Hobby Eagle A3L Gyro
  • rcaviator
    • Nov 2014
    • 14
    Here is how you can put your gyro on a 2 position switch so it is just ON or OFF....no 3D. I did not want to use a 3 position switch for fear that I might accidentally flip to the 3D position, and that would not be good while flying my F-16 90mm.
    Assign a 2-way switch on your radio to the mode channel, and set the end-point (on Spectrum that is "Travel" under servo setup) of the channel to left 100%, right 0%. Now you will have ON or OFF only.
    Also, as another note, because the AL3 is only a gyro, and not also a stabilizer, you can face the pins either toward the the front or rear of the plane. :)
    • 7437
    RE: Hobby Eagle A3L Gyro
    thanks for the tip.  I tried to do that on my DX6i for the Pandoras, but I'd have to sacrifice flaps with a 6 channel setup.  I did try to hook it up, but it would only go off and 3D.  I see what you're saying though,  I probably have the settings at left 0% and right 100%, so by reversing that I would have got the sport setting and not the 3d, interesting............
    • ryramZ
      Pilot Ryan
      • Dec 2012
      • 814
      This will make more sense after you watch the video. It's called "A3L Gyro Setup with DX6i/ How to make a 3 position switch"
      This is a portion of a follow up email I sent the guys at customer service.
      "Guys,
      Here's the follow up with TWO position switch only. This being beneficial mainly to A3L customers who only want access to Normal mode and off.
      No mixing needed whatsoever if two position switch is desired. All that is needed to be done are my first two radio steps. Step one in Travel Adjustment screen nothing changes, same as before the default blank channel values are correct.[Flap switch 1 position Down arrow 100, Flap switch 0 positionUp arrow 100] The only change is in the Flap screen step two. Once in Flaps screen simply move the Land numerical value from my stated setting of Down arrow 100% to Land 0. "
      • boomer108
        Chief Boom
        • Apr 2014
        • 868
        • Chicago IL.
        I have the A3L and I was wondering if the gyro has to be mounted on the center line of the aircraft? I have mine mounted on the side wall of my Sensei pins facing aft. Just curios if that's ok? I have not seen that addressed in the manual or Motions video. If anyone knows I would appreciate the input.
        Roy B.
          • 7437
          I'm pretty sure it is, but check out Pilot Ryans video on the A6 gyro.
          • ryramZ
            Pilot Ryan
            • Dec 2012
            • 814
            Roy B.
            That should be fine. It's not ideal as center is preferred. Try it at altitude.
            Best wishes
            Ryan
            • boomer108
              Chief Boom
              • Apr 2014
              • 868
              • Chicago IL.
              Roy B.
              Best wishes
              Ryan
              Thanks Ryan,
                   The reason I asked was I tried flying with it mounted on the side wall and it didn't seem to handle well. So I will devise a way to mount it on the center line flat. Thanks again Ryan.
              Roy B.
              • GABZEEK143
                • May 2015
                I installed the HE A3L gyro on my Pandora using the Spektrum DX6 as my TX. When everything was setup, instead of getting a blue color light when it is on normal mode (gyro mode) I get a red light. All the servos are working on the right direction when I moved the plane. it is set to 0 on normal mode and 1 turns off the gyro. I set switch 2 off also cause I don't use 3D. I followed all the instruction on videos but still get a red light instead of blue.
                Gabzeek
                • rcaviator
                  • Nov 2014
                  • 14
                  Hmmmm...... :huh: maybe you should try to do it over again. Check that all the "mode" settings are correct. Did you set the travel adjustments as indicated in the first post in this thread?
                  If you try again to no avail, call the support # and talk with a tech.
                  Good luck.
                    • 7437
                    I had that as well, now I'm using a dx8 with a three position switch.  Position 0 is red position1 is off and position2 is blue.  Now, since you are dealing with a two position switch, if I remember right, someone had gone into the values of the switch and reversed them, for instance, it the value of position 1 is 100% and you're getting red, then change it to -100% and it will give you blue.  Don't quote me on this as its been a while since I read it, but there was a thread on using the dx6i for this very thing.  Check out the list of Ryan's videos on You Tube, you might find it there.
                    https://www.youtube.com/watch?v=gKObxglL8lM
                    • rcaviator
                      • Nov 2014
                      • 14
                      That is correct!
                      • Cudaguy
                        • 27
                        Good luck.
                        I had the same thing happen. Had the A3L gyro blinking red. I had the gyro hooked up wrong. The lettered pins (AIL ELEV RUDD) should receive the output from the receiver using the supplied male to male leads. The "output" labeled pins should have your planes servos hooked up there. Once I reversed mine it works fine now.
                          • 7437
                          yeah, and a simple way to remember which is which:
                          think of 'AERO'
                          A (ailerons) is output one
                          E (elevator) is output two
                          R (rudder) is output three
                          • Axle209
                            • Jun 2015
                            Is there a way to setup gyro when you have both Ailerons connected into separate channels, not on a Y harness. As I have FMS Zero ailerons on separate channels.
                            • Pheonix
                              • Aug 2013
                              • 670
                              I do not know about the A3L; however, I use an Eagle Tree when I need this type connection. Perhaps the guys a Motion can help you with this one. Sorry.
                              • ryramZ
                                Pilot Ryan
                                • Dec 2012
                                • 814
                                There is only one port for the aileron. They must be on a y connector.
                                Ryan
                                  • 7437
                                  I have noticed that when using aileron/rudder mixing the rudder throw changes quite a bit when you turn the gyro on, any way around this?
                                  • ryramZ
                                    Pilot Ryan
                                    • Dec 2012
                                    • 814
                                    When you read page 1 of the manual you'll see the paragraph that talks about throws seeming maybe excessive on the ground, but how not to worry.
                                    Also the manual states not to utilize v tail or delta wing MIXES.
                                    I would want to make sure that it's ok to have an aileron to rudder mix prior to flying. Wayne at CS seems to know these very well.
                                    • Axle209
                                      • Jun 2015
                                      Thanks for input on Y connection Guys.
                                      • Cudaguy
                                        • 27
                                        My planes do the same thing but in the air no prob. I have two a/c with these gyros and love em.
