Anyone Into Unlimited Hydros?
  • Ron1950
    Retired ATC
    • Oct 2015
    • 887
    • brandon ms
    vintage hydro.. real one and 1/8 scale
    • Ron1950
      Retired ATC
      • Oct 2015
      • 887
      • brandon ms
      a few more 1/8 scale hydros Click image for larger version  Name:	bud 44.jpg Views:	0 Size:	140.2 KB ID:	402995 Click image for larger version  Name:	IMG_0315.jpg Views:	0 Size:	157.6 KB ID:	402996 Click image for larger version  Name:	IMG_0167 (1).jpg Views:	0 Size:	98.9 KB ID:	402997
      • f4u ausie
        • 1232
        • Melbourne
        Some very niceboats there
          • 8211
          Nice boats!
          • Clugh
            Current F3A world champion American motor winder.
            • Sep 2023
            • 5212
            • Research Triangle Park North Carolina
            Originally posted by Aros
            Yep we reversed the throttle channel as well. Nothing has worked yet. Hopefully this new ESC works!
            Hi Aros,
            Something is not right in the setup. There's no reason the ZTW esc should not be working. You dont have any long motor mount screws or anything touching the windings or anything. Are you programming with a box or the transmitter? and is the transmitter setup for the full range of throttle?
            Thank you,
            Hubert
              • 8211
              Everything seems to be connected just fine but I don't see an option to increase the throttle range on the transmitter. There's reverse, rates, end points, etc...
                • 2693
                Sweet Fleet!!
                • Clugh
                  • Sep 2023
                  • 5212
                  Is your dual rate at 100% is your brake rate at 100% is your servo reversed on the throttle channel? Are you positive you don't have a cold solder joint or something. Have you told who you purchased the combo from that you are having an issue? Id do this before I spend more money because buying the castle doesn't make what you already paid for work. If you haven't done anything but connected as instructed there's no reason for you to eat it. Just my opinion. I truly believe something is not configured correctly. The esc should be able to run that motor with no issue.
                  Hubert
                    • 8211
                    We had the end points and rates to 125% and everything in between. I already have the new ESC on the way and giving the Seal to Brian for him to noodle with. If it turns out it was a missed function/feature and the new one works great, I'll just sell it.
                    • Clugh
                      • Sep 2023
                      • 5212
                      Ron1950
                      Is this a Phil Thomas hull? What are you powering the boats with?
                      Thanks,
                      Hubert
                      • Ron1950
                        Retired ATC
                        • Oct 2015
                        • 887
                        • brandon ms
                        sold it a few years ago but it probably had a 1800kv motor on 4 s
                        • Clugh
                          • Sep 2023
                          • 5212
                          Aros I do have a question about the futaba rx settings on your throttle. Is it set up as an analog, digital, or SR mode? Have you checked that?
                          TIA,
                          Hubert
                            • 8211
                            Hmm, great question! I'll have to check on that and get back to you.
                            • Clugh
                              • Sep 2023
                              • 5212
                              Oh okay thought that was an 1/8th scale. Im assuming it was a 4s or LSH boat at 1800Kv
                              Regards
                              Hubert
                              • Clugh
                                • Sep 2023
                                • 5212
                                Also just out of curiosity what servos are you running with the radio? It has nothing to do with the problem I'm just being nozy. LOL!!!
                                TIA
                                Hubert
                                  • 8211
                                  I never did find out what mode the radio is set for? I didn’t see any settings in the menu on that. Here’s the servo:
                                  https://www.promodeler.com/DS555BLHV
                                  • Clugh
                                    • Sep 2023
                                    • 5212
                                    Ok . But i'm talking about the channel the ESC is on. channel 2 I suppose. Hit the home button then User Menu is bottom right corner of the screen then goto page 2 and select receiver. You should be able to change it there from Digital, Analog, SR, and UR modes.
                                    You paid over 100 dollars for that servo? WOW....
                                      • 8211
                                      I see TFH-N / Normal.
                                      The servo wasn’t that expensive as I didn’t buy it from that website. It’s now discontinued but I heard it’s a good one.
                                        • 8211
                                        So THIS happened.
                                        I was trying to figure out what could possibly be wrong with my setup. I had a well known man in the RC hydro community solder me a setup that should have worked. He preferred an 8mm bullet setup (I prefer connectors that plug easily together which I am used to in model aircraft like EC5, XT90 etc). I didn’t like the multiple positive and negative wires all over the place be he insisted that was normal for hydros.
                                        So I decided in my infinite wisdom to try again on my own and plug everything together and mess with the radio settings.
                                        I noticed there were two leads coming out of the ESC. One for throttle and the other for SBUS. Since I am a Spektrum guy, I didn’t know much about SBUS other than I heard you can program everything with just that lead into the RX.
                                        I plugged the SBUS lead into the SBUS port and thought that would be the difference.
                                        Whoops.
                                        When I went to plug the final cables together for series I heard a massive POP!! Followed by this giant bright circle of light the size of a volleyball so bright it looked like a welder’s arc.
                                        I thought it was my last moment on earth. My fiance heard it all the way upstairs and came running. I was in a momentary state of shock. My fingers were burned and blackened.
                                        It was a scary and humbling experience.
                                        So I have ordered new 4S 6000 batts, and the new ESC of course. I have someone who is going to solder EC8s all the way around. No more stand alone wires. Every main connection will be a EC8 connector so I literally can’t screw up the wiring.
                                        I had to discard one brand new 4S 6000 as the explosion literally bore holes into it. The other one seems to be fine. I checked the cells and there are no irregularities.
                                        A scary experience to be sure. I will never again put myself in a situation where I am unsure of an electrical setup. I am lucky. It could have been much much worse of an outcome.
                                        Here’s some photos.
                                        • Clugh
                                          • Sep 2023
                                          • 5212
                                          So THIS happened.
                                          Whoops.
                                          Here’s some photos.
                                          Man! am I glad you are okay. Lipos are pretty serious powerplants a def not the most stable. We all should really be using charging bags and probably out side somewhere away from flammables. There is alot of juice in the batteries we use for the FE boats. It honestly sounds like a reverse polarity which can happen. I feel horrible about this because you had left it alone. I was the one insisted we try to get the seal going.
                                          I'm sorry Todd I feel like its all my fault. The connector advice your friend is valid, EC5 and XTC90 really are on the small side considering a q hydro can pull and average of around 180 amperes around an oval. It also about which connector has the lower voltage drop across it. Amass 7mm or the Castle 6.5 or 8mm. You have to be careful with the bulk connectors from china and usa distributors or china because the economic side of a cheap connector probably uses copper cladded aluminum which will have a higher resistance than pure copper every time. I set my male & female plugs up in such a way that reverse polarity has to be intentional I always make the positive hooded female and the male negative let me show you about the EC8 which is good but the AMASS is better.
                                          Sincerely
                                          Hubert
