Originally posted by scooter genie View Postyep...goes in a slot right behind the canopy latch. You can see capt Mike gluing it on in the build video. I have been really watching this one for a while now, and just about ready to pull the trigger...one question though. Should I pop on the inrunner version, or wait for the arf plus to come back in stock, and go for an 8s set up ? Any suggestions are welcome.
Originally posted by crxmanpat View PostI know you've already installed it, but that antenna actually goes under the nose, about 2" back from the nose cone. It doesn't show a step for that in the manual, but if you look at the page where you glue the probes on the sides of the fuse, you can see the antenna installed on the bottom. I have to make sure that when I transport the plane I support the nose ahead of the antenna to keep it from being bent/torn off.
Other than bummer, only one thing to say. Order quickly if you want the A-10 and don't expect it before late June. Pre-order 1 on it it should be shipping late next week (I hope)My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
Ok well I got the gyro installed on the plane. Since I am using the Lemon 7ch I needed to remove the air brake servo wire which is fine with me. I rarely use it anyway and would much rather have a gyro instead of a brake that is not very useful...it worked out pretty well but the results were puzzling. I turned down all gain and used just a tad on aileron. it helped but there was still quite a bit or wobble. So I decided to bump the rudder and see what the plane did. That is where all the wobble is coming from!! It did some wonky stuff when I touched the rudder! So the rudder or vertical stabs are the reason for the rock. I will be tweaking the rudder and aileron gain to get it all right.. I may even take a video of the results too. My landing was perfect but the landing gear had been cracked for a while and finally gave up. I will repair that and then get it back into the air...Check me out on youtube at https://www.youtube.com/user/gooniac33
Well I got 3 flights on my F-15 yesterday and am now in love with it all over again. I have been fiddling with my Lemon RX w/3 axis gyro to get rid of the wiggle and finally have. What blew me away was how much rudder gain was required to do that!! The gain is almost all the way up and now the plane goes where you point it with no wibble wobble at all!! Now it flies and tracks just like the real deal! I looked amazing yesterday and now I don't want to stop flying it! Landings were buttery smooth, the approach was rock solid with no tipping. No video this time but I will get some next time. I did low slow passes and low fast passes. All were rock solid and need to be seen to be appreciated.... video to come!Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by gooniac33 View PostOk well I got the gyro installed on the plane. Since I am using the Lemon 7ch I needed to remove the air brake servo wire which is fine with me. I rarely use it anyway and would much rather have a gyro instead of a brake that is not very useful....
Got 3 flights on my F-15 yesterday. This plane flies so great! Just wish I could get 4+ minutes out of it. I put the HiPo fan in it, so I don't have to fly at full power most of the time. But, I'm still just getting 3 1/2 minutes from taxi out. At 1 minute I start the landing cycle and usually pull in when the clock runs out. That leaves me with 20-25% on my Admiral 6S 5000 pack. Every once and a while I'm down to 15-18%, and the battery is smokin'.
It's a great 3 1/2 minutes, though. Nothing looks better than that plane screaming by and then pulling a hard back away ----- Love it!
Anyone know how this plane flies with the missile package? I guess I'd be at full power all the time then.
I have the high performace power pkg in my F-15 and was flying with all the weapons on it right from the first flight, it flew really good but had a little tracking issue I didn't like, so a few flights ago I took off the weapons and pods, Wow is all I can say, it tracked so much better and the speed of course is better, So yes it flies good with it loaded up and you don't have to fly at full power but it flies so much better clean. Hope this helps with your decision, it does look better loaded up though, looks ready for a mission.
Originally posted by Evoman View Post
I got some more great flights with mine this past weekend! Thankfully a friend got a good high quality 4k video review of my set up. I will post before and after videos so that you can see the difference...
Originally posted by DCORSAIR View PostI have the high performace power pkg in my F-15 and was flying with all the weapons on it right from the first flight, it flew really good but had a little tracking issue I didn't like, so a few flights ago I took off the weapons and pods, Wow is all I can say, it tracked so much better and the speed of course is better, So yes it flies good with it loaded up and you don't have to fly at full power but it flies so much better clean. Hope this helps with your decision, it does look better loaded up though, looks ready for a mission.
