  • RichJ53
    • Nov 2018
    • 342
    • Southern Oregon
    Originally posted by Scale Master
    Well boys I finally got my "Star Scream" F-22 Turbine conversion complete! I waited for the new X-45 to com in @ 10lbs of thrust instead of using the slightly bigger and heavier K30 @7.5lbs of thrust! This motors diameter is smaller than a soda can. This Turbine is bad to the bone, high quality, light powerful with a 2 stage compressors. The pump is brushless, and the GSU is small and super light weight. Super easy plug and play set up, NO programing needed from you radio for throttle trim settings as it already knows you radios end points, unlike the kingtech stuff which required the "in learning" process to get things set up. The pics show pretty straight forward installation right where the old EDF unit was. Made the fuel tank with a 33.6 ounce Fuji bottle that squeezed right over the CG area, not using a UAT to save space, so I'm using a felt tip clunk and air trap soft cover over it. Jet has JP wheels and brakes (60mm). 3 lipo backs to power everything; 950mAh/brakes, 2000mAh-50C/ECU, and 2000mAh/Servos along with a BEC. See pics. If you have any question let me know!
    Love the look of this new turbine. Xicoy has great stuff and very high quality. This is something I would like to have, but it is a bit expensive for the size (IMO)
    Keep us updated...…. so much fun
    Rich
      • 8205
      Well done! Look forward to the video!
      • Jdcrow
        • Mar 2019
        • 193
        • Bentonville AR
        well, i decided to hold off on the F-18 for a bit. Although the Service Bulletin and Support from Motion/MRC has been outstanding, i just decided to go the F-22 Route for now. Wow. 131 pages of comments. Is there a recent post someone can refer me to regarding refinement of CG/Throw or Mix settings? or if the Owners Manual references are still the baseline. Maybe Pin a post for those things for the next newby.
          • 8205
          I have found the manual to be pretty spot on for me. This is one model you will fall in love with fast. Excellent flight envelope and performance on 6S...Tracks exceptionally well, very well behaved. Floaty at times (in a good way). A breeze to takeoff and land. Go by the book and have a ball.
            • 5385
            This... if you want a nice simple setup just go by the manual.
            • e4dragongunner
              Living the dream!
              • 876
              • Arlington Heights Il.
              Wow man! That rocks!
              • Ron1950
                Retired ATC
                • Oct 2015
                • 887
                • brandon ms
                sad news as Bill 34207 has passed away in sw fla I beleave it was Friday...bill was a great guy and would help anyone with there planes or boats anytime RIP Bill
                  • 4819
                  Ron, My condolences to you and to those who knew Bill 34207. I did not have the pleasure, though my thoughts and prayers go out to those who called him friend. Best, Steve
                  • fredmdbud
                    • 450
                      Rest in the arms of the Lord. We will miss you here Bill. Blessings and peace to your family and friends... Jerry
                        For those who don't know, the avatar above was his on Hobby Squawk.
                          • 8205
                          Condolences to Bill's family and friends. RIP Bill.
                          • Skyboom
                            Foam flyer
                            • Nov 2018
                            • 344
                            • Chilliwack, British Columbia, Canada
                            I remember that avatar. Sorry to hear.
                            • Jdcrow
                              • Mar 2019
                              • 193
                              • Bentonville AR
                              Have my F-22 ready to maiden. One question, which reference seam is used for setting Neutral on the Elevator? The higher seam just in front of the elevator leading tip? or stepped down seam just slightly aft of it?
                              Thanks for the help.
                                You measure up from the bottom edge of the fuselage. This pic should help.
                                • gooniac33
                                  The Original Gooniac
                                  • Jun 2016
                                  • 1047
                                  Lots of flying this past weekend!! will share videos when they are uploaded....
                                  • Jetman64
                                    • Jun 2017
                                    • 113
                                    CRAP!
                                    • gooniac33
                                      • Jun 2016
                                      • 1047
                                      I still have many more to upload... but here are a couple that are done thus far...
                                      • Bogietrim
                                        Ultimate gravity tester
                                        • Oct 2013
                                        • 112
                                        • Cincinnati, Ohio
                                        Thanks Skyboom! They are position lights bars (on the vertical stabs, wings, and forward fuse) for night ops and formation.
                                        Very nice job! May I ask where you got the formation light bars?
                                        • Scale Master
                                          X USAF Pilot, Commercial IFR Jet Rated
                                          • Apr 2019
                                          • 86
                                          They were 3d printed then wired up the LED's in them. There is some videos on YouTube showing how to do it.
                                          If you want to purchase this kit send me an Email to
                                          Solt4923crew@hotmail.com
