Minwax Polycrylic
  • 8416w
    • Jun 2015
    • 24
    • Mebane NC
    RE: Minwax Polycrylic
    Thank you for the information everyone!
    Is it ok to apply the poly to plastic parts?
    • Pheonix
      • Aug 2013
      • 670
      Sure. I do so all the time.
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        It adheres very well to plastic, however, I use 600 grit wet/dry paper first, just to be on the safe side. Doc
        • 8416w
          • Jun 2015
          • 24
          • Mebane NC
          Thank you for your help.
          • Hippie 64
            • Feb 2014
            • 1049
            • Gaffney , S.C.
            Originally posted by Pheonix
            Originally posted by Hippie 64
            First off Welcome to the Forum 8416W !!
            Some of the oil based have chemicals that will damage the foam . Some instant and some slowly . Use a water based . It will not hurt the foam . The  best options we have found  are , the Minwax , the Hobby Coat , and the brand that Dr Mike has mentioned quite a bit . He has found it and speaks very highly of it sorry I can't recall the name but if you look thru his post you will see it .
            I personally have used the Hobby Coat and the Minwax . Both work well . I break the Minwax down with a little water and use thru a airbrush . The Hobby Coat I just brushed on with a foam brush .
            All three work really well and my past experience now tells me to always do it . It does protect the finish . I do mine before I assemble the plane .
            Hope this helps .
            Bryan
            Do you an problems with your needle clogging when air brushing with Minwax?  When you say a little water, what ratio do you use?  Thanks.
            Just a little clog problem but not always . I run 2/3 wax to 1/3 water . You can even go half if you want to . Works good for me . Hobby Coat is too thick also and I've not tried cutting it down yet
            Bryan
            But Crashing is Landing
            • Pheonix
              • Aug 2013
              • 670
              Hope this helps .
              Bryan
              Bryan
              Thanks so much!
              • doctormike
                • Oct 2013
                • 1260
                • Santa Fe NM
                Hope this helps .
                Bryan
                Bryan
                Thanks so much!
                 It's Varathane waterbased poly. Much better quality than Minwax. I've only found it at Home Depot. Doc
                • Hippie 64
                  • Feb 2014
                  • 1049
                  • Gaffney , S.C.
                  Hey Doc I ordered from Amazon of all places. I don't have a Home Depot close by . Are you cutting it down ? Spraying or brushing?
                  Bryan
                  • doctormike
                    • Oct 2013
                    • 1260
                    • Santa Fe NM
                    I thin it just a little with distilled water. I use a foam brush. It looks like a spray job. It adheres very well to spray paint, which I use now, since the new foam doesn't melt. A tip... pour your Varathane poly into a plastic container. All metal cans rust with water based acrylics. I've had a lot of paint ruined because of this. Have fun! Doc
                      • 7333
                      Personally, I've never diluted Minwax as she shoots on straight easily through my brush.  Its a great glazing medium as well if you want to make the plane look old or whatever it will mix the color down to nothing. You can layer up you paint that way and it works great.  I'm going to try the Varathane as Doc recommends just as soon as I can picks some up
                      • Wisconsin John
                        1crazyoldflyer
                        • Dec 2015
                        • 116
                        • Redgranite
                        The polycrylic worked great for me on my FMS P-51 Red Tail (2 coats). But let me warn you, you better double check your CG. I had to add 4 oz to the nose to balance out. Always check your CG after painting or clear coating your planes. Hope this helps.
                        Wisconsin John
                        • doctormike
                          • Oct 2013
                          • 1260
                          • Santa Fe NM
                          Hi, Gman. Adding acrylic paint to the clearcoat sounds like a great idea for antiqueing or whatever. I'm going to experiment with the idea. Doc
                            • 7333
                            Hey Doc, I like the Varathane!  I see what you mean and I love the idea that it has a UV protectant in it as well.  Yeah, I tried mixing in paint when I did the P51B, its great for tying the whole paint scheme together as well, so the plane looks like its been sun bleached rather than some parts look new and some look old.  Unless that's what your going for, in that case, block out the new parts and spray the rest.  Lots of fun.
                            The new P40B is going under the gun pretty soon as the planes that the Flying Tigers flew would have been hauled off to the nearest scrap heap if they'd have been in the States.  Imagine flying with a magneto zapping you the whole time!!!
                            It happened.
                            • Flygirl
                              • 969
                              • Glen Burnie, Maryland USA
                              GMan, What do you mean when you say it looks sun bleached?
                              Lauren
                                • 7333
                                Faded by the sun.  Like a car that never gets waxed out here in the desert, eventually all the luster is lost and the paint tends to either look like its been whitened, or in the case of green, the yellow starts to dominate (Yellow and blue mixed make green)
                                To start, I blackened the edges of the panel lines on Shangrila with a thinned out black paint, then used the paint I had scanned to match the color on the plane (good ol' Ace Hardware), thinned out and changed slightly, either mixed with a little white or a pinch of yellow and thinned out.  The top of the engine cowling was just white, then I blocked out half of it with a piece of cardboard and sprayed the other half again to change the color slightly to give the effect of a panel line.  Same with the bottom, only I used blue to vary the color and watered down black for the stains.  Gun smoke was the same black, just layered where I wanted it thicker.  One thing about the gun smoke lines, make sure they're running straight back, otherwise they look pretty funky.
                                  Reviving a slightly old thread. I have been using Minwax Polycrylic recently on some planes with great success. I was in Home Depot the other day looking for a flat finish, but all they have is Gloss, Semi-Gloss and Satin. I've used Satin, but it still leaves something of a shine. What are you guys using to dull the finish? Do I have to go to the LHS and buy Testors dullcoat?
                                  Also, based on Doc Mike's comments, next time I'll be buying Varathane brand.
                                  Here's some pics of my Phase 3 YF-16 that got 4 coats of Gloss. That thing really shined!
                                  • doctormike
                                    • Oct 2013
                                    • 1260
                                    • Santa Fe NM
                                    Varathane!!! So much better quality! I threw my Polycrylic away! Doc
                                      • 7333
                                      Well, I didn't go quite as far as Doc, but he's right Varathane is better. Out door version with UV protectant. I've posted this several times , I know, but the results speak for themselves. I'm sure you can get a dull coat, or at least a satin. I ended up blending a satin with my final coat of Acrylic paint, which is usually flat anyway, blend a small amount of paint and it creates a glaze over the areas painted, a great way to 'fade' your paint. A glaze is like the effect you get by laying a colored plastic over something, but more subtle, based on how much paint you mix into it.
                                      Shangrila is about as flat as you'd want to get.
                                      • boomer108
                                        Chief Boom
                                        • Apr 2014
                                        • 867
                                        • Chicago IL.
                                        I also followed Doc's advice and used Varathane on my new Pandora. Much better product,looks great and UV protection, can't be beat!
                                        • olwarbirds
                                          • Nov 2015
                                          • 139
                                          • NC
                                          On the EDF's if you do all of the air intake and exhaust areas with z-poxy or minwax, after a light sanding. You will gain a definite increase in performance....I will be coating my new birds with the Varathane... DJ
                                          FMS: PT-17, Waco, B-25, P-40, P-47, J-3
                                          DF: P-51D, Spitfire, geebee, Skyraider
                                          Dynam: Grand Cruiser, A-10
                                          J-pwr P-38, FZ Beaver + too many more
