    Well that clears that up...………. I got those pics from a guy who knows a guy in the Ukraine.
      I am sure that blowing between the "dorms" with the throttles stuffed way past the detents is a sure way to get a date!!!!
        Also, just FYI OGUR and VD-PATM are common knowledge now....
          • 4817
          ...who had heard from a gal, that presumed she had heard another guy that said he was pretty certain as he understood it that I had said to the Oscar Sierra (opposite sex) in question who later assumed I meant..."oh really, you've never sat in a cockpit? Well now..."
            • 4817
            Jerry, . You've made my day, some more. Steve
            • Wobisch
              • 83
              • Merenschwand, Switzerland
              I'm very excited because Warlords Phantom No. 201 is currently being under construction. In spring we will be able to do a tandem patrol flight showing #200 and #201. Click image for larger version
              • e4dragongunner
                Living the dream!
                • 876
                • Arlington Heights Il.
                Really COOL! Love the rivets!
                • MOFO1
                  • 56
ID:	225594Click image for larger version
ID:	225595Click image for larger version
ID:	225596 Great way to start the New Year(Nowruz). Several hours of flying the F-4 and Mig 21. Love the way the desert paint scheme stands out against the sky.
                    Elbee commented
                    Editing a comment
                    M1, Great looking bird. Congrats. Best, LB
                • Corsair nut
                  Jets...warbirds...mmm hmmm
                  • 218
                  • Tehachapi ca
                  Seeing all these awesome phantoms in here really has me wanting another one!! :o curse you all! Hahaha
                  Ive been toying with the idea of converting one to twin 80s...i know it will be a bit heavy...but it would be awesome! Heres a pic of my old f4. I did a full redinish on it and it had a 8s jf90 in it with rc geek afterburners and jhh pilots
                  • Ben De Vizio
                    Warbird and EDF Pilot
                    • Jun 2018
                    • 11
                    • Worthing, West Sussex, United Kingdom
                    Some photos from the locals club scale evening of the finally finished RAF F4 Phantom. Still yet to fly but will be in spring!
                      • 4817
                      Ben, Beautiful work, Sir. Bravo Zulu. Best, LB
                      • themudduck
                        -TMD- Foaming at the Mouth!
                        • 1041
                        • Burton OH (near Cleveland)
                        Dear Ben, your bird looks really cool - and it appears like you installed big flaps, I can't see any ailerons. Did you do a modification? Or are the surfaces just drooping?
                        • Ben De Vizio
                          • Jun 2018
                          • 11
                          Hi, no surfaces are just drooping no mods done on it
                          • JohnVH
                            • Nov 2017
                            • 259
                            • Lynden, WA
                            • Lcacing
                              • Dec 2017
                              • 155
                              Did a little upgrade on my F4....jetfan 90mm, typhoon 700-68-1500kv on 9s 5000 lipo. 3 minutes flights, mixed throttle, landing with 33% left. Hopefully I can get some better video..
                                @Lracing 9s sounds fast! The 1500kv setup is a good one, I used to run 8s on that, or 6s on their 1680. 8s on the 1680 devoured amps but was a very hot setup.
                                Have you measured your airspeed by any means?
                                • Corsair nut
                                  • 218
                                  • Tehachapi ca
                                  I had 1500kv in a jf90 on 8s 5800 in mine. Id get 4.5-5min and speeds in the 125-130 range. I really miss my f4. I might need another. Imo the 1500kv on 8s is about the perfect mix of powet and flight time. Extra weight wasnt really noticed either
                                  • e4dragongunner
                                    Living the dream!
                                    • 876
                                    WOW!!! Fantastic!!
                                    • Lcacing
                                      • Dec 2017
                                      • 155
                                      Alpha,
                                      I don’t have a way to measure airspeed, but the vertical performance is impressive.
                                      • Lcacing
                                        • Dec 2017
                                        • 155
                                        I think 8s is probably the better way to go, The only reason I went 9s is because I had a couple of 3s 5000’s laying around. I agree the F4 didn’t notice the extra weight. Not sure but I think with the 9s the intakes might not be big enough. More than likely will invest in some 4s packs.
                                        The 9s produced 3150 watts using HRB 5000’s pulling 107 amps.
