!:Cool: This will be the part where I'm glad it's you, not me. But I'll be standing right there sweating it out with you on that day. Brad
                        Thanks Brad! I look forward to the day (sort of). LOL
                        Finished the rounds of bondo and sanding and priming. Coolers are pretty much ready for paint when the time comes. I have a little tiny detail ridge cleanup work but that's about it. Pretty happy with the results!
                        Click image for larger version  Name:	coolers26.jpg Views:	1 Size:	177.7 KB ID:	98449
                        Click image for larger version  Name:	coolers25.jpg Views:	1 Size:	180.8 KB ID:	98450
                        Click image for larger version  Name:	coolers24.jpg Views:	1 Size:	158.3 KB ID:	98451
                          Sure beats the stock coolers!
                          To:
                          • RRHandy
                            Instructor Pilot
                            • 898
                            • Lilburn GA
                            Sweet.
                            AMA 424553
                            • Dewey H Lee
                              WARBIRD JUNKIE
                              • Apr 2015
                              • 919
                              • Fayetteville NC. US
                              Theres only one problem that i can see.:Cool: its not mine:). Looking Good.
                              Dewey l
                                LOL thanks!
                                Next up is cutting out the cockpit area to get ready for the full depth cockpit kit. Man these scale details is what really revs my engine!
                                • RRHandy
                                  Instructor Pilot
                                  • 898
                                  • Lilburn GA
                                  I agree with you on the scale detail bug.
                                  AMA 424553
                                  • Dewey H Lee
                                    WARBIRD JUNKIE
                                    • Apr 2015
                                    • 919
                                    Getter done. I woll have one some day.:Straight-Face: :). But now i can come back for ideas. Looklng great. Think it still needs a radial gasser though;). Soooo cool.
                                    Dewey l
                                    • downwindleg
                                      • 1279
                                      Definitely a vast improvement over the stock setup. I see the little ridge you are referring to on the port wing inlet. One more pass and you will have it. Moooooost exxxxxxxcellent!! Brad
                                        I am all for setting up a Aros GoFundMe page for a Moki Radial! LOL LOL
                                        • Dewey H Lee
                                          WARBIRD JUNKIE
                                          • Apr 2015
                                          • 919
                                          Its all i can do to try and save for the dream your living.;) But i would happily lobby FOR Donations for you.:).
                                          Dewey l
