Been flying my Raptor 90 a lot lately just got my highest speed on it running a SMC 9300/8k hivolt pack. Still flies great can feel the extra weight landing but 7min flights times oh hell yea -
I've got a used F-22 in good condition. I added lights and afterburner, filled the surface and airbrushed a fantasy desert design, based on the F-15 and the colourful tails of some F-16s. I used Vallejo for the first time, which was easy to use. Last step was weathering, which gives a more realistic effect. Grey is fine on the ground, but not in cloudy or winter sky conditions.
It's a great flying jet :-)
Timo
9 PhotosLeave a comment:
Hi FastNLight: I just ordered the light lens set from Ali Express. I found a pic of a F-22 closeup of the landing lights and I think I can come up with a reasonable facsimile using those light covers.
Thanks!
davgeeLeave a comment:
Hi Fast N Light: thanks for the suggestion on the lens covers. Question: is there a filament that will print in a clear look, not cloudy but more like glass? If so, I might try my first design at these light covers.
The foam covers really help out in transport in/out of my house to the car and then to the field. Th entrance road to he field is Very rough!
The red ribbons are good to be sure I don’t take off with one or more of the foam covers on the airplane! Don’t ask me how I know, just asking for a friend!🤣🤣Leave a comment:
My limited experience is with clear PC. It's not clear like glass, but maybe 80% transparent with a good print orientation. Resin printers can do much better, but I don't have one.
That's why I purchased the lenses from AliExpress. 15degree has a tight beam. 60 degree is very splashy eg bright from wide angles. I like the way they appear different together.
Dave Glad that design worked out for you. Another option for lens covers is for you do design a 3D printed version. Could be an easy 1st design project for you if you are ready to get into that.Hi Fast N Light: first of all, thank you for designing these parts. They printed up beautifully. I did not see any name as to the author when I found it online last week, otherwise I would have posted your name for the credit.
I’m still new to 3D printing so little jobs like this help me advance in learning this wonderful parts production. I don’t know how to design my own parts yet, but hope to learn that skill sometime soon.
I modified how to assemble the parts slightly. I just CA’d the lights onto the back plate of the housing and it worked fine. I used two small screws per the instructions to attach the light onto the printed part that slides onto the nose gear strut.
I also made a simple soldering job attaching the wires from the new light to the OEM wires clipped from the light that came with the model.
I appreciate all of you who go to the trouble to add cool mods or embellishments to make our models stand out. Besides yourself, there are folks like Kallend and Elbee on Hobbysquawk who have helped me and others to add neat parts onto our airplanes.
If I find a small clear plastic part that looks like a light lens cover I might add that onto the nose lights, or might even just cut a couple of discs out of clear styrene. Or, it looks pretty good as it is, too.
cheers
davegee
Really like your transport covers. Red tags are a nice touch!
I have other parts for the F-22 on Cults as well as Thingiverse. Leave a comment:
Just received my F22 today put it together tomorrow have a few others to maiden and fly first waiting on the front gear support anyways. Can’t wait to take it up thoughLeave a comment:
cheers
davegeeLeave a comment:
The light looks great Dave. Gotta be my design. Thanks for posting the make.Having fun with my new 90mm F-22 Raptor. Have 5 flights on it so far. For grins, I found plans to make a more scale dual landing light that goes on the nose gear strut. It was pretty simple to print up, wire up, and install. Finished it just now. The two side-by- side landing lights look cool and probably more scale, certainly more scale than the OEM locomotive-looking train light that I don't care for. Besides, it gave me a little more experience printing and assembling parts with my fairly new Prusa mini printer. Some pics below.
Cheers
davegee
Curious how you mounted the LEDs w/o the lenses? I didn't really provision for that option, but you seem to have found a way...
Cheers
davegee
Hello, I am trying to find blueprints of the outer surface of this plane to model in Blender. For this goal, I need photos or drawings, from the top, front and side angles. I checked the manual but couldn't find useful blueprint-worthy assets. There is nothing else in the support tab also, for downloading. I am looking for an image file looks like below, but only in the correct proportions of Freewing F22, not some random F22 blueprint on the internet. Thanks in advance.
Completed the design of the F-22 scale wheel rims with rolling element bearings & low bounce tires. Compatible with Dave Brown low bounce tires which have excellent performance, light weight and low cost. Front rims have 2.0” and 1.75” wheel diameter options. Nose Gear Strut Extension and Nose Gear Flex Brace have been previously posted on RCG.
The wheel rim and tooling print files in the .3MF format (includes slicer metadata) are available along with a 10 page assembly guide. More pictures in my RCG post.
Also posted a replacement landing light
Could be multiple things, do you store them at the right voltage? So you fly to around 3.7v or completly empty them out? Do you cell balance etc etc.Leave a comment:
Looking for some thoughts on lipo battery’s getting cell blow out in my F22 90mm freewing. I’ve had 2 6s 5000mha HRB and one admiral 6s 5100mah battery’s blow out one battery cell during flight. The EDF is a jet fan 90mm with a Freewing 1960 kv motor and the stock
freewing 130amp esc. Anyone have any thoughts on why this is happening? Battery’s getting expensive!Leave a comment:
