I had a slight mishap flying my new Corsair today. Botched a landing in windy conditions, broke one of the steel pins that connect the servo to the landing gear strut. Looking at it closely, it looks to me that you can’’t Just replace the pin like on many other planes, but have to buy a whole new electronic retract. Do I understand that correctly?? I didn’t see a part offering on the website for that broken pin.
thanks
davegee
Originally posted by davegee View PostI had a slight mishap flying my new Corsair today. Botched a landing in windy conditions, broke one of the steel pins that connect the servo to the landing gear strut. Looking at it closely, it looks to me that you can’’t Just replace the pin like on many other planes, but have to buy a whole new electronic retract. Do I understand that correctly?? I didn’t see a part offering on the website for that broken pin.
thanks
davegee
thanks
davegee
Ken
Originally posted by Ken Smith View Post
I had to replace my pin in my P-40, I had to buy a 5/64” cheap drill bit to find the right size. A combination of press fit and CA. Had to remove the servo to get a good working space.
Ken
thanks
davegee
The added problem with the Corsair is that the main gear is a rotating piece where a rotation pin has to be embedded into the main pin. This adds a level of complication that most people won't mess with. With my FMS 1700mm Corsair, I just bought a couple of spare retracts.
idk, IF THESE ARE THE SAME, BUT:
At Motion RC we carry the largest selection of electric and gas powered radio control (RC) planes, boats, buggies, cars, helicopters, tanks, trucks, and much more. We also offer a huge selection of lipo batteries, chargers, ESCs, gas engines, motors, radios, and servos. Shop our lowest prices with free shipping.
I ASSUME YOU HAVE TO PULL THE TILER arm to remove the rotating pin. I would be very interested to see if the rotating pin is metric or English. metric and your done without a lath. English I would be tempted to replace it with music wire, in fact replace both with music wire. i'm sure they are untampered as purchased. which means they won't take a lot to bend.
might be worth it to talk to these guys about making both pins in a kit:
joePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
One thing I found when replacing my retracts (and is the case on most) is the way the servo wire is channeled would be next to impossible to switch out a new retract and run the wires along the same nice hidden - but tiny - channels. So I ended up having to re-route the wires unceremoniously through the wheel bay. Not a huge deal since with some tape and paint it won't be too bad but what I would love is if the connector is close to the retract itself so all you have to do is unplug the old retract by the base and plug in the new retract at the base and simply screw it down. Using the same servo lead as the original. Would make switching out retracts SO much easier.My YouTube RC videos:
Originally posted by paladin View Postidk, IF THESE ARE THE SAME, BUT:
https://www.motionrc.com/products/fm...1700mm-corsair
http://smallpartscnc.com/index.php?r...product_id=129
joe
Pulling pins and lathing this and that, to me, is too much hassle when you can wait just a bit and get a whole new retract.
joe
Originally posted by Ken Smith View PostRead the above and learned a good deal, thanks, great thread, great info. While on landing gear, what is the size of the set screw on the main landing gear sturt? I think it is 2mm. The stock ones are soft and strip out, want to order some extras or may have them in stock.
Ken
Originally posted by xviper View PostIf you're talking about that metal pin that goes into the strut on one end and the other end going into the trunion? (I think it's called that. It's the thing that is rotated by the worm drive to deploy and retract the gear.) If that's the case, I've seen these sold my Motion for planes like the A-10, which was known for breaking. I bought a couple in preparation for the next break. They brought one out made of stronger stuff. You can also find this pin for other planes (like the Avanti S maybe). Just measure the diameter you want and compare to the ones being offered as replacement on other planes. You may need to cut new flats and perhaps shorten the pin a bit to work.
I don't suppose that they will fix this issue. I'll buy the full retract replacements for $16 each, and hope they don't break as often. It is also a pain in the drain to pull the old retract wire out of the wing, and then thread it back in again to the connecting bus. I see that Motion is totally backordered on these replacement parts, so I suspect many others are now experiencing the same problems that I am talking about. My point is if they had just engineered it better, this brain damage wouldn't have been necessary.
Before I got sidetracked, I was going to write this ...I, like the rest of us, really appreciate this Corsair. The fact that there are almost to 2000 posts is a testament to that. It also took that many posts to discover a weak point on this aircraft. THE LANDING GEAR “PIN.” The last airplane that I remember that generated this much of a “buzz”was the Starmax/HSD Skyraider. It to had 90° rotating re-tracks. And, as I well remember, a problem with the LANDING GEAR “PIN.” As Yogi Berra once said, “Deja’ vu all over again.”
SmallParts CNC might be a solution.
The pins for the A10 or the Avanti might be a solution.
MOTION RC SHOULD COME UP WITH A SOLUTION...SHOUlD BE THE SOLUTION! FOR AN INVESTMENT OF $459.00, A LOUSY $3.00 “PIN” SHOULD NOT BE THE CAUSE FOR GROUNDING THIS PLANE :Whew:DUE TO POOR ENGINEERING (AS EXPRESSED IN PRIOR POSTS). MOTION, YOU ARE TOO GOOD TO LET THIS SLIDE.
AT LEAST STOCK REPLACEMENT PINS!
JUST MY HUMBLE OPINION
theoldALFER
Originally posted by davegee View PostIt is also a pain in the drain to pull the old retract wire out of the wing, and then thread it back in again to the connecting bus.
