  • paulrkytek
    • Jun 2019
    • 530
    • North of England
    Originally posted by Radar-Guy
    There is no need for any auxiliary air inlets. I‘ve got two FW L-39 and both have the heater hole closed from both sides. I‘m flying off grass and tried it with a couple of different fan setups.
    Well its done now and it wont do any harm and gives me peace of mind. The way I see it there was no point in Freewing putting an air transfer hole between the nose compartment and the cabin and not providing a clear way to get the air in from the outside. If you have closed the cheater hole from both sides that means the air intake area from the 2 main side inlets will be around 80% of the swept fan area which I would have thought would have had a bit of an impact on initial take off thrust, but hey what do I know !!!
    • Radar-Guy
      AirBorn Jetworkx
      • 364
      My calculations showed 100%, there's really no noticable difference during take-off.
      • paulrkytek
        • Jun 2019
        • 530
        • North of England
        You are probably more accurate than me, I used a tape and guessed on the safe side for the d shaped ducts, my fan calc is accurate for the fms fan
        Freewing L39 Albatros 80mm edf, 1055mm span 1351mm length 2200gm dry weight, FMS 80mm 12blade edf (320gms)with 6s 3280-2100kv inrunner producing 3500g thrust. weight with 4500mah 40c zippy compact s (720g) AUW incl rx &bec 2965gms power to weight = 1.18 to 1.Cheeter fan 3300mm2, cheeter fan with mesh 2300mm2.main inlet ducts3250mm2 fan dia area 5025mm2, motor area 960mm2 so fan swept area4065mm2. inlet air with mesh covered cheater fan 5650mm2. separate BEC set at 5V.
        • steven gubala
          • 69
          what is everyone using for expo on their planes? I'm using a spektrum dx9 transmitter and a spektrum AR 637T receiver, any help would be great.
            • 8817
            Expo is a very personal thing and you have to experiment to see what feels right for you. This L-39 is a very stable airplane and responds well to direct inputs. However, typically, I dial in about 20 to 25% expo on the AIL, ELE channels. I use very little to no expo on the RUD. Some would find that excessive while others really could use even more. Consider also, that when using a 637T and utilizing SAFE, stick inputs in SAFE will be greatly reduced just by nature of SAFE. Even in AS3X, expo may not translate well.
            • steven gubala
              • 69
              ok got you xviper, thanks for your input
              • SanExup
                • 912
                • Western Wy.
                I use some receiver's with as3x and on EDFs I use 30% expo. I'm the opposite, I use 40% expo on the rudder/nosewheel usually with 100% travel but it's plane dependent.
                • SanExup
                  • 912
                  • Western Wy.
                  Prop planes I use less expo.
                  • Gripper39
                    • Apr 2021
                    • 14
                    Lost my L-39 at the weekend in the desert. flew too far out for the return leg for landing and in the heat haze/dust it just disappeared! i cut the throttle and hoped for the best after waiting a few seconds to see if the haze cleared but it never appeared again, after 2 1/2 hours walking in the dubai desert with no water i had to give up before i became a victim of the heat myself. Damm i miss this jet was a wonderful aircraft to fly.
                    • paulrkytek
                      • Jun 2019
                      • 530
                      • North of England
                      First flight with my L39, lots of stuttering from FMS motor, took out100amp esc and separate bec, installed the following :-
                      Freewing L39, 1050mm ws 23.6dm2. 3kg with rhino 4000mah 50c battery WL about 130gms/dm2.
                      FMS platinum pro 3280 2100kv in-runner,ceramic bearings 3.5kg thrust, 120amp Turnigy 32 plus HV 2-8s with 8amp bec esc timing low at 6 deg. Pwm freq 12K.( 52500rpmx4/20 = 10.5and esc card states 8k or 12k ) start up power 10%, brake off , lipo cells on auto, cut off voltage 3.3v, temp protect 140degc. Auto rotation off moto type normal, bec voltage 5.5v Power to weight = 1.15 to 1.0. Full throttle 24.9v 103 amp 2380 watts static on power meter.
                      Balanced fan with table vibration method,running smooth now, any thoughts before I take to the skies again ?
                      • paulrkytek
                        • Jun 2019
                        • 530
                        • North of England
                        First 3 flights with L39 went ok but I prefer the sound of the freewing 80mm so I bought one, installed it, very happy with sound. Not quite the thrust of the fms fan but ok. I asked Motion for performance figures of the 9 blade and was told freewing did not give them any info and they would not give me any esc settings stating that the fan was designed to be used with their esc. I consider that a poor response. How am I supposed to check fan performance if I do not have basic figures ? Here are Freewing figures which I obtained from Ali express within an hour of reading the motion r.c.reply
                        https://fr.aliexpress.com/item/40010...19419660%22%7D
                        power meter readings taken this lunchtime in the model, static 24.9v 86a 2013w Turnigy plush 32 120 amp HV esc with 8 amp bec, timing on auto, pwm 12k. moto type edf. Here are the figures from the highlighted Ali Express site :- Fan ref E72313 3658 1920kv 3350-3450 gms thrust 85-91amps 100amp esc wt 285gms 2100 watts
                        • Bellke
                          • 118
                          • AZ
                          I can sympathize, I lost mine in the AZ desert this past weekend after 4 1/2 flights. I was liking it so much though I'm already thinking of another.
                          • Turbinefancy
                            Head-tracking FPV Advocate!
                            • 294
                            • Irvine, California, USA
Name:	L-39 Sunset (2).jpg
                            FW L-39 is too good looking and too well performing a plane to leave this thread bookended with a crash pic. We are having lots of fun still with ours! Sharing some formation pics!
Name:	L-39 Near Miss (2).jpg
ID:	337542Click image for larger version
Name:	L-39 Inverted.jpg
ID:	337544Click image for larger version
Name:	L-39 Dusk (2).jpg
ID:	337546Click image for larger version
Name:	L-39 on Hill (2).jpg
                            • Turbinefancy
                              • 294
                              I flew a Xfly Sirius against my friend’s FW L-39 in exciting dogfight from cockpit view using head-tracking FPV. The L-39 gets small quick (it’s fast) Which one came out on top?
                              • Turbinefancy
                                • 294
                                And "keeping up foreign relations" cause he was inverted
                                  I got to get my f14 loaded up, I just have to get my muscle memory down for landing where I'm comfortable enough to load up the fpv setup.
                                  • Turbinefancy
                                    • 294
                                    Dude,
                                    The dual FPV setup would be ideal for dogfight! Back seater acting like goose to keep an eye on bogey and front seater maneuvering for the shot. If only the analog setup had better resolution... I had a hard time spotting the bogey during the head-on pass even with digital HD. It's barely a speck in the goggles and flash by so fast
                                      Yeah you reeeeaally have to look for the other plane, but man it's so much fun when it comes together I was thinking maybe short streamers to help have more visual
                                      • Turbinefancy
                                        • 294
                                        Short ones don’t help much, need at least 10-15 ft long to be visible at all.
                                          Ah yeah, you really have to train yourself, the other thing is refresh rates of the cameras and video equipment. There's alot of variables that come into play going head to head like that with jets.
