Here is how you can put your gyro on a 2 position switch so it is just ON or OFF....no 3D. I did not want to use a 3 position switch for fear that I might accidentally flip to the 3D position, and that would not be good while flying my F-16 90mm.
Assign a 2-way switch on your radio to the mode channel, and set the end-point (on Spectrum that is "Travel" under servo setup) of the channel to left 100%, right 0%. Now you will have ON or OFF only.
Also, as another note, because the AL3 is only a gyro, and not also a stabilizer, you can face the pins either toward the the front or rear of the plane. :)
